Ga door naar hoofdinhoud
Lenovo ThinkPad T480 Trackpad Replacement
Sarah Westberg
Sarah Westberg en een andere bijdrager
Voor het laatst geüpdatet op January 3, 2024
45 minuten - 2 uren
Gemiddeld
The trackpad or touchpad works as the mouse on your laptop device. You use your fingers to move the cursor and to select items on the screen. If the trackpad of your Lenovo ThinkPad T480 needs to be replaced, this guide will walk you through the steps.
Generally, trackpads are pretty durable. If you are having problems with your trackpad, first check to make sure that it is enabled as well as its other settings. If they are okay, you may need a new driver. If none of these things fix your issue it may be time to replace your trackpad.
Prior to beginning your repair, disable the internal battery, power off the laptop and finally unplug it from any external power source.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Lenovo ThinkPad T480 Trackpad Replacement, External Battery: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480 Trackpad Replacement, External Battery: stap 1, afbeelding 2 van 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Trackpad Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 2, afbeelding 3 van 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Trackpad Replacement, Back Cover: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480 Trackpad Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Trackpad Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 4, afbeelding 3 van 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Trackpad Replacement, Internal Battery: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T480 Trackpad Replacement, Internal Battery: stap 5, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 Trackpad Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 6, afbeelding 3 van 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Trackpad Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T480 Trackpad Replacement: stap 7, afbeelding 2 van 2
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
  8. Lenovo ThinkPad T480 Trackpad Replacement, Trackpad: stap 8, afbeelding 1 van 2 Lenovo ThinkPad T480 Trackpad Replacement, Trackpad: stap 8, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver remove the four 3.1 mm screws from the chassis.
    • In this guide additional components have been removed. Your laptop internals will look slightly different than the images in Steps 8-10 because of this.
  9. Lenovo ThinkPad T480 Trackpad Replacement: stap 9, afbeelding 1 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 9, afbeelding 2 van 3 Lenovo ThinkPad T480 Trackpad Replacement: stap 9, afbeelding 3 van 3
    • Using the black nylon spudger, remove the ribbon cable connected to the trackpad.
  10. Lenovo ThinkPad T480 Trackpad Replacement: stap 10, afbeelding 1 van 2 Lenovo ThinkPad T480 Trackpad Replacement: stap 10, afbeelding 2 van 2
    • Lift the chassis up and the trackpad will fall out.
Conclusie
Sarah Westberg
29.642 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.550 handleidingen geschreven
5 opmerkingen
Hi, I just tested with my T480, and the replacement looks exactly like this T580 guide, and is very easy in fact.
Open the shell, remove the battery (3 screws), see 3 of the 4 screws of the trackpad.
The fourth one is below the black plastic that you can see on the guide, and you can just lift it up. So you can move from step 11 to the end, the 4 screws are in fact directly accessible and changing the trackpad takes 1mn.
I don’t think I have a special T480 model, so if you are frightened by this guide, don’t hesitate to open yours to look… you may have to spend only 5 to 10mn on this operation :)
Den - Antwoord
Hi Den, thank you for letting me know the procedure can be simplified. I appreciate the reference to the T580 guide too! We always strive to make better guides :)
Sarah Westberg - Antwoord
According to the T480 Hardware Maintenance Manual page 84 "1160 Trackpad and trackpad cable" only the following steps need to be performed to remove the trackpad:
- "1010 Removable battery" on page 64
- 1030 Base cover assembly" on page 65
- 1040 Memory module" on page 68
This is much easier than the steps described here.
See https://download.lenovo.com/pccbbs/mobil...
John Longwood - Antwoord
Thanks Den and John! I finally got a chance to edit the steps. It's not perfect because I wasn't able to reshoot the photos but I removed the prerequisite guides that were unnecessary. I hope this helps.
Sarah Westberg -
I agree with the other commenters. See this YouTube video from June 2023, which shows that you only need to remove the battery and the secondary RAM card (if installed) to replace the trackpad:
https://youtu.be/hM1KZm_XZl0
Also, you may want to place a microfiber cloth between the laptop screen and keyboard while it's closed during this repair - this would ensure that the screen won't get scratched/damaged while the trackpad is falling out.
Tai Lam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 79
Afgelopen 30 dagen: 354
Altijd: 12,781
