Ga door naar hoofdinhoud
iPhone 5 Earpiece Speaker Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart en 10 andere bijdragers
Voor het laatst geüpdatet op October 15, 2024
20 - 40 minuten
Gemiddeld
Use this guide to remove the earpiece speaker in your iPhone 5.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. iPhone 5 Earpiece Speaker Replacement, Taping the display glass: stap 1, afbeelding 1 van 3 iPhone 5 Earpiece Speaker Replacement, Taping the display glass: stap 1, afbeelding 2 van 3 iPhone 5 Earpiece Speaker Replacement, Taping the display glass: stap 1, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    Having completed this repair using the rear camera part from Ifixit I have to comment that the camera is noticeably lower quality. Its not huge - You don't notice it looking at the photos scaled down to fit but viewing one for one there is significant detail lost. My staff member has an Iphone 5 bough at exactly the same time as mine so I was able to take a photo side by side on his and mine after my repair and when you view 1 for 1 pixel in product boxes on mine the text was just a colored blur where on his although you couldn't read the text it was more obviously text. Overall though its still better than having a camera that wouldn't focus at all and being that Apple seem to refuse to supply genuine spare parts (Which there has to be a low against??? - Imagine if a car manufacturer did that) its still good buying one from someone who gives good support. At the end of the day its a phone camera not an SLR and its still better than the older Iphone 4 camera.
    matt - Antwoord
    The majority of product manufacturers are not required to provide parts, and apple will fix items under the various warranties it offers. Car manufacturers on the other hand are required to make parts available by law. It is part of the regulation of their industry. They get a lot of protection for their business model, but have some obligations too. It's why the EV1 was pulled, they didn't want to have to make the parts, and why there are so many Delorian parts.
    William Leeper -
    This is a great guide. However, I'm having a hard time popping the screen back into place. Everything works but I'm afraid of putting too much pressure least I crack it again. Any advice?
    amciotola - Antwoord
    To avoid broken screens during reassembling:
    Put the hooks of the screen in the right place in the housing, then close it loose, don't press it. Turn your phone upside down with the screen on a very flat surface (e.g. table). Now press the housing on the screen -> no more risk for braking the screen because of inhomogeneous force applied on the glass!
    mondbewohner -
    I hope folks read this comment before proceeding to attempt a Sleep/Wake button repair on the iPhone 5! Apple has an iPhone 5 Sleep/Wake button replacement program, free, for iPhone 5 devices manufactured through March 2013. See program details at https://www.apple.com/support/iphone5-sl.... Don't do this yourself if you don't need to. It's a difficult repair.
    Mark Luscher - Antwoord
    I was willing to add the following important remark on top of this guide but, strangely, it has been refused! Here it is:
    *Check if your Iphone 5 is eligible to the Apple special program for a free battery replacement (devices sold between September 2012 and January 2013, within a limited serial number range).
    * If not, watch the video and use this guide [video|https://www.youtube.com/watch?v=6ogE8USs...]
    And thus, as my Iphone 5 was eligible, I went to the Apple store of Le Louvre in Paris and the battery has been changed for free instead of 65 euros. Thanks to Mark!
    revher -
    Hi every one i drop my iphone5s 16gb
    I replace 10!new screen but cant back to live i see on the "logic board" where u conect the screen i se damage HOW CANT FIX THAT WHITOUT LOST MA DATA ??? Thaks for anny hellp!!!!!
    aliroberto01 - Antwoord
    Steps 12-15 seem to be not necessary for battery replacement. They are not required to remove and replace the battery and they at least DOUBLE the amount of work. Most of the time spent on this process involved working with those tiny screws and maneuvering them in place and screwing them down. Steps 12-15 are three of the five screws that you work with inside.
    Also, there should be a note at the beginning of Step 2 that if you bought the iFixit kit that you should go directly to Step 6.
    Bob Hatcher - Antwoord
    please wear safety helmet too, integral helmet and cover mouth with an N95 facemask underneath, just in case the battery punctures, explodes, you knock your head back to the wall and slam it back forward hitting the screw in your eye and and inhaling toxic fumes! can never be too careful ;-)
    ibisiki - Antwoord
  2. iPhone 5 Earpiece Speaker Replacement, Remove the Pentalobe screws: stap 2, afbeelding 1 van 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
    I would recommend keeping multiple pieces of double-sided tape for each step that requires removing screws. Also perhaps label them, or take notes, so you know which piece of tape (and the screws attached to it) go with which step number. It's easy to confuse screws, especially if you go past these instructions to remove everything required to replace the ribbon cable that is necessary for the buttons.
    irwin fletcher - Antwoord
    To avoid misplacing screws or other elements, printout the instructions, apply transparent tape onto the print wherever you have colored circles marking different screws. Then, as you start removing screws, tape each one on top of its image on the instructions. At the end, to reinstall everything, proceed from the end of the instructions, removing each taped screw from its image, to return it to its original position. I have done this with many iFixit repair instructions, never losing or misplacing any screw!
    bduault -
    Ordered and received the Phillips #00 Screwdriver ($5.95 · 50+ In stock). It is a tiny Philips screwdriver. The screws next to the lightning port have tiny star-shaped holes. I will have to find a different screwdriver.
    jacklingwood - Antwoord
    Unfortunately, the kit I ordered that was to come with a suction cup didn't include one; thanks for quality control, ifixit. Tape doesn't work. Now what?
    btarver - Antwoord
    I'm sorry to hear that. I have a suction cup being sent out today (Tue 3/11/14) and it will be there tomorrow for you.
    Scott Dingle -
    I've managed to replace the battery successfully in my iPhone5, but something went wrong with a friend's (battery status is stuck, sometimes the phone reboots for no reason).
    So, i decided to open it up again and reseat the ribbon cables in case they came loose.
    I can't open it now. The Pentalobe screwdriver is worn out! I can't open these screws no matter what. I don't know what to do now as I can't be sure I haven't worn out the actual screws themselves, too. Any ideas?
    Saltank - Antwoord
    I seem to be having a similar situation. Attempting to open the phone again and either the pentalobe screws or the screwdriver itself is stripped. Any suggestion is welcome for removing the screws.
    Battery replacement went well and works great. But I must have a loose (hopefully not damaged) display ribbon.
    pwarkolla -
    Saltank, thanks to your comment I didn't overtighten those little screws! I would try to get a better quality driver from a local hardware store to see that helps, the one ifixit sent are not very good quality. If that doesn't work, you may have stripped the screws.
    SMSHAHKHAN -
    Wish I ordered a back case as well with my repair being so easy!
    Daniel Hatton - Antwoord
    my phones screen displays the dead battery sign and the plug below it sign too, when your phones battery is dead. Bought a new battery and charged overnight...... any ideas?
    Steve Freed - Antwoord
    Hi Steve! I'm experiencing the same issue. Were you able to fix it? Please let me know
    Brittany Hutchinson -
    Steve. Please contact me asap re: the issue on your phone. Thank you.
    Now here's an issue that would seem to apply to many users doing this repair: if the screen is nonfunctional, how do you power-off the device? When I dropped my iPhone, the screen went almost completely dark, midnight blue, actually. I can use the power button at the top of the phone to turn the display on and off, but I can't get the phone to power off. Seems the only way to do it is to wait until the battery is exhausted.
    dwhyink - Antwoord
    Protip: take all the soda out of a case of pop and complete the repair in the empty cardboard tray. That way if you drop a screw it won't go flying off the table.
    John Penfold - Antwoord
    Ok, at the end of the repair, I tried to use the new pentalobe screws that came with ifixit replacement battery but they did not seem to fit. So, reverted to the original pentalobe screws for the final step to close up the phone. Beside that, everything went smooth. I also skipped the steps about detaching the frontpanel (seems not necessary if only replacing the battery)
    Srikanth - Antwoord
    Weirdly I had to use two different screw attachments to remove the pentalobe screws so possible they use different screw heads for each one sometimes.
    Sam Ashken - Antwoord
    The “Pentalobe” screws require the STAR DRIVE driver, NOT a Phillips driver.
    Vard Nelson - Antwoord
    I seems the P2 is too big, My Iphone 5 seems to have 0,8 pentalobe screws. I ordered the new battery and your Pro Tech Toolkit and now I find out this bit isn’t in the kit? Am I missing something?
    Naampje - Antwoord
    Hi, i am trying to remove the serews, i have all the tools neded for it but when i try to unscrew them, they turn but they don’t came out, any ideas of what to do? Tank you.
    Joel - Antwoord
    Hi Joel,
    Chances are, the threads may be slightly stripped. You can try to wedge the point of some tweezers behind the screw head to pry the screw out.
