Ga door naar hoofdinhoud
iPhone 15 Screen Replacement
Wat je nodig hebt
    1. iPhone 15 Screen Replacement, Prepare your phone for disassembly: stap 1, afbeelding 1 van 2 iPhone 15 Screen Replacement, Prepare your phone for disassembly: stap 1, afbeelding 2 van 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Screen Replacement, Tape over any cracks: stap 2, afbeelding 1 van 2 iPhone 15 Screen Replacement, Tape over any cracks: stap 2, afbeelding 2 van 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Screen Replacement, Mark your opening picks: stap 3, afbeelding 1 van 3 iPhone 15 Screen Replacement, Mark your opening picks: stap 3, afbeelding 2 van 3 iPhone 15 Screen Replacement, Mark your opening picks: stap 3, afbeelding 3 van 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Screen Replacement, Remove the pentalobe screws: stap 4, afbeelding 1 van 2 iPhone 15 Screen Replacement, Remove the pentalobe screws: stap 4, afbeelding 2 van 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Screen Replacement, Heat the bottom edge: stap 5, afbeelding 1 van 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Screen Replacement, Insert an opening pick: stap 6, afbeelding 1 van 3 iPhone 15 Screen Replacement, Insert an opening pick: stap 6, afbeelding 2 van 3 iPhone 15 Screen Replacement, Insert an opening pick: stap 6, afbeelding 3 van 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Screen Replacement, Screen information: stap 7, afbeelding 1 van 1
      • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
      • There are two delicate cables connecting the screen to the phone, one just above the mute switch, and the other about halfway between the volume down button and the bottom of the phone.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Screen Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 1 van 3 iPhone 15 Screen Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 2 van 3 iPhone 15 Screen Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 3 van 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 15 Screen Replacement, Heat the right edge: stap 9, afbeelding 1 van 1
      • Heat the right edge of the screen until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 15 Screen Replacement, Position the opening pick: stap 10, afbeelding 1 van 3 iPhone 15 Screen Replacement, Position the opening pick: stap 10, afbeelding 2 van 3 iPhone 15 Screen Replacement, Position the opening pick: stap 10, afbeelding 3 van 3
      • Don't insert your pick deeper than 5 mm along the right edge.
      • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
      • Rotate your pick so the flat edge is under the screen.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 15 Screen Replacement, Release the right clip: stap 11, afbeelding 1 van 3 iPhone 15 Screen Replacement, Release the right clip: stap 11, afbeelding 2 van 3 iPhone 15 Screen Replacement, Release the right clip: stap 11, afbeelding 3 van 3
      • Hold the pick with one hand and twist it to increase the gap between the screen and the frame and release the right clip.
      • Insert a second opening pick to the right of the first one.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 15 Screen Replacement, Separate the right edge adhesive: stap 12, afbeelding 1 van 3 iPhone 15 Screen Replacement, Separate the right edge adhesive: stap 12, afbeelding 2 van 3 iPhone 15 Screen Replacement, Separate the right edge adhesive: stap 12, afbeelding 3 van 3
      • Slide the first pick back to the bottom right corner of the screen.
      • Slide the second pick to the top right corner of the screen to separate the adhesive.
      • Leave these picks inserted to prevent the adhesive from resealing.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone 15 Screen Replacement, Heat the top edge: stap 13, afbeelding 1 van 1
      • Heat the top edge of the screen until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone 15 Screen Replacement, Separate the top right corner adhesive: stap 14, afbeelding 1 van 3 iPhone 15 Screen Replacement, Separate the top right corner adhesive: stap 14, afbeelding 2 van 3 iPhone 15 Screen Replacement, Separate the top right corner adhesive: stap 14, afbeelding 3 van 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Insert a third opening pick in the top right corner, just above the previous pick.
      • Slide your pick around the top right corner and along the top edge until you feel it stop against the top left screen clip.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone 15 Screen Replacement, Release the top edge clips: stap 15, afbeelding 1 van 3 iPhone 15 Screen Replacement, Release the top edge clips: stap 15, afbeelding 2 van 3 iPhone 15 Screen Replacement, Release the top edge clips: stap 15, afbeelding 3 van 3
      • Rotate your pick so its flat edge is under the screen.
