Ga door naar hoofdinhoud
Razer Blade Stealth 2017 Battery Replacement
Ethan Schlocker
Ethan Schlocker en 7 andere bijdragers
Voor het laatst geüpdatet op August 26, 2022
10 minuten
Eenvoudig
Uitgelichte studenten-handleiding
This guide outlines how to remove the lithium-ion battery in the Razer Blade Stealth 2017. Battery replacement may be necessary if the battery is not charging, not powering the computer, swollen, leaking, or not lasting as long as you would like. Some tools are required for this replacement.
Wat je nodig hebt
Reparatieset
Deze set bevat alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Toon meer…
  1. Razer Blade Stealth 2017 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Razer Blade Stealth 2017 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Use a Torx T5 screwdriver to remove the eight, 3mm screws on the bottom cover of the laptop.
    • Whenever you remove screws from the device, remember to save and label them.
  2. Razer Blade Stealth 2017 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom cover of the laptop by sliding it away from the hinge.
    • Do not force the cover up!
  3. Razer Blade Stealth 2017 Battery Replacement: stap 3, afbeelding 1 van 2 Razer Blade Stealth 2017 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use your fingernail to pry up and disconnect the battery from the motherboard.
  4. Razer Blade Stealth 2017 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the six, 5mm screws securing the battery.
  5. Razer Blade Stealth 2017 Battery Replacement: stap 5, afbeelding 1 van 2 Razer Blade Stealth 2017 Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove any tape attached to the battery.
    • Use the plastic spudger to pry out the battery.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
16 andere personen hebben deze handleiding voltooid.
Ethan Schlocker
353 Reputatie
1 Handleiding geschreven
Cal Poly, Team S11-G3, Regan Fall 2019 Lid van Cal Poly, Team S11-G3, Regan Fall 2019
CPSU-REGAN-F19S11G3
4 Leden
7 handleidingen geschreven
2 opmerkingen
ive done everything correctly and laptop boots up but now I have no battery percentage information. any solutions on how to fix?
fdf - Antwoord
Where did you get the replacement battery? The replacement we purchased for two Razer units about a year ago worked fine, but a replacement battery purchased online about a month and a half ago from Amazon is showing the same issue. Essentially, it's not detected by the operating system at all, or only very rarely. Looks like a bad batch of batteries from wherever these sellers are getting their supply.
DST - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 64
Altijd: 17,995