    Arthur Shi -
    This was the second repair in the same iphone5. First was the screen, and all the screws came easily. After a year, I wanted to change the battery. From the two Pentalobe screws, one came easy. The other just turn but did not come out. I search and tried to glue the screw with superglue to the screw-driver, but did not work. Finally, I separated the glass from the phone, removed the button, and pushed the screw from inside to outside. It came just enough I could catch it with tweezers and turned meanwhile pulling. Finally came out. I know, not the best solution, but I did not find another way. I put the battery and works.
    daniel - Antwoord
  3. iPhone 5 Earpiece Speaker Replacement, How to prevent display separation: stap 3, afbeelding 1 van 3 iPhone 5 Earpiece Speaker Replacement, How to prevent display separation: stap 3, afbeelding 2 van 3 iPhone 5 Earpiece Speaker Replacement, How to prevent display separation: stap 3, afbeelding 3 van 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone 5 Earpiece Speaker Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 5 Earpiece Speaker Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 5 Earpiece Speaker Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    The iSclack is a marvel. I've had it in my toolkit for a while but this was its first use. I recommend this tool.
    jlwilliams03 - Antwoord
  5. iPhone 5 Earpiece Speaker Replacement: stap 5, afbeelding 1 van 3 iPhone 5 Earpiece Speaker Replacement: stap 5, afbeelding 2 van 3 iPhone 5 Earpiece Speaker Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Step 4 is a bit dangerous, as the Display is pulled out very fast and (depending on the position, the suction cups are placed at) it could stress the cabels connecting display and mainboard. So, please, hold the phone with finger and thumb at the top, to avoid the display is pulled out to fast.
    Guido Dampf - Antwoord
    I sure wish they did a better job showing in the video how hard it is to take of the front screen without the iSclack tool!
    CHRISMIYAMOTO - Antwoord
    I had to position the suction cup _over_ the home button in order to get the screen far enough away from the frame to slide my trim tool in there. Putting it down above the home button just wasn't working at all...
    tparkinson - Antwoord
    Was someone able to answer this question? I have the same issue
    Brittany Hutchinson - Antwoord
    without this suction cup clamp thing, removing (and replacing) the screen was the hardest part of this job. Especially when the screen is cracked badly as the suction cup loses suction due to air leaking through the cracks. In this case, use tape over the screen to create a smooth surface. ***Also, the screens have rubber running along the side, so use a heat gun or hair dryer to make the rubber softer for removal of cracked screen and installation of replacement screen
    fakik0240 - Antwoord
    I am amazed how simple this is and to make a fortune off of. Wish I had thought of it.
    Bigi44
    wayne44 - Antwoord
  6. iPhone 5 Earpiece Speaker Replacement, Manual Opening Procedure: stap 6, afbeelding 1 van 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
    I found it was easier to start opening from the top left of the display and working straight down towards the home button as there are no clips in this particular area. I realize there are cables on the right side right next to the area, however, this way requires less force as a starting point. Let me know what you think.
    boxerbc - Antwoord
    I think that's not a good idea as the top of the display is held in place with plastic tabs.
    If you apply to much force they can break.
    Johnny - Antwoord
    This part was the most frustrating part of the guide, granted I didn't do the whole thing. I was expecting to slip the plastic separator tool in-between the case and the display. This did not happen and I ate away at the tool in the process. For me after much pushing on the top edge of the case and pulling the screen away it released all of a sudden. I managed to make a dead stop at 90 degrees, but felt like I almost ripped off the ribbon cables(I didn't).
    maxturkewitz - Antwoord
    No matter how hard I tried, I could not get the screen to separate far enough to where the pry tool could get it. Reading through some of the other comments, I followed 2 other people's advice to work the bottom left corner above the headphone input and then use a pushpin at the same time. (this is not recommended, but it worked!) I made a couple of hard to see marks in the corner but was finally able to get the screen off. I also did NOT take off the connectors to the screen and skipped the next few steps all the way down to step 14. Looks like a lot of people damaged their phones that disconnected the top screen.
    I'd recommend to use packaging tape to attach the upper edge of the display to the back of the phone so you won't rip off the ribbon cables if the display suddenly comes loose.
    Cupper Chopper - Antwoord
    I took the suction cup off of an old navigation Tom Tom and it worked great!
    fijisomeday - Antwoord
    My battery needed replacement because the battery had swollen and was warping the glass. Looking at it from the side it looks like gasket that was partly sticking to glass and partly to the case. This is actually part of the glass frame and you need to make sure to separate it from the case not the glass. I did it wrong and ended up removing the glass but there was a metal case covering the inside. I eventually got the rest of the top off but now I'll have replace it all because I can't find a good way to glue the glass to plastic.
    Wade Whitaker - Antwoord
    I initially had trouble, but focusing on the area of the faceplate right above the headphone jack worked for me. There's a slight divot that allows you to slip in the prying tool earlier than in other places around the faceplate. Once I got the prying tool in there, I was able to pop out the bottom, and then continue up the sides.
    Stuart Nelson - Antwoord
    IMPORTANT TO NOTE: The top of the screen is attached to delicate cables inside the phone! Pull up carefully and keep a hand on the top of the screen so it doesn't pop up.
    gobluethunder - Antwoord
    My iPhone 5 only had a weak battery. Now it has a cracked glass panel. Suction cup is strong - so strong the glass breaks before the suction cup lets go. Apparently some of the tolerances in Apple's design occasionally add up to make a front panel assembly that refuses to let go. Phone not worth repairing at this point as it only cost $190 refurbished to begin with. A note of warning - you might want to have this done by an experienced tech - go ahead and spend the $100 or so to have someone experience replace the battery and keep the rest of your phone intact.
    Mark Troeller - Antwoord
    The suction cup with the blue plastic handle that came with the kit did not work, but I still had the cup with the silver ring that came with an iPad repair kit and it worked nicely. Also, I found that the guitar style picks that came with the iPad kit worked best for getting the screen started.
    Bill Roughen - Antwoord
    Top center worked for me best (success after 2nd attempt). Near the home button I failed constantly (I have the suction cup with the blue handle).
    Marie - Antwoord
    I also found that a larger suction cup (from a Garmin GPS) which spanned the width of the glass screen worked better than the provided one.
    Robert - Antwoord
    I used a heavy duty iFixIt suction cup (used for repairing an old iMac) for the job. Worked like a charm.
    Olivier Biot - Antwoord
  7. iPhone 5 Earpiece Speaker Replacement, Start lifting the front panel assembly: stap 7, afbeelding 1 van 1
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    The suction cup didn't work, because of my destroyed front glass.
    So i take "tesa powers trips".
    With that help, i had enough force to pull up the front display from the rear case.
    ulrichstumm - Antwoord
    Suction cup didn't work for me. I tried for half hour with my nerd biceps. In the end, I inserted an xacto blade below the home button to create a gap big enough for me to put in a guitar pick and finally able to pry it open. In the process I scratched the frame so you have to be very careful if you decide to take this approach.
    Meng - Antwoord
    Where can you buy "Tesa Powerstrips?
    latraelmayo - Antwoord
    The glass on my phone was completely destroyed, making the suction cup entirely useless. I was pretty close to giving up when i tried putting a strip of clear packing tape on the screen and squishing out all the bubbles. Put the suction cup on this and it worked perfectly.
    chriscopass - Antwoord
    Thank you. I broke the front glass with this technique..
    Olivier S - Antwoord
    Used a suction cup from my Garmin Navi. The one you use to stick it to your windshield. It has a nice plastic "handle" and made things a lot easier... almost too easy that I nearly pulled the screen off the cables. Go easy on this step.
    michaelychien - Antwoord
    I'd Advise Against The Suction Cup Here As It Will Separate The Glass From The Black/White Framing That You're Actually Supposed To Pry Under. I Found When Using The Suction Cup, The Glass Came Up, But The Framing Stayed Stuck. If You're Replacing The Entire Display It's Not As Much Of A Problem, But If You're Installing Any Other Part Or A Custom Housing, You'll Notice Your Screen Has A Bit Of "Play" When Pressing Down.
    Mitch - Antwoord
    While holding down on the lower sides of the iPhone, I found inserting the plastic separator just to the right of the audio jack while gently applying pressure down and back from the edge popped the bottom of the display assembly up. Keep in mind to do this while pulling back on the suction cup ring, like the guide says constant, but gentle force at the same time. Another note is to have the suction cup ring vertical to align with the length of the display, that made the process much easier.
    Canis Lupis - Antwoord
    You rock! I was having trouble getting the thing to budge, but the moment I put the plastic tool near the audio jack, the screen immediately popped up.
    Justin -
    This should be in the guide. The front panel is actually recessed a bit here making it much easier to get a tool in at this point. No way I would have opened it without this tip. Thanks!
    dave -
    Thank you so much! This should DEFINITELY be added to the main guide.
    After struggling for half an hour and nearly giving up, I was able to easily lift up the screen once I tried to wedge it near the headphone jack!
