Ga door naar hoofdinhoud
Logitech G502 Hero Side Buttons Board Replacement
Spencer Day
Spencer Day
Voor het laatst geüpdatet op November 18, 2024
30 - 45 minuten
Gemiddeld
Use this guide to replace the side buttons board in your Logitech G502 Hero wired gaming mouse.
If your side buttons aren't working, are sticking, or aren't clicking all the way, you may need to replace the side buttons board.
Wat je nodig hebt
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Logitech G502 Hero Side Buttons Board Replacement, Prepare your mouse for disassembly: stap 1, afbeelding 1 van 1
    • Before starting your repair, unplug the mouse.
    • Throughout your repair, it may be helpful to lay your mouse on a soft cloth to stabilize it and prevent damage while you work.
  2. Logitech G502 Hero Side Buttons Board Replacement, Remove the feet: stap 2, afbeelding 1 van 2 Logitech G502 Hero Side Buttons Board Replacement, Remove the feet: stap 2, afbeelding 2 van 2
    • The feet are secured to the bottom of the mouse with adhesive. In order to cleanly remove them, the adhesive needs to be thoroughly heated.
    • Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
    • Alternatively, you can use a hair dryer on the Low heat setting to soften the adhesive.
    • If you're using a hair dryer, only heat the feet a few seconds at a time or you may warp the plastic shell.
  3. Logitech G502 Hero Side Buttons Board Replacement: stap 3, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 3, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 3, afbeelding 3 van 3
    • The feet have two layers—a rubberized one and an adhesive pad underneath.
    • If you're reusing the feet, be very careful not to separate the two layers or damage the feet.
    • Carefully slide the point of a spudger under the large foot near the front of the mouse, making sure it goes under both the foot and its adhesive pad.
    • The foot recesses have a small notch that makes it easier to slide your spudger under.
    • Gently slide the spudger farther under the foot and lift until you can grip the pad with your fingers.
  4. Logitech G502 Hero Side Buttons Board Replacement: stap 4, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 4, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 4, afbeelding 3 van 3
    • Peel up and remove the foot.
    • If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
  5. Logitech G502 Hero Side Buttons Board Replacement: stap 5, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 5, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 5, afbeelding 3 van 3
  6. Logitech G502 Hero Side Buttons Board Replacement, Reassembly information: stap 6, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement, Reassembly information: stap 6, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement, Reassembly information: stap 6, afbeelding 3 van 3
    • To install a new foot:
    • If any of the feet got damaged during removal or separated from their adhesive pads, replace them.
    • Use a spudger to carefully scrape up and remove any remaining adhesive bits.
    • Use isopropyl alcohol and a microfiber cloth to thoroughly clean all adhesive residue from the foot recesses. Allow the surface to completely dry.
    • Remove the feet from their backing and firmly press them into place.
  7. Logitech G502 Hero Side Buttons Board Replacement, Open your mouse: stap 7, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement, Open your mouse: stap 7, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement, Open your mouse: stap 7, afbeelding 3 van 3
    • Lift the weight door by its tab and remove it.
    • If you have weights in the compartment, remove them.
  8. Logitech G502 Hero Side Buttons Board Replacement: stap 8, afbeelding 1 van 2 Logitech G502 Hero Side Buttons Board Replacement: stap 8, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the four 5.5 mm‑long screws securing the bottom shell.
  9. Logitech G502 Hero Side Buttons Board Replacement: stap 9, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 9, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 9, afbeelding 3 van 3
    • Tight plastic clips secure the top and bottom shells. During the next few steps you should feel and hear "clicks" as the clips release.
    • Insert the flat end of a spudger between the top and bottom shells, near the back of the mouse.
    • Twist the spudger to unclip the shells.
  10. Logitech G502 Hero Side Buttons Board Replacement: stap 10, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 10, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 10, afbeelding 3 van 3
    • Insert the flat end of a spudger between the textured edge of the top and bottom shells, near the back of the mouse.
    • Slide the spudger towards the front of the mouse and intermittently twist, stopping near the screw hole.
    • Leave the spudger inserted for the next step.
  11. Logitech G502 Hero Side Buttons Board Replacement: stap 11, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 11, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 11, afbeelding 3 van 3
    • Push the spudger into the mouse and twist to unclip the shells.
  12. Logitech G502 Hero Side Buttons Board Replacement: stap 12, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 12, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 12, afbeelding 3 van 3
    • Slide the spudger towards the thumb rest and push in to unclip the shells.
  13. Logitech G502 Hero Side Buttons Board Replacement: stap 13, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 13, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 13, afbeelding 3 van 3
    • Insert the flat end of a spudger between the top and bottom shells, near the G8 and DPI shift () buttons at the front of the mouse.
    • Pry up with the spudger and push the shells apart to unclip them.
    • Unclipping this part of the mouse is tricky and may take a few tries. Be patient and don't pry too hard, or you may break one of the clips.
  14. Logitech G502 Hero Side Buttons Board Replacement: stap 14, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 14, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 14, afbeelding 3 van 3
    • At this point, the shells should be fully separated. If they're not, repeat the previous unclipping steps with your spudger.
    • Lift the top shell straight up and remove it, making sure the main mouse cable stays attached to the bottom shell.
    • During reassembly, put the top shell back in place and work your way around the perimeter firmly squeezing the shells together to reengage the clips.
  15. Logitech G502 Hero Side Buttons Board Replacement, Remove the side buttons board: stap 15, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement, Remove the side buttons board: stap 15, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement, Remove the side buttons board: stap 15, afbeelding 3 van 3
    • Gently lift the side buttons board straight up and out of its slot.
    • Don't try to fully remove the board yet, as it's still connected by a cable.
  16. Logitech G502 Hero Side Buttons Board Replacement: stap 16, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 16, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 16, afbeelding 3 van 3
    • Hold the button board out of the way so you can access its connector on the motherboard.
    • Use the point of a spudger to push up on alternating sides of the connector's plastic latch until it's in the unlocked position.
    • You should feel the latch pop up into the unlocked position. Don't push too far, or the latch may come completely off the connector.
  17. Logitech G502 Hero Side Buttons Board Replacement: stap 17, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 17, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 17, afbeelding 3 van 3
    • Gently pull the board straight up so the cable comes out of its socket.
    • The cable should come out easily. If you feel any resistance, push the latch up a little more and try again.
    • During reassembly:
    • Insert the cable into its socket so the blue tab is on the same side as the connector's latch.
    • Use the flat end of a spudger to push the latch straight down into its locked position.
  18. Logitech G502 Hero Side Buttons Board Replacement: stap 18, afbeelding 1 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 18, afbeelding 2 van 3 Logitech G502 Hero Side Buttons Board Replacement: stap 18, afbeelding 3 van 3
    • If your replacement board doesn't come with a cable, follow this step to remove and transfer the old one.
    • Set the board down on a clean, ESD‑safe surface so the side with the cable is facing up.
    • Use the point of a spudger to lift the locking flap on the ZIF connector.
    • Pull the cable straight out of its socket.
    • When installing the cable into the ZIF connector, make sure the ridged side is facing up.
Conclusie
Spencer Day
95.445 Reputatie
662 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
19.500 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 129
Altijd: 526
