Ga door naar hoofdinhoud
iPad Pro 13" Lock Button Replacement
Wat je nodig hebt
  1. iPad Pro 13" Lock Button Replacement, Prepare the iPad for disassembly: stap 1, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Prepare the iPad for disassembly: stap 1, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Prepare the iPad for disassembly: stap 1, afbeelding 3 van 3
    • For your safety, fully discharge the battery before disassembling the device. This reduces the risk of fire if the battery is accidentally damaged during the repair.
    • Disconnect all cables and accessories from the iPad.
    • Place masking tape over the following areas of the display:
    • The TrueDepth camera near the middle of the top edge
    • The ambient light sensor near the middle of the left edge
    • The bottom edge, where there are delicate ribbon cables under the display
    • Note that directions in this guide are given for the iPad in landscape orientation. The USB-C port is on the right edge of the iPad.
    • If your screen is badly cracked, cover it with a layer of packing tape to help the suction cup stick and prevent shards of glass from coming off.
    Vraag FixBot
    Voeg opmerking toe
  2. iPad Pro 13" Lock Button Replacement, Mark your opening picks: stap 2, afbeelding 1 van 1
    • While removing the display, don't insert picks more than 3.5 mm.
    • Mark your opening picks at 3.5 mm.
    Vraag FixBot
    Voeg opmerking toe
  3. iPad Pro 13" Lock Button Replacement, Heat the top-right corner: stap 3, afbeelding 1 van 1
    • Apply a heated iOpener to the top-right corner of the screen for two minutes to soften the adhesive.
    • You can also use a hair dryer or heat gun to soften the adhesive, but be careful not to overheat the iPad as the screen and battery can be damaged by heat.
    • Use this same procedure for all future steps where heat is needed to soften adhesive, unless otherwise noted.
    Vraag FixBot
    Voeg opmerking toe
  4. iPad Pro 13" Lock Button Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    • The next three steps show how to use the Anti-Clamp. For complete Anti-Clamp instructions, including how to work with a broken screen, check out this guide.
    • If you don't have an Anti-Clamp, read these steps for important tips, then follow the alternate method using a suction handle, which comes after these steps.
    • Unlock the Anti-Clamp by pulling the blue handle backwards, away from the suction cups.
    • Place something under the bottom-left corner of the iPad to hold it level, then place the Anti-Clamp on your work surface and insert the top-right corner of the iPad between the Anti-Clamp's suction cups.
    • Hold the bottom of the Anti-Clamp and press down on the top arm to engage the suction cups.
    • Make sure the top and bottom suction cups are aligned, and remain aligned for this entire procedure.
    Vraag FixBot
    Voeg opmerking toe
  5. iPad Pro 13" Lock Button Replacement: stap 5, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 5, afbeelding 2 van 2
    • Pull the blue handle forward, towards the suction cups, to engage the twist mechanism.
    • Turn the blue handle clockwise one full rotation or until the suction cups start to stretch.
    • If a suction cup pops off, reapply it. If needed, apply some suction tape for a grippier surface.
    Vraag FixBot
    Voeg opmerking toe
  6. iPad Pro 13" Lock Button Replacement: stap 6, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 6, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 6, afbeelding 3 van 3
    • Wait at least one minute for the Anti-Clamp to pull the screen up until there's a small gap between the screen and the frame.
    • Rely on heat and time to lift the screen. Don't try to force it open.
    • If the screen isn't lifting after two minutes:
    • Make sure there's tension on the suction cups. Crank the handle just until you feel resistance, but don't crank too much or the suction cups will release.
    • Apply more heat while the Anti-Clamp is engaged. You can thread a heated iOpener through the Anti-Clamp or use a hair dryer or heat gun.
    • If the screen is still not releasing, crank the handle a half-turn and wait another minute while applying more heat periodically, still being careful not to overheat the iPad. Repeat as needed.
    • Once the screen lifts, insert a marked opening pick into the gap, no more than 3.5 mm deep.
    • Slide the opening pick around the corner and leave it inserted.
    Vraag FixBot
    Voeg opmerking toe
  7. iPad Pro 13" Lock Button Replacement, Suction handle instructions: stap 7, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Suction handle instructions: stap 7, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Suction handle instructions: stap 7, afbeelding 3 van 3
    • If you don't have an Anti‑Clamp, use a single suction handle instead.
