Ga door naar hoofdinhoud
iPhone 15 Battery Replacement
Wat je nodig hebt
    1. iPhone 15 Battery Replacement, Prepare your phone for disassembly: stap 1, afbeelding 1 van 2 iPhone 15 Battery Replacement, Prepare your phone for disassembly: stap 1, afbeelding 2 van 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Battery Replacement, Tape over any cracks: stap 2, afbeelding 1 van 2 iPhone 15 Battery Replacement, Tape over any cracks: stap 2, afbeelding 2 van 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, Mark your opening picks: stap 3, afbeelding 1 van 3 iPhone 15 Battery Replacement, Mark your opening picks: stap 3, afbeelding 2 van 3 iPhone 15 Battery Replacement, Mark your opening picks: stap 3, afbeelding 3 van 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, Remove the pentalobe screws: stap 4, afbeelding 1 van 2 iPhone 15 Battery Replacement, Remove the pentalobe screws: stap 4, afbeelding 2 van 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, Heat the bottom edge: stap 5, afbeelding 1 van 1
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Battery Replacement, Insert an opening pick: stap 6, afbeelding 1 van 3 iPhone 15 Battery Replacement, Insert an opening pick: stap 6, afbeelding 2 van 3 iPhone 15 Battery Replacement, Insert an opening pick: stap 6, afbeelding 3 van 3
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Battery Replacement, Back glass information: stap 7, afbeelding 1 van 1
      • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
      • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Battery Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 1 van 3 iPhone 15 Battery Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 2 van 3 iPhone 15 Battery Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 3 van 3
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 15 Battery Replacement, Heat the right edge: stap 9, afbeelding 1 van 1
      • Heat the right edge of the back glass until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 15 Battery Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 1 van 3 iPhone 15 Battery Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 2 van 3 iPhone 15 Battery Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 3 van 3
      • Don't insert your pick deeper than 7 mm along the right edge.
      • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
      • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
      • Leave this pick inserted to prevent the adhesive from resealing.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 15 Battery Replacement, Heat the left edge: stap 11, afbeelding 1 van 1
      • Heat the left edge of the back glass until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 15 Battery Replacement, Separate the left edge adhesive: stap 12, afbeelding 1 van 3 iPhone 15 Battery Replacement, Separate the left edge adhesive: stap 12, afbeelding 2 van 3 iPhone 15 Battery Replacement, Separate the left edge adhesive: stap 12, afbeelding 3 van 3
      • Along the left edge, don't insert your pick deeper than 5 mm.
      • Insert a second opening pick at the bottom edge.
      • Rotate the second pick around the bottom left corner.
      • Slide this pick up to the top left corner to separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone 15 Battery Replacement, Heat the top edge: stap 13, afbeelding 1 van 1
      • Heat the top edge of the back glass until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone 15 Battery Replacement, Separate the top edge adhesive: stap 14, afbeelding 1 van 3 iPhone 15 Battery Replacement, Separate the top edge adhesive: stap 14, afbeelding 2 van 3 iPhone 15 Battery Replacement, Separate the top edge adhesive: stap 14, afbeelding 3 van 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
      • You might hear and feel clicks as the top two clips release.
      • Leave this pick in place to prevent the adhesive from resealing.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone 15 Battery Replacement, Heat the top right corner: stap 15, afbeelding 1 van 1
      • Heat the top right corner of the back glass until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone 15 Battery Replacement, Separate the top right corner adhesive: stap 16, afbeelding 1 van 3 iPhone 15 Battery Replacement, Separate the top right corner adhesive: stap 16, afbeelding 2 van 3 iPhone 15 Battery Replacement, Separate the top right corner adhesive: stap 16, afbeelding 3 van 3
      • Don't insert your pick deeper than 4 mm along the right edge.
      • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    13. iPhone 15 Battery Replacement, Open the back glass: stap 17, afbeelding 1 van 3 iPhone 15 Battery Replacement, Open the back glass: stap 17, afbeelding 2 van 3 iPhone 15 Battery Replacement, Open the back glass: stap 17, afbeelding 3 van 3
      • Gently lift and swing open the back glass to the right of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a raised surface so it doesn't strain the cable.