      • Twist your pick to release the top left screen clip.
      • Slide your pick to the top left corner.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone 15 Screen Replacement, Heat the left edge: stap 16, afbeelding 1 van 1
      • Heat the left edge of the screen until it's hot to the touch.
      Vraag FixBot
      Voeg opmerking toe
    13. iPhone 15 Screen Replacement, Separate the left edge adhesive: stap 17, afbeelding 1 van 3 iPhone 15 Screen Replacement, Separate the left edge adhesive: stap 17, afbeelding 2 van 3 iPhone 15 Screen Replacement, Separate the left edge adhesive: stap 17, afbeelding 3 van 3
      • Don't insert your pick deeper than 3 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Slide your pick around the top left corner of the screen and along the left edge to release the clips and separate the adhesive securing it.
      Vraag FixBot
      Voeg opmerking toe
    14. iPhone 15 Screen Replacement, Swing open the screen: stap 18, afbeelding 1 van 3 iPhone 15 Screen Replacement, Swing open the screen: stap 18, afbeelding 2 van 3 iPhone 15 Screen Replacement, Swing open the screen: stap 18, afbeelding 3 van 3
      • Gently swing open the screen over the left edge of the phone.
      • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      Vraag FixBot
      Voeg opmerking toe
    15. iPhone 15 Screen Replacement, Unfasten the front sensor connector cover: stap 19, afbeelding 1 van 1
      • Use a tri-point Y000 driver to remove the 0.9 mm-long screw securing the front sensor connector cover.
      Vraag FixBot
      Voeg opmerking toe
    16. iPhone 15 Screen Replacement, Remove the cover: stap 20, afbeelding 1 van 3 iPhone 15 Screen Replacement, Remove the cover: stap 20, afbeelding 2 van 3 iPhone 15 Screen Replacement, Remove the cover: stap 20, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Use tweezers to lift the cover to a 90-degree angle.
      • Unhook the cover from its slot in the logic board.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    17. iPhone 15 Screen Replacement, Disconnect the front sensor: stap 21, afbeelding 1 van 2 iPhone 15 Screen Replacement, Disconnect the front sensor: stap 21, afbeelding 2 van 2
      • Use the tip of an opening pick to pry up and disconnect the front sensor press connector.
      Vraag FixBot
      Voeg opmerking toe
    18. iPhone 15 Screen Replacement, Unfasten the screen connector cover: stap 22, afbeelding 1 van 1
      • Use your tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
      Vraag FixBot
      Voeg opmerking toe
    19. iPhone 15 Screen Replacement, Remove the cover: stap 23, afbeelding 1 van 2 iPhone 15 Screen Replacement, Remove the cover: stap 23, afbeelding 2 van 2
      • Use tweezers to lift the cover and unlatch it from its hook on the logic board.
      • Remove the cover.
      Vraag FixBot
      Voeg opmerking toe
    20. iPhone 15 Screen Replacement, Disconnect the screen: stap 24, afbeelding 1 van 2 iPhone 15 Screen Replacement, Disconnect the screen: stap 24, afbeelding 2 van 2
      • Use the tip of an opening pick to pry up and disconnect the screen press connector.
      Vraag FixBot
      Voeg opmerking toe
    21. iPhone 15 Screen Replacement, Remove the screen: stap 25, afbeelding 1 van 1
      • Remove the screen.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Screen Replacement, End of disassembly: stap 26, afbeelding 1 van 1
      • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
      • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Screen Replacement, Remove the screen adhesive: stap 27, afbeelding 1 van 3 iPhone 15 Screen Replacement, Remove the screen adhesive: stap 27, afbeelding 2 van 3 iPhone 15 Screen Replacement, Remove the screen adhesive: stap 27, afbeelding 3 van 3
      • Be careful not to damage any of the spring contacts as you clean the frame.
      • This is a good point to test your repair before sealing up your phone. Connect the screen, power on your phone, and make sure it works as expected. Power it back down and continue reassembly.
      • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
      • Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
      • Use a pair of tweezers, or your fingers, to remove the adhesive around the entire perimeter of the iPhone.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone 15 Screen Replacement: stap 28, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 28, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 28, afbeelding 3 van 3
      • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
      • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
      • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone 15 Screen Replacement, Ambient light sensor information: stap 29, afbeelding 1 van 1
      • The ambient light sensor is located behind the screen, directly beneath the cut‑out for the Face ID sensors.
      • Check if the replacement screen comes with one installed. If it does, skip to this step.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone 15 Screen Replacement, Remove the ambient light sensor bracket: stap 30, afbeelding 1 van 2 iPhone 15 Screen Replacement, Remove the ambient light sensor bracket: stap 30, afbeelding 2 van 2
      • Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone 15 Screen Replacement: stap 31, afbeelding 1 van 2 iPhone 15 Screen Replacement: stap 31, afbeelding 2 van 2
      • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone 15 Screen Replacement, Heat the ambient light sensor: stap 32, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone 15 Screen Replacement, Pry up the ambient light sensor: stap 33, afbeelding 1 van 2 iPhone 15 Screen Replacement, Pry up the ambient light sensor: stap 33, afbeelding 2 van 2
      • Use a spudger to pry up the ambient light sensor.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone 15 Screen Replacement, Peel up the ambient light sensor cable: stap 34, afbeelding 1 van 2 iPhone 15 Screen Replacement, Peel up the ambient light sensor cable: stap 34, afbeelding 2 van 2
      • Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving towards to the opposite corner until it's free from the screen.
      • If the adhesive doesn't peel up easily, apply more heat.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone 15 Screen Replacement, Remove the ambient light sensor: stap 35, afbeelding 1 van 1
      • Use a pair of tweezers to lift the ambient light sensor off of the screen.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone 15 Screen Replacement, Prepare the ambient light sensor: stap 36, afbeelding 1 van 2 iPhone 15 Screen Replacement, Prepare the ambient light sensor: stap 36, afbeelding 2 van 2
      Tesa 61395 Tape
      $2.95
      • Use tweezers to reposition any adhesive that may have covered the ambient light sensor during removal. The adhesive should form a border around the raised white rectangle.
      • If the adhesive was damaged or stayed with the old screen, replace it with a 1 mm wide strip of thin, double-sided tape along its bottom border.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone 15 Screen Replacement, Place the ambient light sensor: stap 37, afbeelding 1 van 2 iPhone 15 Screen Replacement, Place the ambient light sensor: stap 37, afbeelding 2 van 2
      • Align the ambient light sensor with its recess in the back of the screen.
      • Use a spudger or your finger to press the ambient light sensor into its recess.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone 15 Screen Replacement, Warm the ambient light sensor: stap 38, afbeelding 1 van 1
      • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable. It only needs to be warm—not hot.
      Vraag FixBot
      Voeg opmerking toe
    13. iPhone 15 Screen Replacement, Press the ambient light sensor: stap 39, afbeelding 1 van 3 iPhone 15 Screen Replacement, Press the ambient light sensor: stap 39, afbeelding 2 van 3 iPhone 15 Screen Replacement, Press the ambient light sensor: stap 39, afbeelding 3 van 3
      Tesa 61395 Tape
      $2.95
      • Use your finger to press down the ambient light sensor cable.
      • If the ambient light sensor cable isn't sticking, apply a few small pieces of double‑sided tape, like Tesa tape, to the back of the sensor cable.
      Vraag FixBot
      Voeg opmerking toe
    14. iPhone 15 Screen Replacement, Install the ambient light sensor bracket: stap 40, afbeelding 1 van 3 iPhone 15 Screen Replacement, Install the ambient light sensor bracket: stap 40, afbeelding 2 van 3 iPhone 15 Screen Replacement, Install the ambient light sensor bracket: stap 40, afbeelding 3 van 3
      • Use tweezers or your fingers to hook the ambient light sensor bracket over the back of the sensor and set it into place.
      Vraag FixBot
      Voeg opmerking toe
    15. iPhone 15 Screen Replacement: stap 41, afbeelding 1 van 2 iPhone 15 Screen Replacement: stap 41, afbeelding 2 van 2
      • Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
      Vraag FixBot
      Voeg opmerking toe
    16. iPhone 15 Screen Replacement, Orient the adhesive: stap 42, afbeelding 1 van 3 iPhone 15 Screen Replacement, Orient the adhesive: stap 42, afbeelding 2 van 3 iPhone 15 Screen Replacement, Orient the adhesive: stap 42, afbeelding 3 van 3
      • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
      • Your adhesive may look slightly different.