    • If the screen is badly cracked, make a handle out of very strong tape instead of a suction cup. If nothing else works, you can use strong glue to stick the suction cup to the broken screen.
    • Apply the suction handle near the top‑right corner with the open part of the handle facing away from the edge.
    • Hold the iPad down with one hand, away from the suction cup, and pull the suction handle up and towards the center of the iPad.
    • As soon as a small gap appears between the screen and the frame, insert a marked opening pick no more than 3.5 mm into the gap and release tension on the suction cup.
    • If you're having trouble lifting the screen, be patient and apply more heat while pulling on the suction handle.
    • Slide the pick gently around the corner and leave it inserted.
    Vraag FixBot
    Voeg opmerking toe
  8. iPad Pro 13" Lock Button Replacement, Heat the top edge: stap 8, afbeelding 1 van 1
    • Use an iOpener, hair dryer, or heat gun to soften the adhesive under the top edge of the screen.
    • This iPad cools very quickly. To get the screen off, work in sections of about 3 inches at a time. So, for this step, start with heating the right side of the top edge.
    Vraag FixBot
    Voeg opmerking toe
  9. iPad Pro 13" Lock Button Replacement, Slice the top edge adhesive: stap 9, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Slice the top edge adhesive: stap 9, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Slice the top edge adhesive: stap 9, afbeelding 3 van 3
    • Be patient while slicing the screen adhesive. If you suddenly feel more resistance, stop and apply more heat. If you're using an iOpener, you can apply heat while you're sliding the pick.
    • Insert an additional marked opening pick beside the first pick, on the top edge of the iPad, no more than 3.5 mm.
    • Slice the adhesive by slowly sliding the opening pick under the screen towards the front camera, stopping before you get to the masking tape.
    Vraag FixBot
    Voeg opmerking toe
  10. iPad Pro 13" Lock Button Replacement: stap 10, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 10, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 10, afbeelding 3 van 3
    • Be careful not to damage the sensitive components, like the front camera and microphone, under the screen. Work slowly. If you feel resistance, stop, slide the pick back partially, apply more heat, and continue.
    • Lift the opening pick so it's at a sharp angle pointing into the iPad.
    • Slice the adhesive by sliding the pick under the taped section of the screen.
    Vraag FixBot
    Voeg opmerking toe
  11. iPad Pro 13" Lock Button Replacement: stap 11, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 11, afbeelding 2 van 2
    • Finish slicing the adhesive by sliding the opening pick to the top-left corner.
    • Leave the opening pick inserted.
    Vraag FixBot
    Voeg opmerking toe
  12. iPad Pro 13" Lock Button Replacement, Slice the right edge adhesive: stap 12, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Slice the right edge adhesive: stap 12, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Slice the right edge adhesive: stap 12, afbeelding 3 van 3
    • Heat the right edge of the iPad.
    • Insert an opening pick beside the first opening pick you inserted, on the right edge.
    • Working in small sections, slice the adhesive, applying more heat as needed.
    Vraag FixBot
    Voeg opmerking toe
  13. iPad Pro 13" Lock Button Replacement, Slice the bottom-right corner adhesive: stap 13, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Slice the bottom-right corner adhesive: stap 13, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Slice the bottom-right corner adhesive: stap 13, afbeelding 3 van 3
    • Heat the bottom-right corner of the iPad.
    • Carefully slide the opening pick from the previous step around the bottom-right corner.
    • Leave the pick inserted.
    Vraag FixBot
    Voeg opmerking toe
  14. iPad Pro 13" Lock Button Replacement, Slice the bottom edge adhesive: stap 14, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Slice the bottom edge adhesive: stap 14, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Slice the bottom edge adhesive: stap 14, afbeelding 3 van 3
    • Heat the bottom edge of the iPad, focusing on the right end.
    • Insert an opening pick beside the pick in the corner, on the bottom edge, no more than 3.5 mm deep.
    • Lift the pick so it enters the iPad at a sharp angle.
    • Carefully slide the pick under the screen across the bottom edge of the iPad.
    • Work slowly to avoid damaging the delicate ribbon cables under the screen in this section. If you feel any resistance, stop, slide your pick back partially, apply more heat, and try again.
