Ga door naar hoofdinhoud
Nintendo Switch Motherboard Replacement
Wat je nodig hebt
    1. Nintendo Switch Motherboard Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 1 van 3 Nintendo Switch Motherboard Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 2 van 3 Nintendo Switch Motherboard Replacement, Release the Joy Con controller locking tabs: stap 1, afbeelding 3 van 3
      • Before you begin this repair, make sure the device is completely powered off.
      • Press and hold down the small round button on the back of the Joy Con controller.
      • While you hold down the button, slide the controller upward.
      Vraag FixBot
      Voeg opmerking toe
    2. Nintendo Switch Motherboard Replacement, Remove the Joy Con controllers: stap 2, afbeelding 1 van 3 Nintendo Switch Motherboard Replacement, Remove the Joy Con controllers: stap 2, afbeelding 2 van 3 Nintendo Switch Motherboard Replacement, Remove the Joy Con controllers: stap 2, afbeelding 3 van 3
      • Continue sliding the Joy Con upward until it's completely removed from the console.
      • Repeat this same process for the other Joy Con.
      Vraag FixBot
      Voeg opmerking toe
    3. Nintendo Switch Motherboard Replacement, Remove the back-side screws: stap 3, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      Magnetic Project Mat
      $19.95
      • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
      • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
      • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
      Vraag FixBot
      Voeg opmerking toe
    4. Nintendo Switch Motherboard Replacement, Remove the top and bottom screws: stap 4, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement, Remove the top and bottom screws: stap 4, afbeelding 2 van 2
      • Use a JIS 00 driver to remove the following screws securing the rear panel:
      • One 2.5 mm-long screw on the top edge of the device
      • Two 2.5 mm-long screws on the bottom edge of the device
      • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
      • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
      Vraag FixBot
      Voeg opmerking toe
    5. Nintendo Switch Motherboard Replacement, Remove the center side screws: stap 5, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement, Remove the center side screws: stap 5, afbeelding 2 van 2
      • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
      Vraag FixBot
      Voeg opmerking toe
    6. Nintendo Switch Motherboard Replacement: stap 6, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 6, afbeelding 2 van 2
      • Use your finger to flip up the kickstand on the back of the device.
      • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
      Vraag FixBot
      Voeg opmerking toe
    7. Nintendo Switch Motherboard Replacement, Remove the kickstand well screw: stap 7, afbeelding 1 van 1
      • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
      • Close the kickstand.
      Vraag FixBot
      Voeg opmerking toe
    8. Nintendo Switch Motherboard Replacement, Remove the rear panel: stap 8, afbeelding 1 van 3 Nintendo Switch Motherboard Replacement, Remove the rear panel: stap 8, afbeelding 2 van 3 Nintendo Switch Motherboard Replacement, Remove the rear panel: stap 8, afbeelding 3 van 3
      • Open the game card cartridge flap.
      • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
      • Lift the rear panel straight up from the bottom of the device and remove it.
      • Don't tilt it upwards while opening or else you risk breaking the plastic tabs on the top edge of the panel.
      Vraag FixBot
      Voeg opmerking toe
    1. Nintendo Switch Motherboard Replacement, Remove the microSD card reader: stap 9, afbeelding 1 van 1
      • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Nintendo Switch Motherboard Replacement: stap 10, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 10, afbeelding 2 van 2
      • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
      • During reassembly, remove the foam pad before connecting the press connector to the motherboard. Set the foam pad back in place after you verify it's connected.
      Vraag FixBot
      Voeg opmerking toe
    1. Nintendo Switch Motherboard Replacement, Remove the shield plate: stap 11, afbeelding 1 van 1
      • Use a JIS 00 driver to remove the six 3 mm screws securing the shield plate to the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Nintendo Switch Motherboard Replacement: stap 12, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 12, afbeelding 2 van 2
      • If the console doesn't have this foam, skip this step.
      • Use your fingers or a pair of tweezers to peel back the piece of foam on the top edge of the device near the fan exhaust port.
      • If the foam doesn't easily peel away, don't force it as it might end up tearing. Carefully peel at different spots to pull back the foam.
