Ga door naar hoofdinhoud
Onderdelen
Gereedschap
Dit is een aantal algemene gereedschappen dat gebruikt wordt om aan dit apparaat te werken. Je hebt niet elk stuk gereedschap voor elke procedure nodig.
Background and Identification
The Fitbit Ionic is a smartwatch made by Fitbit and released in 2017. It uses GLONASS, a global satellite navigation system for built-in GPS as well as SmartTrack to record user activity on the Fitbit app. It’s predecessors were the Fitbit Blaze and Surge and in 2018, Fitbit released the Fitbit Versa along with an update to the Ionic with the Fitbit OS 2.0.
The Fitbit Ionic has a steel case and rubberized band. It has a rectangular full-color screen and though it’s similar to the Blaze’s screen, it’s bigger because the bezels are thinner. The Fitbit logo is placed just below the screen. It comes in Charcoal, Blue Gray and Slate Blue. The bands can be changed out, there are leather and plastic strap options.
Some of the features of the watch include battery life that lasts up to four or five days. It is also water resistant up to 50m. It has 2.5GB of space to upload music. There is also a heart rate monitor which is easy to access and gives instant readings on the main display.
The Fitbit Ionic was voluntarily recalled in the United States in March of 2022. "The battery in the Ionic smartwatch can overheat, posing a burn hazard," according to Fitbit.
Specifications
Release date:  August 2017
Dimensions and Weight: 35.99 × 21 × 29.23 mm (1.42 × 0.83 × 1.15 in), 49.89 g (1.76 oz)
Display :
  • Corning Gorilla Glass 3
  • 348 × 250 Pixels, 1.4 Inch, 306 ppi
Body Material: Aluminum
Max Depth of Water Resistance: 164 ft
Protection: 5ATM waterproof
Operating System: Fitbit OS
Processor:
  • Toshiba ARM Cortex M4F 120 MHz, 32 Bit
  • Chipset: TZ1201XBG
RAM and Storage: 2,5 GB internal storage
Battery:
  • Lithium-polymer
  • Magnetic charging
Sensors: 3-axis accelerometer, altimeter, optical heart rate monitor, ambient light sensor
Wireless Interface:
  • Bluetooth, IEEE 802.11b/g/n, NFC
  • GPS and GLONASS
Tracking data: Active time, activity, calories burned, distance, floors climbed, heart rate, pace, sleep activity, sleep stages, steps taken, swim laps
Supported Host Device Platform: Android, Windows Phone, iOS
Additional Information
Tony Sharma
30 Reputatie
0 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 48
Altijd: 27,113