    Vraag FixBot
    Voeg opmerking toe
  15. iPad Pro 13" Lock Button Replacement, Slice the bottom-left corner adhesive: stap 15, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Slice the bottom-left corner adhesive: stap 15, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Slice the bottom-left corner adhesive: stap 15, afbeelding 3 van 3
    • Heat the bottom-left corner of the iPad.
    • Carefully slide the opening pick around the bottom-left corner.
    Vraag FixBot
    Voeg opmerking toe
  16. iPad Pro 13" Lock Button Replacement, Slice the left edge adhesive: stap 16, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Slice the left edge adhesive: stap 16, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Slice the left edge adhesive: stap 16, afbeelding 3 van 3
    • Heat the left edge of the iPad, focusing on the bottom end.
    • Insert an opening pick above the pick already inserted near the bottom-left corner.
    • Carefully slide the pick to the beginning of the masking tape.
    Vraag FixBot
    Voeg opmerking toe
  17. iPad Pro 13" Lock Button Replacement: stap 17, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 17, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 17, afbeelding 3 van 3
    • Slide the opening pick to the top-left corner.
    • Work slowly to avoid damaging the ambient light sensor near the middle of the screen. If you feel resistance, stop, pull the pick back slightly, apply more heat, and try again.
    • Don't try to remove the iPad screen yet. You should be able to lift the iPad screen about a half–inch out of the frame all the way around the edge.
    • If the screen is still adhered anywhere, use heat and an opening pick to slice the adhesive. Use opening picks to keep the screen lifted while you work.
    Vraag FixBot
    Voeg opmerking toe
  18. iPad Pro 13" Lock Button Replacement, Reposition the screen: stap 18, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Reposition the screen: stap 18, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Reposition the screen: stap 18, afbeelding 3 van 3
    • Once the screen is completely free of the adhesive, lift it about a half-inch and rotate it slightly counterclockwise so the screw next to the front camera is visible.
    Vraag FixBot
    Voeg opmerking toe
  19. iPad Pro 13" Lock Button Replacement, Remove the microphone connector cover: stap 19, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Remove the microphone connector cover: stap 19, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Remove the microphone connector cover: stap 19, afbeelding 3 van 3
    • Use a JCIS or JIS 00 screwdriver to remove the 1.3 mm‑long screw securing the microphone connector cover.
    • Small iFixit Phillips bits are designed to work with JIS screws, so you can use an iFixit PH 00 driver. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
    • Use tweezers or your fingers to remove the microphone connector cover. Be careful not to damage the foam on the back.
    Vraag FixBot
    Voeg opmerking toe
  20. iPad Pro 13" Lock Button Replacement, Disconnect the microphone: stap 20, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Disconnect the microphone: stap 20, afbeelding 2 van 2
    Vraag FixBot
    Voeg opmerking toe
  21. iPad Pro 13" Lock Button Replacement, Open the iPad: stap 21, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Open the iPad: stap 21, afbeelding 2 van 2
    • Open the iPad like a book from the top edge.
    • Hold the screen above the iPad body and place a soft cloth on top of the iPad to protect both the screen and the iPad body.
    • Place the screen face-down on the cloth, being careful not to strain the cables still attached to the iPad body.
    Vraag FixBot
    Voeg opmerking toe
  22. iPad Pro 13" Lock Button Replacement, Remove the display connectors cover: stap 22, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Remove the display connectors cover: stap 22, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Remove the display connectors cover: stap 22, afbeelding 3 van 3
    • Place cloths over the batteries to protect them while you work.
    • Use a JCIS or JIS 00 screwdriver to remove the screws securing the display connectors cover:
    • Four 2.1 mm‑long screws towards the center of the iPad
    • Two 1.6 mm‑long screws near the edge of the iPad
    • Use tweezers or your fingers to remove the display connectors cover.
    Vraag FixBot
    Voeg opmerking toe
  23. iPad Pro 13" Lock Button Replacement, Disconnect the screen: stap 23, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Disconnect the screen: stap 23, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Disconnect the screen: stap 23, afbeelding 3 van 3
    • Use the tip of a spudger to pry up and disconnect the wide display cable press connector.
    • Then, use the tip of a spudger to pry up and disconnect the Multi‑Touch cable press connector.
    Vraag FixBot
    Voeg opmerking toe
  24. iPad Pro 13" Lock Button Replacement: stap 24, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 24, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 24, afbeelding 3 van 3
    • Use the tip of a spudger to pry up and disconnect both of the display power cable press connectors.