      Vraag FixBot
      Voeg opmerking toe
    3. Nintendo Switch Motherboard Replacement: stap 13, afbeelding 1 van 3 Nintendo Switch Motherboard Replacement: stap 13, afbeelding 2 van 3 Nintendo Switch Motherboard Replacement: stap 13, afbeelding 3 van 3
      iFixit Thermal Putty
      $9.95
      • Insert a spudger underneath the shield plate along the edge of the device.
      • Pry up to lift the shield plate and remove it from the device.
      • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
      • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. This helps prevent the Switch from overheating.
      • During reassembly, if you don't have replacement thermal compound, use the flat end of a spudger to distribute the old compound evenly across the heat pipe, as thick as possible to ensure proper contact. Repeat this process on the shield plate.
      • If you need to replace it, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate compound, such as thermal putty or K5 Pro, during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    1. Nintendo Switch Motherboard Replacement, Disconnect the battery: stap 14, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement, Disconnect the battery: stap 14, afbeelding 2 van 2
      • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Nintendo Switch Motherboard Replacement, Remove the heat sink: stap 15, afbeelding 1 van 1
      • Use a JIS 00 driver to remove the three 3 mm screws securing the heat sink to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Gereedschap gebruikt in deze stap:
      iFixit Adhesive Remover
      $19.99
      • Carefully peel the two foam pieces stuck over both the heatsink and the fan away from the fan.
      • The foam only needs to be peeled back enough to clear the fan.
      • The foam is really delicate and tears easily. Use the following technique to peel the foam:
      • If you have some, dip the point of a spudger in adhesive remover or isopropyl alcohol (90% or greater).
      • Insert the point of a spudger underneath a part of the foam that isn't stuck to anything.
      • Press the top of the foam with your finger to hold it in place.
      • Roll the spudger tip underneath the foam all the way to the other end of the foam to release it.
      Vraag FixBot
      Voeg opmerking toe
    3. Nintendo Switch Motherboard Replacement: stap 17, afbeelding 1 van 3 Nintendo Switch Motherboard Replacement: stap 17, afbeelding 2 van 3 Nintendo Switch Motherboard Replacement: stap 17, afbeelding 3 van 3
      • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
      • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
      • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly. Don't reuse the old thermal paste.
      • Apply thermal paste to all surfaces that had thermal paste applied previously. This includes between the heatpipe and aluminum shield, which the Switch uses as additional heatsinking.
      Vraag FixBot
      Voeg opmerking toe
    1. Nintendo Switch Motherboard Replacement, Remove the headphone jack and game card reader: stap 18, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement, Remove the headphone jack and game card reader: stap 18, afbeelding 2 van 2
      • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the digitizer cable's ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Nintendo Switch Motherboard Replacement: stap 19, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 19, afbeelding 2 van 2
      • Use a pair of tweezers to slide the digitizer cable horizontally out of its connector on the game card reader board.
      • Before inserting the cable during reassembly, make sure the ZIF connector locking flap is flipped up.
      • With the cable parallel to the board, gently slide it into its connector.
      • Don't force the cable into the connector. If it doesn't insert, ensure the locking flap is flipped up, reposition the cable, and try again.
      • If your touchscreen doesn't work after the repair but your Game Card reader does, make sure this cable is properly inserted. If your Game Card reader also doesn't work, check the Game Card connector in the next step instead.
      Vraag FixBot
      Voeg opmerking toe
    3. Nintendo Switch Motherboard Replacement: stap 20, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 20, afbeelding 2 van 2
      • Use the point of a spudger to pry the headphone jack and game card reader connector straight up to disconnect it from the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
      • If the touch screen doesn't work and/or game cards aren't detected after reassembly, you might have not fully reconnected this press connector. Carefully disconnect it and try again.
      Vraag FixBot
      Voeg opmerking toe
    4. Nintendo Switch Motherboard Replacement: stap 21, afbeelding 1 van 1
      • Use a JIS 00 driver to remove the three 3.1 mm screws securing the headphone jack and game card reader board to the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Nintendo Switch Motherboard Replacement: stap 22, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 22, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to remove the headphone jack bracket.
      Vraag FixBot
      Voeg opmerking toe
    6. Nintendo Switch Motherboard Replacement: stap 23, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 23, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to remove the headphone jack and game card reader board.