    Thanks so much!
    diegoholt -
    This was the key for me. Thank you so much for this tip :)
    I was having a lot of trouble. Should be in the guide.!!
    Coact -
    Thank you very much, this worked for me!
    gbmattson -
    I've been using a metal flat opening tool along with the suction cup to pop these bad boys open - remember the tape on the screen trick if you have a smashed screen - so the suction cup can grip and stops the glass going everywhere!
    Ben Watkins - Antwoord
    Definitely a difficult step. Make sure not to pry the screen from framing. Also, I kept pushing the power button on while attempting separate the frame. Keep your fingers clear from the top of the phone because having it turn on while the casing is popped is a little nerve racking!
    Andrew - Antwoord
    I had trouble with this step too, since I had to apply quite a lot of force on the suction cup when pulling up on the screen while holding down on the frame with my fingernails. Eventually it popped free, but came almost to 90 degrees before I was able to stop it. No damage, but nerve-wracking, and if there was a better technique, it would be good to figure it out and share the information here.
    Adam Engst - Antwoord
    Be very gentle! I overdid it and, though the repair was successful, there's now a bit of play when pressing on the top right quadrant of the screen.
    plasticpool - Antwoord
    When i was reassembling, the screen broke form the pressure. I recommend putting the screen towards your working surface and press your phone downwards. That way your screen is always straight.
    Kenichi Haramoto - Antwoord
    My front panel flew right off after some puling on the suction cup - no prying was necessary.
    Fortunately, no cables got damaged. Take care.
    Leonid - Antwoord
    I can confirm, the Garmin sucker cup worked like a charm. Within 5 seconds it popped open.
    Nolan - Antwoord
    everything worked but i got a problem i hope anybody can help me very fast !
    when i lift the screen up it just lift the glass up not the whole display ....
    what should i do ??
    thanks in advance
    edis - Antwoord
    Need extra careful while pulling the screen.
    Once there is a gap between the screen and the frame, insert the plastic opening tools and move it around the screen. But don't use it for top area (near to power button) as there is a location for flexible ribbon cable.
    Once the bottom part is free, the screen will pop out easily.
    Ardi Purwalaksana - Antwoord
    Suction cup is very difficult with a cracked screen. Stick something in the ear jack and carefully push it and the edge of the screen will pop up. Use the plastic stick to open it.
    Julie To - Antwoord
    I had trouble opening the screen due to a warped suction cup that was bent up at one spot and also due to my cracked screen. My solution: used double sided tape between the suction cup and the glass. I had some command strips, but I think any double-sided tape could work.
    earthhasassri - Antwoord
    Use needle its a best way
    imran - Antwoord
    I could never even get the case open. Waste of $30.
    dpetronis - Antwoord
    The suction cup will hold if you put a piece of tape over the cracked screen.
    prattdesign1 - Antwoord
    BE VERY, VERY CAREFUL, HERE!!
    -The repair went horribly wrong during this step, for me. I pulled-up on the suction cup, gradually increasing force. Instead of just opening a gap to get the plastic prying tool into, the whole thing gave way at once. This damaged the connection between the display assembly and the rest of the iPhone.
    -During this step, I would recommend placing a rubber band around the phone, over the home button and one near the top of the iPhone for good measure. Even better, invest in the "iSclack". In my case, it would have saved me about fifty bucks and three days without a functional iPhone.
    -When I reassembled, The screen was blank, but I could still sync with iTunes. I may have been able to replace only the cables, but I wasn't sure how extensive the damage was and I was done messing around with it. I replaced the whole display assembly, and now it works just fine.
    -This was STILL cheaper than buying a new phone, and I learned a lot. Overall, it was a good experience.
    peterthemick - Antwoord
    1. This is very difficult, you have to use much more strength than it appears and it's very easy to rip out the connector cords. Mine did not rip, thankfully.
    2. Upon replacing the screen, I had to do this 3 times, I would not recommend putting the screws back in but turning on the phone and testing all screens before putting the panel back.
    3. When I finally managed to ensure all displays were working, I was pushing the screen back in and cracked the glass just below the home button. This part is very sensitive as it is the thinnest portion of the glass so be careful and ensure you push from the top and go all the way around. I also had to do this twice because after cracking the glass on the first try, I also realised the top was not fully pushed back.
    kkwang18 - Antwoord
    We highly recommend using the iSclack tool for opening the phone up. It simply pops it up with very little effort, and you won't risk damaging your screen or device.
    Matt Gordon - Antwoord
    My older phone had a swollen battery, it turns out it had distorted the display assembly enough that the suction cup only separated the screen from the display assembly. Not good.
    robin - Antwoord
    I was in no mood to pay for the special tool and wait for it. Took the "right of headphone jack" suggestion and pushed down vertically at the edge of the frame with a "ice pick" sharp tool, " I had two of them. Who cares if you scratch the frame a little, I usually have my phone in a protective case anyhow. I kept working with this until the corner was up, and then the rest of the display was loose without any further work.
    primaljoy - Antwoord
    My phone is in pristine condition for a 5 year old phone, I have no cracks to speak of on the glass and the suction cup that ifixit sent me doesn't stick to the glass.
    Mary Ellen Cammilleri - Antwoord
    Holding the other side (top of the phone) down with another hand is extremely important. Plenty of people have damaged their screens by pulling the panel right off, ripping all the cables.
    Eugueny Kontsevoy - Antwoord
    I made a series of gentle pulls and the front panel came up without problems. The opening started to appear next to the audio jack, as other people indicated. Then, I used the pry that came with the kit and the panel opened easily.
    Javier Buzzalino - Antwoord
    Upon reassembly, I cracked the glass at this step. The top of the screen seemed to have too play in it and on my phone—I suspect from right side brackets that may have been damaged already. Was nearly finished and applied too much pressure? to the top of the screen area to get it back into position. Snap!
    Robert Innis - Antwoord
    I pulled and pulled on the suction cup with no results then read the comments! Ugh! Found a kiosk at the mall that will replace battery for $15. Should have saved the cost of tools. They were very pretty and well packaged though! Good fortune to all that succeeded.
    Frank Fulchiero - Antwoord
    Suction cup does not work. I also had to use the Garmin suction cup
    K G - Antwoord
    This went easy. Place the opening tool in the seam near the earphone jack to pry as others have stated. Also, as insurance I wrapped a rubber band around the top end of the phone (covering the listening speaker and camera lens) so if the cover suddenly popped open when pulling the suction ring, (which it did!) the cover would not pop entirely off and damage the connector ribbon inside.
    Anthony Baldino - Antwoord
    I used the suction cup that came with the replacement battery kit. It took me quite a while to get the screen loose, but ultimately it came open. They are not kidding when they said this device is tighter that most. I also use the iOpener to get the battery to let go. The iOpener worked like a charm.
    ershler - Antwoord
  8. iPhone 5 Earpiece Speaker Replacement, Detaching the front panel side clips: stap 8, afbeelding 1 van 1
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
    while opening the front panel, i lose control and it gone so fast. And now, after putting it back, the screen is not working. What am I supposed to do? I dont have any other phone in hand and I need to repair it immediately.
    yakbu - Antwoord
    as I wanted to close the display again, the sealing ring wasn't attached to the edge of the glass anymore. did someone have the same issue? thx for help!
    luc - Antwoord
    I didn’t see any side clips! Could they have fallen out previously because my screen was bulging out from the case? Or did I miss them somewhere? I managed to separate the front panel from the body, but there is yet another metallic looking panel on the body. The back of the panel still attached to the front part is mirror shiny on the back of that panel.
    tom - Antwoord
    Hey Tom! Unfortunately you only separated part of the display panel, try to reseat the display and open it again, paying special attention to step 3 which shows you where you should be prying to get those clips on the metal rail out of the phone body.
    Sam Goldheart -
    The thin glass front panel has partially separated from the plastic frame along both sides. Should I try to put a small amount of adhesive to keep it from popping out? It was pushed out by an expanding battery!