    Vraag FixBot
    Voeg opmerking toe
  25. iPad Pro 13" Lock Button Replacement, Remove the screen: stap 25, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Remove the screen: stap 25, afbeelding 2 van 2
    • Remove the screen.
    Vraag FixBot
    Voeg opmerking toe
  26. iPad Pro 13" Lock Button Replacement, Remove the rear camera cover: stap 26, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Remove the rear camera cover: stap 26, afbeelding 2 van 2
    • Use a JCIS or JIS 00 screwdriver to remove the four screws securing the rear camera cover:
    • Two 1.4 mm‑long screws, one near the center and one in the top-right corner
    • Two 1.6 mm‑long screws, one near the middle of the left edge and one near the bottom-right corner
    Vraag FixBot
    Voeg opmerking toe
  27. iPad Pro 13" Lock Button Replacement: stap 27, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 27, afbeelding 2 van 2
    • Use tweezers or your fingers to remove the rear camera cover.
    Vraag FixBot
    Voeg opmerking toe
  28. iPad Pro 13" Lock Button Replacement, Remove the lock button screws: stap 28, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Remove the lock button screws: stap 28, afbeelding 2 van 2
    • Use a JCIS or JIS 00 screwdriver to remove the two screws securing the lock button and bracket:
    • One 2.0 mm‑long screw securing the top of the bracket.
    • One 2.5 mm‑long screw securing the bottom of the bracket.
    • On models without cellular, remove the screws in this image instead.
    Vraag FixBot
    Voeg opmerking toe
  29. iPad Pro 13" Lock Button Replacement, Disconnect the camera: stap 29, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Disconnect the camera: stap 29, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Disconnect the camera: stap 29, afbeelding 3 van 3
    • Place the flat end of a spudger between the camera ribbon cable and the top button ribbon cable, against the camera press connector.
    • While holding the top button ribbon cable down with the spudger, twist the spudger to disconnect the rear camera press connector.
    • Lift the camera ribbon cable up so it's nearly vertical to keep it out of the way.
    Vraag FixBot
    Voeg opmerking toe
  30. iPad Pro 13" Lock Button Replacement, Disconnect the lock button: stap 30, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Disconnect the lock button: stap 30, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the lock button press connector.
    Vraag FixBot
    Voeg opmerking toe
  31. iPad Pro 13" Lock Button Replacement, Remove the lock button and bracket: stap 31, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Remove the lock button and bracket: stap 31, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Remove the lock button and bracket: stap 31, afbeelding 3 van 3
    • Slide an opening pick under the lock button press connector.
    • While pressing the opening pick up against the lock button ribbon cable, slide the pick under the cable to release the adhesive securing it to the iPad.
    • There are two pads under the ribbon cable. Be careful not to peel these up. If you do peel them up, place them back in their original positions.
    • Remove the lock button and bracket.
    • If you're just replacing this part and not the lock button cap, skip the next 8 steps.
    Vraag FixBot
    Voeg opmerking toe
  32. iPad Pro 13" Lock Button Replacement, Remove the lock button cap screws: stap 32, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Remove the lock button cap screws: stap 32, afbeelding 2 van 2
    • Removing the screws in this step may cause the plunger, lock button, and retaining clip to fall out, so work carefully over a clean work surface.
    • Use a JIS 00 screwdriver to remove the two 1.6 mm‑long screws securing the lock button retaining clip.
    Vraag FixBot
    Voeg opmerking toe
  33. iPad Pro 13" Lock Button Replacement, Remove the plunger: stap 33, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Remove the plunger: stap 33, afbeelding 2 van 2
    • Use tweezers or your fingers to remove the plunger from the lock button cap.
    • Note that this is small, non-magnetic, and round, so place it somewhere safe if you're not replacing it!
    Vraag FixBot
    Voeg opmerking toe
  34. iPad Pro 13" Lock Button Replacement, Remove the lock button cap: stap 34, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Remove the lock button cap: stap 34, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Remove the lock button cap: stap 34, afbeelding 3 van 3
    • Use a pair of angled tweezers or a spudger to gently push the lock button cap and retaining clip out of the iPad frame.
    • Alternatively, you can tilt the iPad to let these pieces fall out.