      Vraag FixBot
      Voeg opmerking toe
    14. iPhone 15 Battery Replacement, Unfasten the lower connector cover: stap 18, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      FixMat
      $36.95
      • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
      Vraag FixBot
      Voeg opmerking toe
    15. iPhone 15 Battery Replacement, Remove the lower connector cover: stap 19, afbeelding 1 van 3 iPhone 15 Battery Replacement, Remove the lower connector cover: stap 19, afbeelding 2 van 3 iPhone 15 Battery Replacement, Remove the lower connector cover: stap 19, afbeelding 3 van 3
      • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    16. iPhone 15 Battery Replacement, Disconnect the battery: stap 20, afbeelding 1 van 3 iPhone 15 Battery Replacement, Disconnect the battery: stap 20, afbeelding 2 van 3 iPhone 15 Battery Replacement, Disconnect the battery: stap 20, afbeelding 3 van 3
      • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
      • A plus and minus sign is printed on the head of this connector.
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    17. iPhone 15 Battery Replacement, Unfasten the middle connector cover: stap 21, afbeelding 1 van 2 iPhone 15 Battery Replacement, Unfasten the middle connector cover: stap 21, afbeelding 2 van 2
      • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
      Vraag FixBot
      Voeg opmerking toe
    18. iPhone 15 Battery Replacement, Remove the cover: stap 22, afbeelding 1 van 3 iPhone 15 Battery Replacement, Remove the cover: stap 22, afbeelding 2 van 3 iPhone 15 Battery Replacement, Remove the cover: stap 22, afbeelding 3 van 3
      • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    19. iPhone 15 Battery Replacement, Disconnect the wireless charging coil: stap 23, afbeelding 1 van 2 iPhone 15 Battery Replacement, Disconnect the wireless charging coil: stap 23, afbeelding 2 van 2
      • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
      Vraag FixBot
      Voeg opmerking toe
    20. iPhone 15 Battery Replacement, Remove the back glass: stap 24, afbeelding 1 van 1
      • Remove the back glass.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, Separate the battery cable: stap 25, afbeelding 1 van 3 iPhone 15 Battery Replacement, Separate the battery cable: stap 25, afbeelding 2 van 3 iPhone 15 Battery Replacement, Separate the battery cable: stap 25, afbeelding 3 van 3
      • Light adhesive secures the battery cable to the logic board.
      • Slide an opening pick under the battery cable to separate it from the logic board.
      • Be careful not to crease the cable or dent the battery with your tool.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, Peel up a corner of the pull tabs: stap 26, afbeelding 1 van 3 iPhone 15 Battery Replacement, Peel up a corner of the pull tabs: stap 26, afbeelding 2 van 3 iPhone 15 Battery Replacement, Peel up a corner of the pull tabs: stap 26, afbeelding 3 van 3
      • Your iPhone's battery is secured with two stretch release adhesive strips. The next four steps show how to remove them and free your battery.
      • Be careful not to dent or puncture the battery, and avoid using sharp tools near it.
      • Use the tip of an opening pick to scrape up an edge of each stretch release pull tab from the top of the battery until you can grip the tab with blunt nose tweezers.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Battery Replacement, Peel up the pull tabs: stap 27, afbeelding 1 van 3 iPhone 15 Battery Replacement, Peel up the pull tabs: stap 27, afbeelding 2 van 3 iPhone 15 Battery Replacement, Peel up the pull tabs: stap 27, afbeelding 3 van 3
      • Use blunt nose tweezers to grip a pull tab and peel it from the battery.
      • Don't try to pull the tab out from under the battery just yet.
      • Repeat this for the other pull tab.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Battery Replacement, Free the top edge of the battery: stap 28, afbeelding 1 van 3 iPhone 15 Battery Replacement, Free the top edge of the battery: stap 28, afbeelding 2 van 3 iPhone 15 Battery Replacement, Free the top edge of the battery: stap 28, afbeelding 3 van 3
      • The stretch release adhesive wraps around the top edge of the battery, and must be separated before you remove the strips.
