Ga door naar hoofdinhoud
Samsung Galaxy Watch4 Classic Display Replacement
Adriana Zwink
Adriana Zwink en 3 andere bijdragers
Voor het laatst geüpdatet op November 21, 2024
20 - 45 minuten
Gemiddeld
Uitgelichte handleiding
Use this guide to replace a cracked or broken screen on your Samsung Galaxy Watch4.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your Galaxy Watch4 Classic. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Samsung Galaxy Watch4 Classic Display Replacement, Power down your watch: stap 1, afbeelding 1 van 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the back cover: stap 2, afbeelding 1 van 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
    My model needed the Y00 screwdriver, the Y000 was too small and did mess up the screws' head a bit.
    Andreas G - Antwoord
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
    • Use the pointed end of a spudger to disconnect the hall sensor-, the display-, and the crown button flex cable.
  3. Samsung Galaxy Watch4 Classic Display Replacement, Unscrew the motherboard: stap 6, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  4. Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: stap 7, afbeelding 1 van 3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: stap 7, afbeelding 2 van 3 Samsung Galaxy Watch4 Classic Display Replacement, Remove the motherboard: stap 7, afbeelding 3 van 3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
    • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
    • Twist and tilt the spudger to lever the core assembly out of the metal housing.
    • Thread the display flex cable through the opening in the core assembly.
    • Remove the core assembly.
  5. Samsung Galaxy Watch4 Classic Display Replacement, Heat the display: stap 9, afbeelding 1 van 1
    • Heat an iOpener and apply it to the display for two minutes to loosen the adhesive.
    • If your display is cracked, keep glass shards contained by applying a strip of tape over the glass.
    • Use your finger to steadily push the display down through the watch's metal housing to separate the display from the frame.
    • Remove the display.
Conclusie
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
4 andere personen hebben deze handleiding voltooid.
Adriana Zwink
56.477 Reputatie
167 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
19.510 handleidingen geschreven
Één opmerking
Where can I order the screen?
Scott Snyder - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 57
Afgelopen 30 dagen: 227
Altijd: 14,403