    Kevin Knoop - Antwoord
  9. iPhone 5 Earpiece Speaker Replacement, Opening up the phone: stap 9, afbeelding 1 van 3 iPhone 5 Earpiece Speaker Replacement, Opening up the phone: stap 9, afbeelding 2 van 3 iPhone 5 Earpiece Speaker Replacement, Opening up the phone: stap 9, afbeelding 3 van 3
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    When reinserting the screen, be sure to start from the top and insert the plastic tabs on the screen into the case before advancing the rest of the screen into place, finishing at the bottom. The screen will snap into place once lined up to complete the insertion.
    jeff - Antwoord
    This is actually very important, I was having trouble getting the front panel to go on by starting at the top. I started from the bottom instead and the bottom ended up secure, but not the top. I then tried to take the front panel back off, but because the top portion was already loose the force required to pull off the bottom led to one of the ribbon cables at the top of phone breaking.
    jjensik11 -
    When reattaching the screen, please start from the top. BEFORE you try to push the bottom of the screen down and snap it in, use some pressure from the bottom edge to push the screen towards the top of the phone. I suggest that by the time you get to the middle of the phone (starting from the top), you do this. It will allow for getting the clips at the bottom by the sync cable clipped in and will sit nicely and allow for you to use overall pressure to make sure the whole screen is secured. I didn't do this and I damaged the seal on the right side of the phone and almost separated my screen from the digitizer trying to reseparate it to reattach the screen. Be very carefull to follow these steps I listed. If you do this while reattaching the screen, you'll have no problem.
    zhunterzz - Antwoord
    I also agree with it being not necessary to remove the complete front panel. I just kept it attached and kept it at an angle as I pulled with gentle, continuous force (at a 45 degree angle as suggested) on the battery pull tab. It eventually came loose, I set the new battery in and everything works perfectly.
    Jen Robinson - Antwoord
    That's the way I did it too. I put a piece of packing tape from the screen, over the top of the phone, and onto the back. That kept me from putting any pressure on the ribbon cable should the phone slip and the whole screen try to lift away from the backing.
    Ed Chapman -
    Be careful taking the front panel off. I tried to pull it very careful but it ripped. One of the cables was damaged but luckily, it was the cable that goes out with the old front panel. It also ripped 4.1 mm Phillips screw from step 13 and it jumped to the floor. I was lucky and recovered it from the floor.
    In the end everything was fine and phone works great. But remember to be super careful.
    drummerMarkku - Antwoord
    BE VERY CAREFUL!! While trying to open the phone, I was must've tried a little too much and the screen came off in one shot, and it damaged the ribbon cables. Screen didn't turn on, and it cost 100$ to repair. BE VERY CAREFUL.
    Marc - Antwoord
    Hello guys, I would like to first thank iFixit for these amazing repair guides they have always worked for me! Thank you!.
    When reassembling the phone make sure to put the screen from top to bottom, but be aware there are 2 small flaps on the top left side of the screen (you can notice them using another iphone as a flashlight) if you don't put these 2 flaps first then you are going to have a little space between the top part of the screen and the aluminum frame, at least this happened to me and then I inspected the screen using a flashlight and then I found these 2 tiny flaps behind the screen near the top left corner.
    I hope it helps!
    Cesar Valenzuela - Antwoord
    Was it just me or did anyone else discover a ribbon cable (or something like it) on the bottom end of the phone (under the home button)? It kept me from opening the front panel more than 30 degrees or so, making the replacement impossible. Thoughts?
    Curt Jones - Antwoord
    It looks like you might actually have an iPhone 5s, that is probably the Touch ID cable, check out the iPhone 5s Display Assembly replacement here!
    Sam Goldheart -
    Thank you, Sam!
    Curt Jones -
    What the heck only the top part of the lcd came off, NOT together with the shield plate. I used the stupid islack opener but only the very top layer came up. I don't see the battery or anything underneath because the shield plate is still in there. I can't even put it back closed and resuction it open because the shield plate is solidly stuck in and there is a cable at the top not settling properly. I have an open lcd top part of this phone. IDK man, PLEASE ADVISE.
    http://imgur.com/a/Qd8gp
    Gabrielle Rivera - Antwoord
    Hi Gabrielle, sorry you're having trouble! This frame step was meant to show you how to avoid that issue, however, you should be able to use it to pry up the frame and shield plate. You'll need to carefully pry the frame itself up. Insert a thin prying tool between the black or white plastic display frame, and the metal phone case, to lift the frame assembly out of the phone body. If you continue to have trouble, try posting a question in our forum for faster feedback!
    Sam Goldheart -
    Hello, I've changed the earphone piece on my iPhone5 following this guide but I've skipped from step 9 directly to step 17 without problem, just shutting down first. Once opened I've tied the iPhone's body vertically to a small box with an elastic ring, the display assembly resting horizontal at some 90 degrees allows enough place to unscrew and replace the earpiece.
    Cesar Martin - Antwoord
    So easy! My biggest problem is my eyesight. LOL! Had to wear glasses and use a magnifying glass. Battery took about 20 minutes. Re-installing the cover for the screen ribbons was the toughest for me. If you cant see...have someone hold the screen while you gently wrestle the screws, while holding the plate, back in.
    James Bridges - Antwoord
    Worth adding to the main tutorial that the screen re-install must start from the top.
    donaldboscoe - Antwoord
    I found the suction cup to be very effective in removing the front glass. Didn't take that much force to start to see the glass separate from the frame. It's a lot easier if you have a fingernail you can insert when you start to see the glass separate from the frame so that you can let go of the suction cup ring and grab a spudger to pry down one side and then the other.
    Eclectica - Antwoord
    When reassembling, be sure to work from the top down to get the screen display in place. There are three hooks at the top that need to be seated otherwise they will bend and prevent the top from popping in flush.
    Wendy - Antwoord
    Add a rubber band in the picture as mentioned, I couldn’t figure out how it should be positioned, also put in instructions that front panel does not have to be disconnected as I agrree with some of the other comments it is difficult to reattach the plate, although it may be a lot easier to pry the battery out without messing with the vertical top. Otherwise, great instructions, thanks Ifixit,new iPhone battery is wonderful. Bil - 1/16/2018
    William Doherty - Antwoord
    The rubber band and soda can idea for holding the display in place at the proper position as depicted works great!
    Thank you to everyone that has posted comments! It has benefited so many who came after you.
    hipplayer - Antwoord
  10. iPhone 5 Earpiece Speaker Replacement, Removing the battery connector bracket screws: stap 10, afbeelding 1 van 1
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
    When reassembling, note the black jumper cable that runs next to the battery ribbon cable. Sometimes this jumper comes off its little groove and can make seating the battery ribbon cable tricky. The black jumper should travel up that little ramp and then curve to the right.
    DOMINIC INFERRERA - Antwoord
    A note about screw management: ALWAYS remove screws from left to right if you are just putting them in order of removal on a magnetic trey, it helps with re-assembly. If you can, I recommend getting a magnetic white board and writing the size of the screws on it and categorizing by that, it makes it way easier and you won't ever have to worry about putting the wrong size screw in anywhere ever again.
    Addison Rasmussen - Antwoord
    What length are these screws?
    Alberto Anaya - Antwoord
    You actually need a Phillips #0000 not #000.
    Dan - Antwoord
    Same for me for the 1.8mm screw.
    Sam Ashken -
    Any risk if I put wrong screw?
    syidan - Antwoord
    So without ph#0000, i'm screwed, right?
    Osjua Newton - Antwoord
    I managed to remove all the internal screws with PH000 that came with the ifixit battery replacement kit
    Gavin - Antwoord
    It helps if you have fine pointed forceps to remove the thin delicate plate after removing the screws. long pointed forceps also help in placing the screws into their holes when you're putting everything back together at the end.
    Be very careful with the screws. I almost lost one of the battery ones. No replacement screws in the kit. You can buy them on the web, but that takes time.
    I can’t remove these screws with the tools provided. I’m returning this. Useless.
    Dorian Tireli - Antwoord
    ifixit should include replacement screws in the kit. i lost one and the plate is now held with one screw. Also the video leaves ALOT out. Plus no need to take cover off; you can replace battery easily without doing that step.
    josephine ottman - Antwoord
    A 0000 Phillips screwdriver did seem to fit the screw heads better.
    Robert - Antwoord
    I can also confirm that the Phillips 000 that came with the kit did not work on these. I used another screwdriver from a glasses repair kit and that worked great. Seems odd they would include a tool that is unable to remove the battery connector bracket. I would have been up a creek if I didn’t have the right tool already.
    Clay Withrow - Antwoord
    The PH000 worked fine for me.
    Gale Benson, April 28, 2018
    Gale Benson - Antwoord
    The screws have, indeed, Phillips 000 heads. The problem can be that the Phillips 000 driver BIT supplied with the repair kit is of INFERIOR QUALITY! I have extensive experience with Phillips head screws, and no amount of firm pressure and proper driver seating would loosen the screws. I found a micro-tool kit I had for repairing computers, grabbed the Phillips 000 bit, and it worked PERFECTLY! The instructions are pretty good, but the QUALITY of the tools supplied is a real PROBLEM.
    I had this iPhone 5 battery changed previously at the Apple Store Manchester Trafford on opening the front it was clear that the red screw was missing and only the other screw was in place…. presumably an apple store screw up.
    ipodista - Antwoord
    I used the same driver for both screws and it worked perfectly.