      • Hold one of the pull tabs away from the battery with tweezers.
      • Use an opening pick to slice the adhesive securing the strip to the top edge of the battery.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Battery Replacement, Remove the stretch release adhesive: stap 29, afbeelding 1 van 3 iPhone 15 Battery Replacement, Remove the stretch release adhesive: stap 29, afbeelding 2 van 3 iPhone 15 Battery Replacement, Remove the stretch release adhesive: stap 29, afbeelding 3 van 3
      • Grab an adhesive strip's pull tab and slowly pull it at as low of an angle as possible out from under the battery.
      • Give the strip plenty of time to stretch and re-grip it as necessary. Avoid dragging it over the components or cables above the battery. Consider wrapping the strip around a tool for better leverage.
      • Repeat this for the other strip.
      • If a strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, don't worry—move on to the next step for an alternate method.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 15 Battery Replacement, Alternate method to remove the battery: stap 30, afbeelding 1 van 2 iPhone 15 Battery Replacement, Alternate method to remove the battery: stap 30, afbeelding 2 van 2
      • If you removed both stretch release adhesive strips, congratulations—you can now remove the battery! If not, follow the next three steps to remove it with isopropyl alcohol and a plastic card.
      • Prop up the right edge of the phone (the side with the volume buttons).
      • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the inside edge of the battery.
      • Prop up the top edge of the phone and repeat this for the upper edge of the battery.
      • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 15 Battery Replacement, Insert a plastic card: stap 31, afbeelding 1 van 3 iPhone 15 Battery Replacement, Insert a plastic card: stap 31, afbeelding 2 van 3 iPhone 15 Battery Replacement, Insert a plastic card: stap 31, afbeelding 3 van 3
      Plastic Cards
      $2.99
      • Don't bend or crease your battery. If it feels stubborn, apply a few more drops of isopropyl alcohol and try again.
      • Insert the short edge of a plastic card between the left edge of the battery and the frame.
      • Hold the phone steady and pry the battery up.
      • Depending on how strong your adhesive is, this may take some time. Allow up to a minute of constant pressure for the adhesive to loosen.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 15 Battery Replacement, Pry up the battery: stap 32, afbeelding 1 van 3 iPhone 15 Battery Replacement, Pry up the battery: stap 32, afbeelding 2 van 3 iPhone 15 Battery Replacement, Pry up the battery: stap 32, afbeelding 3 van 3
      • Once you can slide the plastic card deeper under the battery, slide it side-to-side to slice any remaining adhesive.
      • Lift the battery until you can grab it with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 15 Battery Replacement, Remove the battery: stap 33, afbeelding 1 van 2 iPhone 15 Battery Replacement, Remove the battery: stap 33, afbeelding 2 van 2
      • Remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, End of disassembly: stap 34, afbeelding 1 van 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, Remove the residual battery adhesive: stap 35, afbeelding 1 van 1
      • If there's any large pieces of residual battery adhesive remaining, use a pair of tweezers to peel them off the iPhone frame.
      • Use coffee filters or a lint‑free cloth and high‑concentration (>90%) isopropyl alcohol to wipe off any remaining battery adhesive residue from the iPhone frame.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Battery Replacement, Remove the plastic sleeve: stap 36, afbeelding 1 van 2 iPhone 15 Battery Replacement, Remove the plastic sleeve: stap 36, afbeelding 2 van 2
      • If your replacement battery comes with a plastic sleeve, peel it off and remove it.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Battery Replacement, Remove adhesive liner: stap 37, afbeelding 1 van 2 iPhone 15 Battery Replacement, Remove adhesive liner: stap 37, afbeelding 2 van 2
      • If your battery doesn't come with pre‑installed adhesive, follow this guide to install it, then come back to this guide to finish reassembly.
      • Peel the liner off the battery adhesive.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Battery Replacement, Place the battery: stap 38, afbeelding 1 van 3 iPhone 15 Battery Replacement, Place the battery: stap 38, afbeelding 2 van 3 iPhone 15 Battery Replacement, Place the battery: stap 38, afbeelding 3 van 3
      • Hold the battery over its place in the iPhone and connect its press connector.