      Vraag FixBot
      Voeg opmerking toe
    17. iPhone 15 Screen Replacement, Apply the adhesive: stap 43, afbeelding 1 van 3 iPhone 15 Screen Replacement, Apply the adhesive: stap 43, afbeelding 2 van 3 iPhone 15 Screen Replacement, Apply the adhesive: stap 43, afbeelding 3 van 3
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      Vraag FixBot
      Voeg opmerking toe
    18. iPhone 15 Screen Replacement: stap 44, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 44, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 44, afbeelding 3 van 3
      • When the adhesive is aligned, use the flat end of a spudger, or your finger, to press it down firmly along the bottom edge.
      Vraag FixBot
      Voeg opmerking toe
    19. iPhone 15 Screen Replacement: stap 45, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 45, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 45, afbeelding 3 van 3
      • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
      Vraag FixBot
      Voeg opmerking toe
    20. iPhone 15 Screen Replacement, Press the adhesive into place: stap 46, afbeelding 1 van 3 iPhone 15 Screen Replacement, Press the adhesive into place: stap 46, afbeelding 2 van 3 iPhone 15 Screen Replacement, Press the adhesive into place: stap 46, afbeelding 3 van 3
      • Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
      • Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
      • Be careful not to press on the camera, spring contacts, or other internal components.
      Vraag FixBot
      Voeg opmerking toe
    21. iPhone 15 Screen Replacement, Remove the top liner: stap 47, afbeelding 1 van 2 iPhone 15 Screen Replacement, Remove the top liner: stap 47, afbeelding 2 van 2
      • Insert the point of a spudger under the top liner's hole at the bottom of the frame.
      • Pry up to separate the liner from the frame—enough to grip it with your fingers.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners under it.
      Vraag FixBot
      Voeg opmerking toe
    22. iPhone 15 Screen Replacement: stap 48, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 48, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 48, afbeelding 3 van 3
      • Peel back the top liner and remove it.
      Vraag FixBot
      Voeg opmerking toe
    23. iPhone 15 Screen Replacement, Prop up the screen: stap 49, afbeelding 1 van 1
      • Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
      Vraag FixBot
      Voeg opmerking toe
    24. iPhone 15 Screen Replacement, Connect the screen: stap 50, afbeelding 1 van 2 iPhone 15 Screen Replacement, Connect the screen: stap 50, afbeelding 2 van 2
      • Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
      Vraag FixBot
      Voeg opmerking toe
    25. iPhone 15 Screen Replacement: stap 51, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 51, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 51, afbeelding 3 van 3
      • Insert the top of the screen connector cover into its slot in the frame and lay it over the press connector.
      Vraag FixBot
      Voeg opmerking toe
    26. iPhone 15 Screen Replacement: stap 52, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 52, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 52, afbeelding 3 van 3
      • Insert the front sensor connector cover into its slot in the frame at a 90‑degree angle vertically.
      • Lay the cover over the press connector.
      Vraag FixBot
      Voeg opmerking toe
    27. iPhone 15 Screen Replacement, Install the cover screws: stap 53, afbeelding 1 van 2 iPhone 15 Screen Replacement, Install the cover screws: stap 53, afbeelding 2 van 2
      • Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
      Vraag FixBot
      Voeg opmerking toe
    28. iPhone 15 Screen Replacement, Remove the final adhesive liners: stap 54, afbeelding 1 van 2 iPhone 15 Screen Replacement, Remove the final adhesive liners: stap 54, afbeelding 2 van 2
      • As you remove the liners in this step, the adhesive will be fully exposed. Make sure nothing touches the exposed adhesive.
      • Use a spudger, or your fingers, to separate the pull tabs at the bottom right corner of the frame.
      Vraag FixBot
      Voeg opmerking toe
    29. iPhone 15 Screen Replacement: stap 55, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 55, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 55, afbeelding 3 van 3
      • Remove the narrow liner covering the adhesive along the right and top edges of the frame.