    There must be a quality control issue with production of the PH000 bits. This is the third battery I’ve ordered, and I needed another kit because my pentalobe bit was damaged and no longer working. Anyway, the PH000 bit that came with my new kit is significantly larger than the one that came with my original kit and will under no circumstances remove the 1.6 mm screw. I pulled out the old kit, used the smaller PH000 bit and had absolutely no problem removing the screw. That would explain why some people are having zero issue with the screw and others are unable to remove it.
    Charles Czuhajewski - Antwoord
    I noticed the 1.8mm screw had a slightly larger diameter than the 1.6mm screw. This may help if you (or I) get it mixed up during reassembly.
    Shannon B - Antwoord
  11. iPhone 5 Earpiece Speaker Replacement, Removing the battery connector bracket: stap 11, afbeelding 1 van 1
    • Remove the metal battery connector bracket from the iPhone.
    When I did this strep the battery connector (step 12) came with it. There seemed to be a bit of adhesive but it wasn't hard to separate them after the fact.
    davidmeyers - Antwoord
    Note the long, thin forceps in the photo. These aren't included in every vendor's tool set that ships with the replacement battery and I found it a necessary tool not only for removing this particular plate, but also for positioning the screws back into their holes when you're putting the thing back together. If your replacement kit doesn't include that tool, they're only a couple of bucks and you can get them at any computer geek shop like Micro Center.
    When removing the connector bracket note that there is a small square black barrier pad on the undersurface of the bracket at the lower screw location. I suspect this is to prevent the metal bracket from touching the material below it. So, ensure when reinstalling the bracket that you reinstall the pad also.
    Also need to remove the plate covering the speaker module connector. It’s next to the battery connector cover, they share a screw.
    Stace Long - Antwoord
  12. iPhone 5 Earpiece Speaker Replacement, Disconnecting the battery connector: stap 12, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    Oh my God.
    When prying, make sure you do it from the TOP or far TOP RIGHT corner using ONLY a spudger, and NOT like it is shown here on the picture.
    There is a component next to the battery connector that is easily torn off the board if you're not careful. It's a common mistake made by somebody who have never done the repair before. This will make it so the phone looks like it's charging but only ever discharges. The component is the filter for the gas gauge line which is directly to the right of the battery connector and is extremely hard to see. They look like a tiny-tiny silver cylinders and you would need a microscope to actually be able to distinguish them.
    Hope this helps.
    Haytham Alexander - Antwoord
    HEED THIS WARNING!!!! Not doing so failed my entire repair. When I looked with an eye loupe, I could see one of these components by the connector had been knocked loose after I removed the connector. Pry from the top ot the connector or top right corner only.
    Rob Miller -
    The replacement battery out of the ifixit box: The connector may not fit immediately to the contact on the logic board. I needed to bend the stiff (metal-like?) cable quite a bit to find a shape of the cable that allows the connector to fit to the contact.
    Salta SMR SAS - Antwoord
    Ditto the comments by Salta. I compared the iFixit battery cable to the battery cable of the one I had removed and found that I needed to kind of crimp the cable a bit where it needs to fit between the battery and the connector. It's all quite stiff. Make sure the connector snaps into place!
    Re-attaching the battery connector was tricky. Make sure you align the pins well. Otherwise you may bend them and that could be a big problem.
    Why do I need to take the battery out? I replaced battery a few weeks ago and it seemed no need to disconnect the screen as well.
    They seem recommending taking out connections more than necessary. Anyone let me know why leaving the battery there would make a problem for replacing the screen.
    kimgcp08 - Antwoord
  13. iPhone 5 Earpiece Speaker Replacement, Removing the front panel assembly cable bracket screws: stap 13, afbeelding 1 van 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
    Anyone have any idea why the 1.6mm screw is not magnetic? Just wondering why this screw seems to be made of aluminum, its the first screw of its kind as far as iphones go.
    crevz - Antwoord
    The compass is right next to it.
    Tom Chai -
    I'd recommend if they made that clearer in the guide, luckily I put them back in right, its the one with the little bit of blue on it if i recall that isn't magnetic
    Matt -
    is it necessary to disconnect the front panel assembly cables fore removing the battery ?
    or can you leave it on wile replacing the battery ?
    aardappel - Antwoord
    I just finished this process using the battery replacement kit from ifixit and it went easily. I did NOT remove the entire screen but rather just had someone hold it at less than a 90 degree angle until I got the battery out. I found it took a while to slowly pry the battery out. Take your time and alternate between gently using the plastic tool and pulling on the plastic pull tab that says "for authorized use only" or something like that. It was MUCH easier than disconnecting the entire screen for the process. Hope this helps.
    david -
    Rule #1 on electronics repair methodology: to prevent damage to the electronics, power should be the first thing to be removed and the last to be restored. I'd disconnect the battery before touching anything else, a slip of the screwdriver or a loose screw could cause a fatal short circuit.
    andrewcilia - Antwoord
    It's no need to remove front panel to change battery. I just skip to Step 10 and successfully changed battery, and it works well. And THANKS TO ifixit.com, IT IS AWESOME!
    sorrowboy - Antwoord
    I skipped steps 6-9. leaving the screen attached to the phone makes it that much easier and quicker to repair
    Frank - Antwoord
    Mon téléphone a pris l'humidité et présente un fond d'écran d'aspect granuleux. Du coup l'éclairage n'est plus uniforme, nuisible pour une bonne lecture de l'écran.
    J'ai démonté l'écran, une pellicule grasse et collante entre le LCD et la plaque métallique. J'ai nettoyé à l'alcool. Tout remonter avec la crainte que le téléphone ne fonctionne plus.
    Le téléphone s'est rallumé, tout fonctionne normalement mais j'ai toujours ses traces sur le fond d'écran. Il faut le changer!
    Mes difficultés étaient de remettre les petites vis aimantés, difficiles à remettre!
    Merci à IFIXIT pour ce tutoriel très explicite.
    Patrick Rosa, june 23 2014
    pkrosa - Antwoord
    So, of COURSE I dropped the screw that you are not supposed to lose. I was being careful, but as I did not want to lose track of it, I attempted to put it back ing the phone FIRST. Bad idea. This makes the plate kind of springy, and my screwdirver slipped, and the screw popped up, spun in the air, fell between my legs, bounced off my padded chair, and clattered around on the floor. I searched for an hour, and could not locate it. BE IT KNOWN, at least in MY CASE, the screw WAS INDEED attracted to my magnet (I keep a powerful round magnet stuck to the shaft of my drivers to provite the magnetism, far more powerful than a regular magnetic screwdriver. This being the case, I WAS able to provide a substitute fron a bag of iphone 4 screws, and my compass calibrated flawlessly upon power-up. YOUR MILEAGE MAY VARY, but I thought I'd add my experience.
    stevesontheroad - Antwoord
    Be warned, the 1.6mm screw is exceptionally easy to strip. I haven't been able to get it out yet (already tried rubber band trick and a few others) and am on the verge of giving up. The #00 screwdriver that comes with the set did not do a very good job of catching.
    joseparra947 - Antwoord
    Were you ever able to get it out? Mine seemed stripped from the get go, rendering my attempt to troubleshoot my blank screen fruitless. Rubber band, glue, flat-head all did not work for me. Buying a soldering iron tomorrow to try that.
    randypalmerjr -
    I did the repair without disconnecting the screen. I skipped down to step 13 and carefully held the screen while removing the battery. Adds a small element difficulty, but helps prevent all the issues others are having when reconnecting the screen.
    The non-magnetized screw was very difficult to install. This is how I ultimately succeeded:
    Install the two magnetized screws first. They are easy because the magnetized screws will stick to then end of the screwdriver. They will hold the cable bracket in place.
    Place the third, non-magnetized, screw on the center of the cable bracket. Take a toothpick and nudge the screw toward the screw hole. The threaded part of the screw (the shaft) has enough weight that it will fall into the hole, and the head of the screw will be pointed upward. You will then be able to use the screwdriver.
    alsmith1928 - Antwoord
    Put a piece of tape on the table sticky side up. Set the screw on the tape head down. lift the tape and guide the screw in place. drive the head of your screw driver through the tape and tighten screw. lift off tape. throw away. :)
    rdgentry -
    The tape trick works well. Another way is to dip the screwdriver in alcohol (isopropanol, do NOT use water) and put the screw on its tip. It will be held there until the liquid is evaporated, which should be sufficient to put it in place.
    Kater_S -
    One of the screw is completely stuck and I cannot remove it! What can I do?
    stefanoclearmounth - Antwoord
    When putting it back together, I replugged in all three of the ribbon cables and powered on the phone to test before putting everything back together. All was OK except for the Home button, it had no effect when pressed. I ended up unplugging and replugging the 3 ribbon cables a few times and retrying. I then cleaned the connectors using a can of compressed air, screwed the little silver cover back on and snapped the whole phone back together, hoping everything would be fine. It was. I don't know if the problem was a dirty connector, or if you need to close the phone to make the home button work again.