      • With the battery connected, lower it into place and use your fingers to press it into the frame.
      • After the battery is set, use the tip of a spudger to pry up and disconnect the battery cable press connector.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Battery Replacement, Remove the back glass adhesive: stap 39, afbeelding 1 van 2 iPhone 15 Battery Replacement, Remove the back glass adhesive: stap 39, afbeelding 2 van 2
      • Be careful not to damage any of the spring contacts as you clean the frame.
      • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
      • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
      • Use the tweezers to pull the adhesive off of the phone.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Battery Replacement: stap 40, afbeelding 1 van 3 iPhone 15 Battery Replacement: stap 40, afbeelding 2 van 3 iPhone 15 Battery Replacement: stap 40, afbeelding 3 van 3
      • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
      • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Battery Replacement, Orient the adhesive: stap 41, afbeelding 1 van 3 iPhone 15 Battery Replacement, Orient the adhesive: stap 41, afbeelding 2 van 3 iPhone 15 Battery Replacement, Orient the adhesive: stap 41, afbeelding 3 van 3
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
      • Your adhesive may look slightly different.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Battery Replacement, Apply the adhesive: stap 42, afbeelding 1 van 3 iPhone 15 Battery Replacement, Apply the adhesive: stap 42, afbeelding 2 van 3 iPhone 15 Battery Replacement, Apply the adhesive: stap 42, afbeelding 3 van 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
      • Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
      • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 15 Battery Replacement: stap 43, afbeelding 1 van 3 iPhone 15 Battery Replacement: stap 43, afbeelding 2 van 3 iPhone 15 Battery Replacement: stap 43, afbeelding 3 van 3
      • When the adhesive is aligned, use the flat end of a spudger or your finger to press it down firmly along the bottom edge.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 15 Battery Replacement: stap 44, afbeelding 1 van 3 iPhone 15 Battery Replacement: stap 44, afbeelding 2 van 3 iPhone 15 Battery Replacement: stap 44, afbeelding 3 van 3
      • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 15 Battery Replacement, Press the adhesive into place: stap 45, afbeelding 1 van 3 iPhone 15 Battery Replacement, Press the adhesive into place: stap 45, afbeelding 2 van 3 iPhone 15 Battery Replacement, Press the adhesive into place: stap 45, afbeelding 3 van 3
      • Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
      • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
      • Be careful not to touch the spring contacts sticking through the pink liner.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 15 Battery Replacement, Remove the top liner: stap 46, afbeelding 1 van 3 iPhone 15 Battery Replacement, Remove the top liner: stap 46, afbeelding 2 van 3 iPhone 15 Battery Replacement, Remove the top liner: stap 46, afbeelding 3 van 3
      • Remove the top adhesive liner.
      • Depending on your adhesive, your liner might be split into multiple parts or be a single piece.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone 15 Battery Replacement, Prop up the back glass: stap 47, afbeelding 1 van 3 iPhone 15 Battery Replacement, Prop up the back glass: stap 47, afbeelding 2 van 3 iPhone 15 Battery Replacement, Prop up the back glass: stap 47, afbeelding 3 van 3
      • Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
      • Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone 15 Battery Replacement, Place the middle connector cover: stap 48, afbeelding 1 van 2 iPhone 15 Battery Replacement, Place the middle connector cover: stap 48, afbeelding 2 van 2
      • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone 15 Battery Replacement: stap 49, afbeelding 1 van 2 iPhone 15 Battery Replacement: stap 49, afbeelding 2 van 2
      • Use your finger to press the cover down on the logic board.
      • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone 15 Battery Replacement, Place the lower connector cover: stap 50, afbeelding 1 van 3 iPhone 15 Battery Replacement, Place the lower connector cover: stap 50, afbeelding 2 van 3 iPhone 15 Battery Replacement, Place the lower connector cover: stap 50, afbeelding 3 van 3
      • Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
      • Lay the lower connector cover over the press connectors.