    Vraag FixBot
    Voeg opmerking toe
  35. iPad Pro 13" Lock Button Replacement, Disassembly complete: stap 35, afbeelding 1 van 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble the iPad.
    Vraag FixBot
    Voeg opmerking toe
  36. iPad Pro 13" Lock Button Replacement, Check the lock button cap: stap 36, afbeelding 1 van 1
    • Make sure that the silver retaining clip is properly seated in the lock button cap.
    Vraag FixBot
    Voeg opmerking toe
  37. iPad Pro 13" Lock Button Replacement, Place the lock button cap: stap 37, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Place the lock button cap: stap 37, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Place the lock button cap: stap 37, afbeelding 3 van 3
    • Use a pair of tweezers to hold the lock button cap and retaining clip in place over the opening in the iPad frame.
    • Use your finger to press the lock button cap, retaining clip, and tweezers against the frame.
    • Remove the tweezers and press the lock button cap and retaining clip into the frame.
    • Alternatively, you can hold the iPad with the lock button opening facing up and drop these pieces in place, but they're easy to lose if you miss the opening.
    Vraag FixBot
    Voeg opmerking toe
  38. iPad Pro 13" Lock Button Replacement: stap 38, afbeelding 1 van 1
    • Optionally, tape the lock button cap in place.
    Vraag FixBot
    Voeg opmerking toe
  39. iPad Pro 13" Lock Button Replacement, Secure the lock button cap: stap 39, afbeelding 1 van 1
    • Use a JIS 00 screwdriver to install the two 1.6 mm‑long screws securing the lock button retaining clip.
    Vraag FixBot
    Voeg opmerking toe
  40. iPad Pro 13" Lock Button Replacement, Insert the plunger: stap 40, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Insert the plunger: stap 40, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Insert the plunger: stap 40, afbeelding 3 van 3
    • Use tweezers or your fingers to slide the plunger into the lock button cap.
    Vraag FixBot
    Voeg opmerking toe
  41. iPad Pro 13" Lock Button Replacement, Secure the lock button and bracket: stap 41, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Secure the lock button and bracket: stap 41, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Secure the lock button and bracket: stap 41, afbeelding 3 van 3
    • Use tweezers or your fingers to place the lock button bracket over its screw wells.
    • Use a JIS 00 screwdriver to install the two screws securing the lock button bracket:
    Vraag FixBot
    Voeg opmerking toe
  42. iPad Pro 13" Lock Button Replacement, Press the ribbon cables: stap 42, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Press the ribbon cables: stap 42, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Press the ribbon cables: stap 42, afbeelding 3 van 3
    • Use a spudger or your finger to press the lock button ribbon cable onto the pads.
    Vraag FixBot
    Voeg opmerking toe
  43. iPad Pro 13" Lock Button Replacement, Connect the lock button: stap 43, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Connect the lock button: stap 43, afbeelding 2 van 2
    • Use the flat end of a spudger or your finger to connect the lock button press connector.
    Vraag FixBot
    Voeg opmerking toe
  44. iPad Pro 13" Lock Button Replacement, Connect the rear camera: stap 44, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Connect the rear camera: stap 44, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Connect the rear camera: stap 44, afbeelding 3 van 3
    • Use the flat end of a spudger or your finger to connect the rear camera press connector to the lock button ribbon cable.
    Vraag FixBot
    Voeg opmerking toe
  45. iPad Pro 13" Lock Button Replacement, Install the rear camera cover: stap 45, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Install the rear camera cover: stap 45, afbeelding 2 van 2
    • Use tweezers or your fingers to place the rear camera cover over the rear camera.
    Vraag FixBot
    Voeg opmerking toe
  46. iPad Pro 13" Lock Button Replacement: stap 46, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 46, afbeelding 2 van 2
    • Use a JCIS or JIS 00 driver to install the four screws securing the rear camera cover:
    Vraag FixBot
    Voeg opmerking toe
  47. iPad Pro 13" Lock Button Replacement, Clean frame adhesive: stap 47, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Clean frame adhesive: stap 47, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Clean frame adhesive: stap 47, afbeelding 3 van 3
    • Don't touch the ambient light sensor near the middle of the left edge or TrueDepth camera near the middle of the top edge while cleaning the frame.
    • Use the tip of a spudger to lift a section of adhesive. Look for an edge or overhang where you can get underneath the adhesive strip.