    I recommend wiping the plastic prying tool after lifting the screen off, it gets dirty from the gunk build up and some of that could eventually fall inside the phone.
    My battery was really stuck, so much that the plastic tab broke when pulling. I followed someones advice to heat the back of the phone with a hair dryer, still wasn't super easy but I managed to get the battery out, only deforming it slightly.
    grosstua - Antwoord
    The contacts for the home button are on the phone base so the screen needs to be in place for the button to work..
    Liam Carson -
    Step 9-12 are totally unnecessary unless you need to replace a broken screen. All you need is to keep the front panel in a vertical position once the front is open. The battery can be removed without taken out the 3 connectors which by the way the screws are very very tiny and difficult to put back.
    rich1812 - Antwoord
    I completely agree. These are unnecessary steps. Might be a little easier to pry the battery out with the display completely off, but not enough to make it worthwhile IMHO.
    davidmeyers -
    Is the 1.2mm a #000 or #0000? I have a small set and can't get one of these out. The instructions say a 1.2mm, the tools list shows #000, but my set says #000 = 1.5mm.
    Kevin - Antwoord
    1.2 mm refers to the length of the screw (from head to end), the screw head size is compatible with a Phillips #000 driver. So as long as you have a #000 you should be set! Good luck =)
    Sam Goldheart -
    Invest in and use some colored Sharpie Pens... I color the tops of the screws orange and red etc. to match the colors of the circles in this guide. Then when I go to put them back in there's no doubt as to which screw is the correct size.
    Pete H - Antwoord
    What an idea, lol.
    bigfnevil -
    frustrated...screws to battery holder is stripped, now what?
    Martin Gonzalez - Antwoord
    Maybe a small amount of loctite. I noticed the P2 screws holding the display down had a small amount on my iPhone 5.
    Steve Heigh -
    Como se ha comentado más arriba, no es necesario desmontar la pantalla, yo he sustituido la batería aplicando calor con el iOpener y siguiendo atentamente la guía. Resultado óptimo.
    Yes, right! I, too, do not see the need to remove the LCD display at all; except, when one is replacing a broken display. The battery is ready for replacement once you had removed its bracket.
    valuesphilippines - Antwoord
    I found that it wasn't at all necessary to remove the front glass. I did need to use a hair dryer to soften the glue holding the battery, but I simply laid the phone down on the face glass and blew the hot dryer on the back for a couple of minutes at almost point blank range. Then I simply held the phone open with one hand, making sure the front glass never went back more than about 80 degrees (no need to stretch it all the way to 90 degrees), and used my other hand to work the spudger around the battery, making sure not to touch any delicate electronics in the area. The top right corner gave away first and then I worked it down from there and the battery came out pretty easily. The trick is to use the hair dryer for a few minutes beyond the phone being too hot to hold in your hand! (you might need to use a towel to pick it up when you pry the battery out.)
    The battery of my 2012 iPhone 5 was working well but started to inflate pushing the front panel assembly out from the case. Replacing is faster and easier than on iPhone 5s. No need to remove the front panel completely, just holdig it at near 90º is enough but needed to warm the case to soften the battery glue. Thanks to iFixit for this guides and you guys for your comments.
    As other people already indicated, steps 13 to 16 are not needed and risky. I asked another person to hold the front panel at 70 degrees while changing the battery.
    I rushed in and did steps 13 to 16 without reading the warning. There were some unexpected events that happen. The short version of this story is my screen comes up with funny looking grey squares but phone is still usable. I don’t care as my main phone is an iPhone SE and I bought the battery as a learning exercise. Plus iOS 11 doesn’t install on an iPhone 5 so it’s days are numbered as a productivity tool.
    Long version. Dissemble was easy. I made sure I had used the phone so the battery was warmed up . First problem with reassembly is in step 13 the bottom most 1.2mm wasn’t biting and screwing in. So it looked like the top of the hole got threaded. Also a screw fell out of what I think is the loud speaker. That was unexpected. This iPhone 5 isn’t my original, it was a replacement phone that came in a white phone that the Apple Store gave me when my original phone from 2012 had 2 recalls on it. So I strongly suspect this is a factory refurbished phone and not 100% mint off the line.
    Ignatius Tse - Antwoord
    I found I didn’t need to remove the front panel at all so I skipped this step 13 through step 16. These steps seem to add potential problems.
    Incredibly helpful tips & comments. Very grateful, thanks!
    Jay - Antwoord
  14. iPhone 5 Earpiece Speaker Replacement, Removing the front panel assembly cable bracket: stap 14, afbeelding 1 van 2 iPhone 5 Earpiece Speaker Replacement, Removing the front panel assembly cable bracket: stap 14, afbeelding 2 van 2
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
    My iPhone 5 (1428) model don't has this bracket and replacing the earpiece don't fix my problem (don't hear anyone).
    plyhell - Antwoord
    You might check that front camera flex cable.there can be a damage also where war speaker connects
    Vinayak Devadiya -
    Great Guide, Any idea what else could be wrong if Ive replaced the screen with a working 1 and the phone still has no display?
    Thanks for any insight in advance.
    Raistlin - Antwoord
    When you reverse step 7, make sure you clip the little hooks of the bracket under and then lower towards the outside of the phone. If you don't, the phone won't snap back together properly.
    Dirk - Antwoord
    I've misplaced this metal plate AND the three screws and two pentalobe screws. I think my wife threw out the ziplock I had them in. Any chance you can tell me where to get them? thx
    Don - Antwoord
    Don't forget to clip this in flush, my phone couldn't get a cell signal when it was slightly out-of-place.
    julian - Antwoord
    Remember to put this plate back such that it's sitting evenly. The side towards the battery some times tends to stick up a bit, this in turn will put pressure on the backplate of the screen. After putting everything back together, you see a small yellow smear just to the left of the battery % indicator, you have not put that plate on correctly. Open up the phone, remove that retention plate and put it back such that it sits properly!
    AGS - Antwoord
    Opened my iPhone 5 etc. When reassembling, I notice the screen doesn't stay clipped into the back tray and is raised a couple of mils.
    There is also a new brighter spot on the screen. Any ideas anyone?
    Ian Campbell -
    I really wonder about the wisdom, and risk, of removing this upper plate in step 14 - unless I missed it, those three cables are NOT connected to the battery in anyway - and the chances for stuffing up said cables re-assembly are moderate to high! I can see that one would have to be careful taking that bracket and disconnecting those three cables ( I certainly was), but it looks to me like there's a case for just undoing the battery bracket & screws and carefully - very carefully - with great patience and some good spudgers, esp the black ones we use in desktop iMacs, - flat one end; pointy the other - plus the usual blue plastic ones and even a guitar pick - prying the battery out from its hideyhole! Much less stress regarding the upper bracket and the three cables while only a bit more stress over releasing the battery from its sticky grip! Anywho, I might have to stand corrected - but next time I'll go for this abreviated method. :)
    amicuset - Antwoord
    please do not do this part....after you remove the bracket over the battery don't mess with the 3 cables at the top or remove its bracket. Just carefully remove the battery and insert the new one. the idea of using the rubber band helped a lot with the entire procedure and i did it in one very easily. thank you ifixit and most importantly the comments. Make sure to read all the comments before doing each step even when you r reassembling.
    Anderson Ashby - Antwoord
    I confirm the previous post! It’s the third times I change the battery and I just realize this time that it’s completely useless to remove the front panel. You just have to be careful if it’s your first battery change because the original one is strongly sticked on the board. Don’t be brutal! Proceed slowly.
    I think that lots of problem may occur when you reassemble the front panel cables. So just don’t disconnect them !
    Ifixit is great. The comments are usefull too.
    jproubin - Antwoord
    I also made the mistake of trying to remove the cable bracket. Once again I had to resort to another screwdriver since the included 000 in the battery kit did not work on these. But once I got the three screws removed I noticed the bracket’s top corner (near the top of the unit) was stuck even when I properly pulled the bracket back to unhook the lip from the logic board. I tried pulling it free every which way but nothing seemed to work so that’s when I checked the comments here and realized I shouldn’t have even bothered trying to remove it.
