Inleiding
Welcome! Does the battery in your controller not last as long as it used to or not at all? You must be looking to replace the battery in your Nintendo Switch Pro Controller, well you have come to the right place! Below you will find instructions for replacing the battery in your controller, read them carefully and follow the steps in order from one to six.
The Switch Pro Controller uses JIS screws, but you can use a Phillips screwdriver in a pinch. Be very careful not to strip the screws. iFixit's Phillips bits are designed to be cross-compatible with JIS-style screws.
NOTE: an improperly sync Switch Pro controller will not charge properly. To determine if your battery is faulty and needs replacing, you can first re-sync your controller and, while plugged in, check within the Switch controllers menu if it is charging properly.
CAUTION: The handling of any swollen batteries should be done with the utmost care. For information on how to identify, what to do with, how to handle, and how to dispose of swollen batteries follow the link below.
Wat je nodig hebt
Flip the controller over so the model stickers face the ceiling.
Use a JIS 00 driver or an official iFixit PH 00 driver to remove the two black flathead 8.4 mm-long screws that secure the handles, located at the ends of the handles.
Carefully remove the handle covers by pulling them away from the main body.
Use a Phillips screwdriver to remove the four silver 6.8 mm-long screws that secure the clear back plastic cover.
Carefully pry away the clear plastic cover using your fingernail.
Remove the lithium-ion battery by using a fingernail or plastic opening tool to pry it up on the left side.
For optimal performance, calibrate your newly installed battery after completing this guide.
19 andere personen hebben deze handleiding voltooid.
6 opmerkingen
easy peasy only have to recycle battery
Where can I buy genuine ctr-003 batteries in germany/europe?