    Vraag FixBot
    Voeg opmerking toe
  48. iPad Pro 13" Lock Button Replacement: stap 48, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 48, afbeelding 2 van 2
    • Use tweezers or your fingers to lift and remove the old screen adhesive. Apply a little heat to make the removal easier.
    Vraag FixBot
    Voeg opmerking toe
  49. iPad Pro 13" Lock Button Replacement: stap 49, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 49, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 49, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Adhesive Cleanup Kit (Set of 12)
    $7.99
    • Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
    • Alternatively, use our adhesive cleanup kit.
    Vraag FixBot
    Voeg opmerking toe
  50. iPad Pro 13" Lock Button Replacement, Clean screen adhesive: stap 50, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Clean screen adhesive: stap 50, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Clean screen adhesive: stap 50, afbeelding 3 van 3
    • Skip this step if you're installing a new screen.
    • Repeat this process to clean the adhesive off the screen bezel.
    • Don't scrape with a metal tool, or you will scratch the display assembly's black paint.
    • Only apply solvents (like isopropyl alcohol) to the black bezel. Don't let any get under the front sensor assembly or display itself. Solvents will also dissolve the foam gaskets, especially around the front camera cutouts.
    Vraag FixBot
    Voeg opmerking toe
  51. iPad Pro 13" Lock Button Replacement, Align new adhesive: stap 51, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Align new adhesive: stap 51, afbeelding 2 van 2
    • If your replacement screen comes with adhesive pre‑installed, skip the next twelve steps.
    • Be careful not to crease or stretch the adhesive during installation. It can't be used if damaged.
    • Align the adhesive with the frame of the iPad. It's easiest to align it above the USB‑C port.
    Vraag FixBot
    Voeg opmerking toe
  52. iPad Pro 13" Lock Button Replacement, Flip the adhesive over: stap 52, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Flip the adhesive over: stap 52, afbeelding 2 van 2
    • Flip the adhesive over so it's aligned with the back of the screen.
    Vraag FixBot
    Voeg opmerking toe
  53. iPad Pro 13" Lock Button Replacement, Set the adhesive aside: stap 53, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Set the adhesive aside: stap 53, afbeelding 2 van 2
    • Lift the adhesive off the back of the screen and set it to the side. Keep it in the same orientation as the screen.
    Vraag FixBot
    Voeg opmerking toe
  54. iPad Pro 13" Lock Button Replacement: stap 54, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 54, afbeelding 2 van 2
    • Don't remove any of the plastic adhesive liners yet—they keep the adhesive in shape.
    • Use scissors to cut the adhesive vertically in half. Be careful not to crease or pull the adhesive itself.
    Vraag FixBot
    Voeg opmerking toe
  55. iPad Pro 13" Lock Button Replacement, Left adhesive: stap 55, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Left adhesive: stap 55, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Left adhesive: stap 55, afbeelding 3 van 3
    • The adhesive is encased in four layers of plastic—three on top and one on the bottom.
    • Peel and remove the topmost plastic cling layer from the left adhesive strip.
    Vraag FixBot
    Voeg opmerking toe
  56. iPad Pro 13" Lock Button Replacement: stap 56, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 56, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 56, afbeelding 3 van 3
    • Flip the left adhesive over.
    • Peel the clear liner with the blue line off the back of the left adhesive. The adhesive is now exposed.
    Vraag FixBot
    Voeg opmerking toe
  57. iPad Pro 13" Lock Button Replacement, Install the left adhesive: stap 57, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Install the left adhesive: stap 57, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Install the left adhesive: stap 57, afbeelding 3 van 3
    • Work slowly when installing the adhesive—once it sticks, it can't be repositioned.
    • Flip the left adhesive and align it to the left edge of the display assembly.
    • Set the left adhesive in place aligned with the left edge of the screen.
    • Press the top and bottom sections of the left adhesive onto the back of the screen.
    Vraag FixBot
    Voeg opmerking toe
  58. iPad Pro 13" Lock Button Replacement: stap 58, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 58, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 58, afbeelding 3 van 3
    • Remove the clear liner on the left adhesive. Leave the final blue liner in place.
    Vraag FixBot
    Voeg opmerking toe
  59. iPad Pro 13" Lock Button Replacement, Prepare the right adhesive: stap 59, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Prepare the right adhesive: stap 59, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Prepare the right adhesive: stap 59, afbeelding 3 van 3
    • Repeat the preparation process with the right adhesive strip.