    Can I leave the bracket out? Does it have any shielding or antenna function? It’s hard enough to get the replacement screen in without it…
    Andi - Antwoord
    I agree, it is not necessary to remove this cover or the cables underneath. nothing is covering the battery so just pry it out. I had the battery changed in less than 10 minutes.
    chriswood - Antwoord
  15. iPhone 5 Earpiece Speaker Replacement, Disconnecting the front panel assembly cables: stap 15, afbeelding 1 van 3 iPhone 5 Earpiece Speaker Replacement, Disconnecting the front panel assembly cables: stap 15, afbeelding 2 van 3 iPhone 5 Earpiece Speaker Replacement, Disconnecting the front panel assembly cables: stap 15, afbeelding 3 van 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
    The part itfixit sent only has two cables: the digitizer and LCD are combined into a single cable. (And the guide is great! Thanks!)
    baileyswanson - Antwoord
    After replacing the screen I was presented with a no image screen (but backlight was ok), so I refited the shartered one, same issue, no image, but backlight. thinking I might damage the pcb, I just did a power cycle (disconnecting the battery) and now it's fine.
    so... always powercycle :)
    poseido - Antwoord
    Be very careful here, at this point the phone power is live! a slip of the connectors or a loose screw could let the magic smoke out of the chips (chips won't work without their magic smoke, you know :-)
    I'd disconnect the battery before messing with the connectors.
    This is a troublesome step, since the LCD connector is particularly difficult to reconnect, and know that you've gotten it on. And thanks to the note claiming that if it's disconnected, if you might just get a black screen, you're left with having to disassemble the entire unit again, without knowing if it's powered off (since you presumably tried to power on). That's also nerve-wracking. I had this problem and disassembled and reassembled the entire phone, only to have the problem again. On the second try, I plugged the phone into power, and after a little bit, got the dead battery screen showing. So the problem was that the battery was discharged, not that I'd biffed the LCD connector.
    A tip for knowing when your device is powered:
    Activate VoiceOver before you start. this can give you audio clues with the volume control.
    I did not do it on purpose, but it saved me, because I got the black screen.
    I also had to re-insert the display cable for like 3 to 4 times until it worked for me.
    (Note: Check if the display port cover is hinged on the battery side, otherwise there will be room for the connectors to come loose.)
    Eric Nöske -
    The hint to disconnect the battery was very useful for my successful repair. After rebooting the phone everything was working just fine. Thanks!
    Benjamin Richter - Antwoord
    BE CAREFUL HERE.
    Take a good look at that camera loosely sitting there. It is possible that it will be slightly offset when shutting the assembly back into place. This causes it to not properly focus on closeups. If you don't move it around you will probably be okay.
    Also, look at the display assembly, it has three small locking tabs that can bend easily if not pushed in at the right angle into the iPhone frame. Be careful not to be too forceful. Good luck.
    info - Antwoord
    I am having issues removing the white lines on my screen. I made sure to connect the digitiizer connector was seated all the way and I also power cycled my phone several times. Anyone else having this issue?
    eric51redding - Antwoord
    If your lcd is properly fine then it can be a LCD Ic issue on pcb
    Vinayak Devadiya -
    When I was reassembling this the front facing camera cable was a bit longer than the previous one. I had to kink the ribbon cable a bit to get the connection to line up. Everything seems to be working but I wanted to note that the part might be slightly off spec.
    Aaron Martina - Antwoord
    I am very satisfied with the replacement display assembly (including FaceTime camera and Home button) iFixit sent. It arrived a day early, fit perfectly, and has fixed the color banding, cracked screen, and scratched edges very well. In addition, the home button now has a much crisper "click" to it, more like the new MacBook's keys vs those of an older MacBook Pro.
    Nathan Jones - Antwoord
    This step is not needed to remove the battery and complicates the process by having to reconnect the sensors.
    nicholaskan - Antwoord
    if my lcd metal plate is scratched can i replace it to remove the lines or do i need a new lcd
    brittany stapleton - Antwoord
    When I started the phone again, there was a grid pattern and touch was not working consistently. It turns out there were two separate problems. (1) We had over-handled the cables and a quick swab of alcohol helped remove the oil from the connections. (2) The first connection is really tricky to get right and comes undone easily during the final reassembly.
    Jeannie Crowley - Antwoord
    I had this problem too (not the oil though). When I first restarted the phone, I had white crosses over the display, and the digitiser didn't work. The only way to shut down the phone was to hold the home key & power key for 8 seconds until the display went black. Reseating the LCD & Digitiser connectors, and power cycling by reconnecting the battery fixed the problem. Hope this info helps others.
    Tom Hannen -
    In the image you can see the camera has lifted out a bit. Mine did this too, because the old screen had levered it out. To push the camera back into position you need to insert a fine tool behind a small metal spring contact because it catches on the camera's casing otherwise. This little spring is to the left of the metal case, between the camera and ribbon.
    pauldevans - Antwoord
    Great pics too. Pls confirm if the three photos in Step 15 only show removal of 2 of the 3 connectors mentioned in the instruction (and colored bullets). I could not tell which was the third one to remove in the three photos. Thanks!
    gandarlmg - Antwoord
    So I keep getting the "white lines on the LCD" bit with no resolution. I've tried reconnecting the connector like 6 times and power cycling and I get the exact same thing every time? Is it possible that the replacement screen has an issue?
    Jared Spencer - Antwoord
    May I ask what the 4th little connector is that comes from under your battery and connects to the board mine came undone during repair and won't go back in
    Cameron - Antwoord
    Watch the soft pad between the rear camera enclosing and the top side of the frame, especially when reassembling. After replacing the battery, my camera pictures gradually showed lots of dust spots. I opened the device again and discovered that the pad had been displaced. However, I am not fully sure if that is the reason for the spots.
    Kater_S - Antwoord
    On reinstall, I can't get the connectors to line up and the replacement screen has 3 connectors where as my busted screen had only 2. The cables on the replacement screen are too short? Is that even possible?
    maryann miller - Antwoord
    I’d say removing the screen is BS. I realized that I didn’t have to remove my screen cable as I was able to flip the screen vertically while I take the battery out. Removing the screen cables causes more problems- you may end up with white squares on the top of the screen which seem to expand over time. Also it is very easy to bend little metal legs on the socket when prying the connector.
    kimgcp08 - Antwoord
    totally agree, no need to remove the screen. It means you will have to do everything with only one hand (the other one is holding the screen), but you skip so many steps that overall it’s well worth it.
    Metafisco Parapensante -
    It is very important to make sure the cables are fully seated. When I finish assembling the phone I too had a vertical white stripe on the display. I disassembled the phone and reconnected the cables very carefully, and also made sure the shield was properly seated. When I turned the phone back on I found a very faint white line, but after doing a power cycle it disappeared to my great relief. Also, I would definitely recommend removing the display because it’s so hard to get the battery out you don’t need the extra risk of damaging the display.
    After replacing a friend’s iPhone 5’s rear camera and reassembling their phone the screen displays verticle black lines on the right side now like this: http://i1091.photobucket.com/albums/i393...
    Anyone else have this problem? I didn’t think about cleaning the display connectors with alcohol at the time.
    Ken Shimabukuro - Antwoord
    Also, when the battery was too low and before the display produced vertical lines the display showed half of a low battery symbol:
    Like the right side of the display was blank.
    Ken Shimabukuro -
    On reinstalling the front panel assembly, I had a difficult time lining up the digitizer cable. After struggling with it for a while, I noticed that the plastic shoulders of the small mounting bracket at the ends of the pins had become rounded over. After cleaning these up with a razor blade, everything slid together perfectly. Thanks so much for these guides and all the helpful comments!
    Dave Martin - Antwoord
    I have done all these operations 6 times to get back a good displaying. The last was the last: nothing on the screen now. It is now black, no sound, no vibration, BUT the iPhone show up in iTunes O.O
    iTunes asked me to update the iOS to 10.3.3 but it’s already done. I clicked OK but nothing more. Still black and quiet.
    The new battery is 100% charged.
    What is my problem, please help :-(
    franck.bremeault - Antwoord
    I found the part who was deffective: the connector of the screen has broken due to too much movements. :-( Screen is perfect and clean but dead.
    franck.bremeault -
  16. iPhone 5 Earpiece Speaker Replacement, Separating front panel assembly and rear case: stap 16, afbeelding 1 van 1
    • Remove the front panel assembly from the rear case.
    My display was not turning on and my home button was not working (I verified this by trying to activate siri which didn't work). When I replaced the display assembly everything works except for the home button. Since this assembly comes with the button and the ribbon cable, I'm not sure what else can be wrong. I checked the contacts on the phone and I see the little copper 'pins' sticking out. I can't tell if they are making contact since the display has to be closed, but it appears they are lined up correctly. Does anyone have any suggestions or ways to test the contact pins? Could the home button on my replacement be defective? I've already emailed support, but just curious if anyone has any suggestions I could try while waiting to hear back from them. Thanks! By the way, SUPER grateful the rest of the display works. I can now back up my phone and can probably deal with a broken home button if I need to. Woohoo!
    jhagerman - Antwoord
    I'm having issues where the screen jumps around when you get a finger near it. I'm reading it might be grounding but no idea where any tape could be applied. Replaced the screen twice thinking it was a bad part. Now, I just don't know.