      Vraag FixBot
      Voeg opmerking toe
    13. iPhone 15 Battery Replacement, Install the cover screws: stap 51, afbeelding 1 van 2 iPhone 15 Battery Replacement, Install the cover screws: stap 51, afbeelding 2 van 2
      • Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
      • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
      Vraag FixBot
      Voeg opmerking toe
    14. iPhone 15 Battery Replacement, Remove the final adhesive liners: stap 52, afbeelding 1 van 2 iPhone 15 Battery Replacement, Remove the final adhesive liners: stap 52, afbeelding 2 van 2
      • Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
      Vraag FixBot
      Voeg opmerking toe
    15. iPhone 15 Battery Replacement: stap 53, afbeelding 1 van 3 iPhone 15 Battery Replacement: stap 53, afbeelding 2 van 3 iPhone 15 Battery Replacement: stap 53, afbeelding 3 van 3
      • Remove the narrow liner covering the adhesive along the left and top edges of the frame.
      Vraag FixBot
      Voeg opmerking toe
    16. iPhone 15 Battery Replacement: stap 54, afbeelding 1 van 3 iPhone 15 Battery Replacement: stap 54, afbeelding 2 van 3 iPhone 15 Battery Replacement: stap 54, afbeelding 3 van 3
      • Hold the back glass over the phone without letting it touch the adhesive, so you can access the remaining liners along the right edge of the phone.
      • Use a pair of tweezers or your fingers to remove the remaing liners along the right edge of the phone.
      Vraag FixBot
      Voeg opmerking toe
    17. iPhone 15 Battery Replacement, Install the back glass: stap 55, afbeelding 1 van 3 iPhone 15 Battery Replacement, Install the back glass: stap 55, afbeelding 2 van 3 iPhone 15 Battery Replacement, Install the back glass: stap 55, afbeelding 3 van 3
      • Lay the back glass straight down onto the frame and press until the clips engage.
      • Press around the perimeter of the back glass to engage all the clips.
      Vraag FixBot
      Voeg opmerking toe
    18. iPhone 15 Battery Replacement, Heat the back glass: stap 56, afbeelding 1 van 2 iPhone 15 Battery Replacement, Heat the back glass: stap 56, afbeelding 2 van 2
      • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
      Vraag FixBot
      Voeg opmerking toe
    19. iPhone 15 Battery Replacement, Press the back glass: stap 57, afbeelding 1 van 3 iPhone 15 Battery Replacement, Press the back glass: stap 57, afbeelding 2 van 3 iPhone 15 Battery Replacement, Press the back glass: stap 57, afbeelding 3 van 3
      • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Vraag FixBot
      Voeg opmerking toe
    20. iPhone 15 Battery Replacement: stap 58, afbeelding 1 van 2 iPhone 15 Battery Replacement: stap 58, afbeelding 2 van 2
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Vraag FixBot
      Voeg opmerking toe
    21. iPhone 15 Battery Replacement: stap 59, afbeelding 1 van 3 iPhone 15 Battery Replacement: stap 59, afbeelding 2 van 3 iPhone 15 Battery Replacement: stap 59, afbeelding 3 van 3
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Stack them to a consistent height taller than the camera bump.
      Vraag FixBot
      Voeg opmerking toe
    22. iPhone 15 Battery Replacement: stap 60, afbeelding 1 van 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings  General  About  Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
25 andere personen hebben deze handleiding voltooid.
Clay Eickemeyer
105.750 Reputatie
472 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
10 Leden
32.566 handleidingen geschreven
4Gids Commentaar
Wait so if your phone has a dent in it and you take off your back screen to put a new battery in it can you still put your back screen back on?
Missis - Antwoord Deel
As long as the new battery has the same thickness and size as the original one, you should be able to put the back screen back on. Just make sure the dent doesn’t interfere with the back cover’s alignment or the parts that hold it in place
121niu - Antwoord Deel
can the battery be replace at the apple store or some store around in newport new cs my battery got overheated
Michael - Antwoord Deel
Ich finde Apple Reparatur-Assistenten nicht . Hab aber die neueste Firmware auf dem IPhone 15. bitte um Info
Giggler - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 361
Afgelopen 7 dagen: 2,236
Afgelopen 30 dagen: 9,547
Altijd: 136,185