    • Peel and remove the topmost (clear) cling layer from the strip.
    • Peel and remove the bottom liner layer (clear with a blue line) from the strip.
    Vraag FixBot
    Voeg opmerking toe
  60. iPad Pro 13" Lock Button Replacement: stap 60, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 60, afbeelding 2 van 2
    • Flip the right adhesive and peel off the clear liner with a blue line.
    Vraag FixBot
    Voeg opmerking toe
  61. iPad Pro 13" Lock Button Replacement, Install the right adhesive: stap 61, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Install the right adhesive: stap 61, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Install the right adhesive: stap 61, afbeelding 3 van 3
    • Flip the right adhesive and set it in place, aligned with the right edge of the screen.
    • Press the top and bottom sections of the right adhesive onto the back of the screen.
    Vraag FixBot
    Voeg opmerking toe
  62. iPad Pro 13" Lock Button Replacement, Remove the clear liner: stap 62, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Remove the clear liner: stap 62, afbeelding 2 van 2
    • Remove the clear liner off the right adhesive. Leave the final blue liner in place.
    Vraag FixBot
    Voeg opmerking toe
  63. iPad Pro 13" Lock Button Replacement, Press the adhesive: stap 63, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Press the adhesive: stap 63, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Press the adhesive: stap 63, afbeelding 3 van 3
    • Use the flat end of a spudger to gently press all the adhesive into place around the entire perimeter of the iPad. Be careful not to press on the delicate ribbon cables across the bottom of the screen.
    Vraag FixBot
    Voeg opmerking toe
  64. iPad Pro 13" Lock Button Replacement, Set the screen on the iPad: stap 64, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Set the screen on the iPad: stap 64, afbeelding 2 van 2
    • Place a clean cloth over the left battery cell in the iPad.
    • Set the screen on the iPad, so the screen cable connectors can reach their respective sockets in the iPad.
    Vraag FixBot
    Voeg opmerking toe
  65. iPad Pro 13" Lock Button Replacement, Connect the display power cables: stap 65, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Connect the display power cables: stap 65, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Connect the display power cables: stap 65, afbeelding 3 van 3
    • Align one of the display power cable press connectors over its socket on the logic board.
    • Press down with the flat end of a spudger or your fingertip—first on one of the short sides, then the other—until it clicks into place.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    • Repeat this process to connect the second display power cable press connector.
    Vraag FixBot
    Voeg opmerking toe
  66. iPad Pro 13" Lock Button Replacement, Connect the display cables: stap 66, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Connect the display cables: stap 66, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Connect the display cables: stap 66, afbeelding 3 van 3
    • Repeat the same procedure to connect the two remaining display cables.
    Vraag FixBot
    Voeg opmerking toe
  67. iPad Pro 13" Lock Button Replacement, Install the display connectors cover: stap 67, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Install the display connectors cover: stap 67, afbeelding 2 van 2
    • Set the display connectors cover onto the logic board so it's aligned with its screw holes.
    Vraag FixBot
    Voeg opmerking toe
  68. iPad Pro 13" Lock Button Replacement, Install the display connectors cover screws: stap 68, afbeelding 1 van 1
    • Use a JCIS or JIS 00 screwdriver to install the six screws securing the display connectors cover:
    Vraag FixBot
    Voeg opmerking toe
  69. iPad Pro 13" Lock Button Replacement, Remove the final adhesive liners: stap 69, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Remove the final adhesive liners: stap 69, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Remove the final adhesive liners: stap 69, afbeelding 3 van 3
    • Use tweezers or your fingers to remove the final, blue liners off the iPad screen adhesive.
    Vraag FixBot
    Voeg opmerking toe
  70. iPad Pro 13" Lock Button Replacement: stap 70, afbeelding 1 van 1
    • Verify all the adhesive liners are removed. The adhesive is now exposed.
    Vraag FixBot
    Voeg opmerking toe
  71. iPad Pro 13" Lock Button Replacement, Remove the cloth: stap 71, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Remove the cloth: stap 71, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Remove the cloth: stap 71, afbeelding 3 van 3
    • Without touching the adhesive, slightly lift the iPad screen and remove the cloth between it and the iPad.