    Ana Van Meter - Antwoord
    My front camera does not work. I took apart and ensured the connection several, several , several times.... no front camera... anyone else have this issue?
    Patricia Young - Antwoord
    Try replacing the camera and flex assembly.
    Greg M -
    No info on removing the home button?
    T S - Antwoord
    Unless I missed something, the cover removal where the replacement module plugs into the board was not mentioned No big though.
  17. iPhone 5 Earpiece Speaker Replacement, Earpiece Speaker: stap 17, afbeelding 1 van 1
    • Remove two screws securing the front-facing camera bracket to the display assembly.
    • One 4.1 mm Phillips screw
    • One 2.2 mm Phillips screw
    I just replaced mine on 10/6/13. WARNING: the black plastic spacer for the upper screw could come loose when taking the bracket off. Be very careful.
    cappich - Antwoord
    Can anybody measure the spacer height for me? I have the phone where it is missing. I have even been to service place to ask for it, and they claim there is absolutely no other small part under earpiece speaker. I guess I'll have to make some replacement from hard plastic. I can't seem to find it in any online store.
    Adam -
    You can find it on eBay. It is sold along with the two clear plastic pieces.
    Greg M -
    The 4.1 mm screw has a blue line on it. This may help with organization.
    Timmy McInerney - Antwoord
    reassembling the upper screw ( i guess i fastened it too tight) i ripped off its base on display plate… there was no spacer maybe because of a previous repair.
    Emanuele Carucci - Antwoord
  18. iPhone 5 Earpiece Speaker Replacement: stap 18, afbeelding 1 van 2 iPhone 5 Earpiece Speaker Replacement: stap 18, afbeelding 2 van 2
    • Remove the earpiece speaker bracket from the display assembly.
    There is a tiny black plastic spacer under the top screw, be sure not to lose this. It is easier to reinstall it after all of the parts have been transferred to the new screen including the front facing camera assembly. The spacer has a small cutout in it, which is positioned to the left side. Put this spacer in as the last step before reinstalling the metal speaker bracket, otherwise you risk losing it moving the screen around reattaching all the parts to the new screen.
    crevz - Antwoord
    Hello, Do you have a photo of this as I'm still unsure to where it goes.
    Thank You
    Jordan Baker -
    ehm, you can leave that out just fine
    Fixandinstall -
    One additional note to the above comment, the gap in the little spacer goes on the left, but the flat side of the spacer goes on top. Took me a few minutes to figure out that orientation.
    vhfreak - Antwoord
    what happens if i lost the small plastic spacer? and where can i buy it? ty
    HandyGarage - Antwoord
    Same here and could not find answers. Basically without this wicked little plastic bastard I can only make calls via headphones? What a faulty design.... Maybe loosening the screws can help? Or using something plastic or paper on that place with similar size?
    More annoying than soldered parts I swear...
    szikszai70 -
  19. iPhone 5 Earpiece Speaker Replacement: stap 19, afbeelding 1 van 1
    • Remove the earpiece speaker from the iPhone.
    There a small square black plastic "gasket" next to the 2 copper contact points. Be sure it is back in place before putting back the screws holding the earpiece speaker in place.
    Rany - Antwoord
    It is a site of iPhone 5 Earpiece Speaker Replacement .I have visit the site Its photos are very nice and relevant like a site <a href="http://www.reasonablegifts.com/">Iphone 5 cases</a>
    Lee Ratliff - Antwoord
    Took about 2 hrs to finish. First I left the red film on after placing the LCD plate. I unscrewed and took the film off. The tough part was placing the front camera and earpiece speaker. It took me sometime to understand that one of the cables fold to sit in its position. Tested the camera and phone call. All seems to be working fine.
    sathyajsn - Antwoord
    I torn (ripped ) my earpiece speaker contacts ( two metal dot ) , how can I repair them ? Thanks
    bulentkucuk - Antwoord
    You will need to replace the flex assembly.
    Greg M -
  20. iPhone 5 Earpiece Speaker Replacement: stap 20, afbeelding 1 van 1
    • There is a small, black plastic spacer underneath the metal bracket at the upper screw. The upper screw goes through the metal bracket then through this plastic spacer.
    Use a hair-dryer on low heat to loosen the glue around the speaker cover. Also, don't forget the small clear plastic holder for the camera
    Tady Walsh - Antwoord
    This should really come after Step 16
    Drew18 - Antwoord
    This seems to be in the wrong order. The picture shows parts removed that are instructed to be removed in later steps.
    Kenny Evitt - Antwoord
    I don't know what's going on here. First, it seems like this instruction is in the wrong place -- it should be a few steps later. Second, the phone I was working on did NOT have the piece described. I don't know if that means that the phone was screwed up before I got it apart, or whether there was some change to the design to the iPhone that some models have this piece separate, and some models don't. As far as I can tell, the proximity sensor works after reassembly.
    Adam Goldberg - Antwoord
    I replaced my battery and ever since then my front facing camera does not work and after a while my back camera is not working nethier does the microphone where I hear people talk on the phone why is this please help
    Kulli Kalervo - Antwoord
    When replacing the battery, be careful not to open the LCD more than 90 degrees. You may have damaged a flex cable assembly or possibly the connector may not be seated correctly, although unless you removed the connector cover, that is unlikely. Or if you had to pry the battery out, you may have damaged something else. Since the cameras are on different connectors it doesn't sound like something simple.
    Greg M -
    This step should be after step 20. It is fitted under the earpiece speaker,
    Herbert Schröder - Antwoord
    I believe you (and the other commenters who pointed this out) are correct! I went ahead and shuffled the order of the steps. Thanks for the heads-up.
    Jeff Suovanen -
    I agree with you guys. This step should be after the camera and sensor cable are removed. It's much easier to get at. Cheers fellow fixit's
    Wayne Lyell - Antwoord
    did you sell the plastic spacer ? if yes, how much?
    Hrahmi - Antwoord
    you can also see the front facing camera soccer/positioning piece of plastic (clear plastic circle) this needs to be removed also and placed into the new display.
    laptop - Antwoord
    Be VERY careful with this spacer! When i picked it up with the tweezers to put it back in, it shot out of the tweezers! I finally found it - but it was a tense half hour!!!
    Theresa Biggs Greenan - Antwoord
    “The upper screw goes through the metal bracket then through this plastic spacer.”
    doesn’t the screw go first through the shield, then the speaker, then the spacer then the bracket? The wording here is confusing.
    garegin - Antwoord
Conclusie
200 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
508.952 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.577 handleidingen geschreven
9 opmerkingen
Hello folks,
my iPhone stopped working, diagnostic as follow:
Need to switch to speaker or use headphones to call, since caller can hear me, but I cant.
Please tell me that its not a chip failure.
thx :)
umweltverschmutzer - Antwoord
I decided to examine the problem before ordering the new earpiece speaker, so performed the disassembly first. At Step 13, I found that one of the two screws holding the bracket was already completely loose. Everything else checked out visually (the spilled wine that I'd worried about was nowhere to be seen), so I reassembled. Bam! Working just fine, no new part needed.
gregoryhayes - Antwoord
worked for me also. issue was that the 2 gold coils on the back of the ear-piece (which you will see after you disassemble parts) were contracted. Simply extended them out a little by pulling with gentle force, this will re-enable them to earth properly against the gold plates.
GH Sales -
Also worked for me. iPhone 5C, 2 years old, ear speaker stopped working.
Like GH Sales all that was required was pulling on the two gold springs on the back of the earpiece speaker. This fixed the speaker problem for me.
Jakub -
Had the same issue, what GH Sales did worked for me!
Angela Penaherrera -
ordered the parts with a new battery, new set of screws and a new ear piece... battery is fine but earpiece still doesn't work...
dechdez - Antwoord
I replaced it with a new speaker, but despite this I still hear very low, I add that before the issue I had also changed the flat proximity sensor with the circuit and the front camera, could be this the problem?
Andrea Sgambato - Antwoord
Hello, I had replaced my earpiece speaker half a year ago at a repair store, then it seemed to work again but a day later it stopped working again. They told me it wasnt their fault because it worked yesterday. So i got basically nothing for my €39. Before then en after it got replaced I always used earpods or the bottom speaker, but i was quite fed up with the fact i have to make phonecalls this way. So I ordered a repait kit with a new earpiece speaker (The previous speaker came from another broken iphone 5) and repaired it myself accordingly. But it still doensnt work, I have no idea what the issue might be... anyone any suggestions? I dont really want a new phone, since I dont really have the money, and Im still pretty pleased with my iphone 5
12chrismi The Legend - Antwoord
Hi!
I replaced new digitizer and display for my iPhone 5 and I lost that little plastic spacer between ear speaker and bracket. Where I can buy new one? In europe.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 53
Altijd: 217,702
