Lenovo ThinkPad X280 Touch Pad Replacement
Inleiding
Ga naar stap 1Are you experiencing issues with your Lenovo ThinkPad X280's touchpad like unresponsiveness or physical damage? Disassembling it for repairs or replacement is a straightforward process.
In this guide, you will learn how to access and remove the touchpad on your Lenovo ThinkPad X280. This process involves taking off the back cover and removing a few internal parts. Make sure you have all the tools you need and take your time.
Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
Remove the battery.
Carefully peel off the black tape covering the touchpad connector with your fingers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