    Vraag FixBot
    Voeg opmerking toe
  72. iPad Pro 13" Lock Button Replacement, Set the screen down at an angle: stap 72, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Set the screen down at an angle: stap 72, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Set the screen down at an angle: stap 72, afbeelding 3 van 3
    • Don't align the iPad screen with the frame yet—the front sensor assembly still needs to be connected.
    • Flip the iPad screen over and set it down at a slight angle on top of the iPad frame.
    Vraag FixBot
    Voeg opmerking toe
  73. iPad Pro 13" Lock Button Replacement, Connect the front sensor assembly: stap 73, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Connect the front sensor assembly: stap 73, afbeelding 2 van 2
    • Be careful not to strain the microphone cable while connecting it. If it doesn't reach, lower the screen until it does.
    • Hover the top of the screen over the microphone connector's socket on the board.
    • Use the flat end of a spudger or your finger to connect the microphone press connector to its socket on the board (located next to the front camera assembly).
    Vraag FixBot
    Voeg opmerking toe
  74. iPad Pro 13" Lock Button Replacement, Install the microphone connector cover: stap 74, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Install the microphone connector cover: stap 74, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Install the microphone connector cover: stap 74, afbeelding 3 van 3
    • Use tweezers to install the microphone connector cover into its slot beneath the front camera assembly bracket.
    • Set the cover down so it's aligned with its screw hole.
    • The cover may try to stick to the magnets next to it. Keep it in place for the next step.
    Vraag FixBot
    Voeg opmerking toe
  75. iPad Pro 13" Lock Button Replacement: stap 75, afbeelding 1 van 1
    • Use a JCIS or JIS 00 screwdriver to install the 1.3 mm‑long screw securing the microphone connector cover.
    Vraag FixBot
    Voeg opmerking toe
  76. iPad Pro 13" Lock Button Replacement, Install the screen: stap 76, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement, Install the screen: stap 76, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement, Install the screen: stap 76, afbeelding 3 van 3
    • Carefully align the bottom edge of the screen with the bottom edge of the iPad.
    • Position the screen so it sits into the lip on the edge of the iPad.
    • Before closing up the display, check to make sure that no cables are trapped beneath the screen. If they are, lift the top edge slightly (without straining the microphone cable), reposition the screen, and try again.
    Vraag FixBot
    Voeg opmerking toe
  77. iPad Pro 13" Lock Button Replacement: stap 77, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement: stap 77, afbeelding 2 van 2
    • Lower the screen into place, ensuring the screen's bottom edge stays flush with the bottom edge of the iPad.
    Vraag FixBot
    Voeg opmerking toe
  78. iPad Pro 13" Lock Button Replacement: stap 78, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 78, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 78, afbeelding 3 van 3
    • Press down across the bottom edge, then across the entire perimeter of the screen so it sits flush.
    Vraag FixBot
    Voeg opmerking toe
  79. iPad Pro 13" Lock Button Replacement, Heat the screen: stap 79, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Heat the screen: stap 79, afbeelding 2 van 2
    • To help the adhesive bond, apply heat to all four edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    Vraag FixBot
    Voeg opmerking toe
  80. iPad Pro 13" Lock Button Replacement, Press the screen adhesive: stap 80, afbeelding 1 van 2 iPad Pro 13" Lock Button Replacement, Press the screen adhesive: stap 80, afbeelding 2 van 2
    • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of the iPad. You can compensate for the camera bump by laying the iPad face-down and placing coins around its perimeter.
    • Alternatively, you can use screen vise clamps around the perimeter of your device to set the new adhesive.
    • Place the iPad screen-side-down on a soft, flat surface.
    • Apply tape to the back to protect its finish.
    Vraag FixBot
    Voeg opmerking toe
  81. iPad Pro 13" Lock Button Replacement: stap 81, afbeelding 1 van 3 iPad Pro 13" Lock Button Replacement: stap 81, afbeelding 2 van 3 iPad Pro 13" Lock Button Replacement: stap 81, afbeelding 3 van 3
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
    Vraag FixBot
    Voeg opmerking toe
  82. iPad Pro 13" Lock Button Replacement: stap 82, afbeelding 1 van 1
    • Stack multiple books or other heavy objects on the iPad.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad Pro 13" Answers Community for help.
Nick Schultz
58.387 Reputatie
316 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 223