      Vraag FixBot
      Voeg opmerking toe
    30. iPhone 15 Screen Replacement: stap 56, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 56, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 56, afbeelding 3 van 3
      • Remove the liner along the bottom edge of the frame.
      Vraag FixBot
      Voeg opmerking toe
    31. iPhone 15 Screen Replacement: stap 57, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 57, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 57, afbeelding 3 van 3
      • Without letting the screen touch the adhesive, hold the screen over the phone so you can access the final liner along the left edge of the phone.
      • Use a pair of tweezers or your fingers to remove the final liner along the left edge of the phone.
      Vraag FixBot
      Voeg opmerking toe
    32. iPhone 15 Screen Replacement, Place the screen: stap 58, afbeelding 1 van 3 iPhone 15 Screen Replacement, Place the screen: stap 58, afbeelding 2 van 3 iPhone 15 Screen Replacement, Place the screen: stap 58, afbeelding 3 van 3
      • Lay the screen straight down onto the frame and press until the clips engage.
      • Press around the perimeter of the screen to engage all clips.
      Vraag FixBot
      Voeg opmerking toe
    33. iPhone 15 Screen Replacement, Heat the screen: stap 59, afbeelding 1 van 2 iPhone 15 Screen Replacement, Heat the screen: stap 59, afbeelding 2 van 2
      • To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
      • If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
      Vraag FixBot
      Voeg opmerking toe
    34. iPhone 15 Screen Replacement, Press the screen: stap 60, afbeelding 1 van 3 iPhone 15 Screen Replacement, Press the screen: stap 60, afbeelding 2 van 3 iPhone 15 Screen Replacement, Press the screen: stap 60, afbeelding 3 van 3
      • To evenly compress your iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the box your iPhone came in, take the lid and place it on a flat surface.
      • If you don't have your original box, skip this step for an alternate method.
      • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
      • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
      Vraag FixBot
      Voeg opmerking toe
    35. iPhone 15 Screen Replacement: stap 61, afbeelding 1 van 2 iPhone 15 Screen Replacement: stap 61, afbeelding 2 van 2
      • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      Vraag FixBot
      Voeg opmerking toe
    36. iPhone 15 Screen Replacement: stap 62, afbeelding 1 van 3 iPhone 15 Screen Replacement: stap 62, afbeelding 2 van 3 iPhone 15 Screen Replacement: stap 62, afbeelding 3 van 3
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Stack them to a consistent height taller than the camera bump.
      Vraag FixBot
      Voeg opmerking toe
    37. iPhone 15 Screen Replacement: stap 63, afbeelding 1 van 1
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone 15 Screen Replacement, Install the pentalobe screws: stap 64, afbeelding 1 van 2 iPhone 15 Screen Replacement, Install the pentalobe screws: stap 64, afbeelding 2 van 2
      • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
22 andere personen hebben deze handleiding voltooid.
Clay Eickemeyer
105.659 Reputatie
472 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
10 Leden
28.223 handleidingen geschreven
11Gids Commentaar
Is it safe to remove the screen of Iphone 15 or even 14 without disconnecting the battery? Thank you.
Laurentiu.P - Antwoord Deel
Hi Laurentiu,
In the case of the iPhone 15 series and the iPhone 14 vanilla models, their design is intentional so that you may replace the screen without disconnecting the battery. To mitigate any ESD-related risks, don't use any metal prying tools, use ESD-safe tools, and discharge and shut down your device before opening it up. Read more about ESD here.
Good luck!
Clay Eickemeyer - Antwoord Deel
Ok, I got you, thank you very much. So it doesn't matter if we change the screen and battery is still unplugged, even if we use lcd or led screen, if we use the right tools.
This may not be true for all devices, but Apple devices are quite robust. You should have no problem swapping a screen out on an iPhone 15. Just make sure that the press connectors are fully connected, since the insulating foam around the sockets may prevent them from laying flush!
Why is iPhone 15 Screen Replacement not sold in Canada?
SirDropsphonealot - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 140
Afgelopen 7 dagen: 975
Afgelopen 30 dagen: 4,917
Altijd: 101,106