      Vraag FixBot
      Voeg opmerking toe
    1. Nintendo Switch Motherboard Replacement, Remove the motherboard: stap 24, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement, Remove the motherboard: stap 24, afbeelding 2 van 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Nintendo Switch Motherboard Replacement: stap 25, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 25, afbeelding 2 van 2
      • Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Nintendo Switch Motherboard Replacement: stap 26, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 26, afbeelding 2 van 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the fan cable ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    4. Nintendo Switch Motherboard Replacement: stap 27, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 27, afbeelding 2 van 2
      • Use a pair of tweezers to pull the fan cable straight out of its connector on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Nintendo Switch Motherboard Replacement: stap 28, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 28, afbeelding 2 van 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the power and volume button ribbon cable ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    6. Nintendo Switch Motherboard Replacement: stap 29, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 29, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    7. Nintendo Switch Motherboard Replacement: stap 30, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 30, afbeelding 2 van 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    8. Nintendo Switch Motherboard Replacement: stap 31, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 31, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    9. Nintendo Switch Motherboard Replacement: stap 32, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 32, afbeelding 2 van 2
      • Use the point of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail's data cable ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    10. Nintendo Switch Motherboard Replacement: stap 33, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 33, afbeelding 2 van 2
      Vraag FixBot
      Voeg opmerking toe
    11. Nintendo Switch Motherboard Replacement: stap 34, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 34, afbeelding 2 van 2
      • Use the point of a spudger to pry up the black antenna cable straight up out of its socket on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    12. Nintendo Switch Motherboard Replacement: stap 35, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 35, afbeelding 2 van 2
      • Use the point of a spudger to pry up the white antenna cable straight up out of its socket on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    13. Nintendo Switch Motherboard Replacement: stap 36, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 36, afbeelding 2 van 2
      • Use your fingers or a pair of tweezers to pull the right speaker connector straight out of its socket on the motherboard.
      • Do not pull on the connector by the speaker wires. They're very thin and can easily snap off the connector.
      Vraag FixBot
      Voeg opmerking toe
    14. Nintendo Switch Motherboard Replacement: stap 37, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 37, afbeelding 2 van 2
      • Use your fingers or a pair of tweezers to pull the left speaker connector straight out of its socket on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    15. Nintendo Switch Motherboard Replacement: stap 38, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 38, afbeelding 2 van 2
      • Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the Joy Con sensor rail data cable ZIF connector.
      Vraag FixBot
      Voeg opmerking toe
    16. Nintendo Switch Motherboard Replacement: stap 39, afbeelding 1 van 2 Nintendo Switch Motherboard Replacement: stap 39, afbeelding 2 van 2
      • Use a pair of tweezers to slide the Joy Con rail data cable straight out of its connector on the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    17. Nintendo Switch Motherboard Replacement: stap 40, afbeelding 1 van 1
      • Use a JIS 00 driver to remove the following screws:
      • Four 2.5 mm screws
      • Two 3.1 mm screws
      Vraag FixBot
      Voeg opmerking toe
    18. Nintendo Switch Motherboard Replacement: stap 41, afbeelding 1 van 3 Nintendo Switch Motherboard Replacement: stap 41, afbeelding 2 van 3 Nintendo Switch Motherboard Replacement: stap 41, afbeelding 3 van 3
      • Insert a spudger into a gap between the motherboard and the frame.
      • Carefully lift up the motherboard and remove it from the frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
119 andere personen hebben deze handleiding voltooid.
Craig Lloyd
42.978 Reputatie
82 handleidingen geschreven
20Gids Commentaar
Great guide! Thank you. Just one problem: Where the !&&* can I buy a replacement?
Rob - Antwoord Deel
You can buy one on the ifixit parts store or you can find a used one on eBay.
HeyJacksonY - Antwoord Deel
What’s the name of the grey compound you insert on the cooper section on the motherboard? I’ve been wondering what that stuff is.
Steven Peck - Antwoord Deel
That is thermal compound or commonly known as thermal paste. It improves performance of parts by bridging the gaps between the CPU and heat pipes.
If you get a used motherboard is there any issues with login credentials? I assume the system memory and everything is located on this motherboard?
nrb_o_21 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 116
Afgelopen 7 dagen: 477
Afgelopen 30 dagen: 2,028
Altijd: 244,177
