Ga door naar hoofdinhoud
Google Pixel 3a Battery Replacement
Wat je nodig hebt
  1. Google Pixel 3a Battery Replacement, Screen: stap 1, afbeelding 1 van 3 Google Pixel 3a Battery Replacement, Screen: stap 1, afbeelding 2 van 3 Google Pixel 3a Battery Replacement, Screen: stap 1, afbeelding 3 van 3
    • Take note of the two seams on the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
    • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
    • Before you begin prying, note the following areas on the screen:
    • Screen flex cable: Do not pry deeper than instructed, or you risk damaging this cable.
    • Adhesive perimeter: Prying beyond the narrow perimeter without angling the pick will damage the display panel.
    Vraag FixBot
    Voeg opmerking toe
  2. Google Pixel 3a Battery Replacement: stap 2, afbeelding 1 van 1
    • Heat an iOpener and apply it to the right edge of the display for a minute.
    • You can also use a hair dryer to heat the edge until it's hot to the touch.
    Vraag FixBot
    Voeg opmerking toe
  3. Google Pixel 3a Battery Replacement: stap 3, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 3, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 3, afbeelding 3 van 3
    • Place a suction cup near the right edge of the screen.
    • Pull on the suction cup with strong steady force.
    • The adhesive can be stubborn. If you can't create a gap, heat the edge and try again.
    • Insert the pick into the gap, no more than 1 mm.
    Vraag FixBot
    Voeg opmerking toe
  4. Google Pixel 3a Battery Replacement: stap 4, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 4, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 4, afbeelding 3 van 3
    • This step shows how to insert the pick without damaging the OLED panel. Do this before you slice either long edges of the phone.
    • With the pick 1 mm in the gap, pivot the pick upwards to a steep angle.
    • At this angle, carefully push the pick into the gap about 1/4" (6 mm). The pick should slide in below the OLED panel.
    • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
    Vraag FixBot
    Voeg opmerking toe
  5. Google Pixel 3a Battery Replacement: stap 5, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 5, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 5, afbeelding 3 van 3
    • Slide the pick along the right edge, slicing through the adhesive.
    • Do not insert the pick more than 1/4" (6 mm), or you may damage the screen's flex cable.
    • Leave a pick in place to prevent the adhesive from resealing.
    Vraag FixBot
    Voeg opmerking toe
  6. Google Pixel 3a Battery Replacement: stap 6, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 6, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 6, afbeelding 3 van 3
    • As you slice around the bottom edge of the phone, do not insert the pick more than 1/4" (6 mm).
    • Slide the pick around the bottom right corner to slice through the adhesive.
    • If the corner feels hard to slice, apply a heated iOpener to the corner for a minute and try again.
    • Continue slicing along the bottom edge of the phone and around the left corner.
    Vraag FixBot
    Voeg opmerking toe
  7. Google Pixel 3a Battery Replacement: stap 7, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 7, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 7, afbeelding 3 van 3
    • Slice through the left edge of the phone, making sure to properly angle the pick below the OLED panel and insert it in no more than 1/4" (6 mm).
    • To angle the pick below the OLED panel, insert the point of the pick no more than 1 mm in, angle the pick upwards, and then slowly push the pick in 1/4".
    Vraag FixBot
    Voeg opmerking toe
  8. Google Pixel 3a Battery Replacement: stap 8, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 8, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 8, afbeelding 3 van 3
    • Slice along the top edge while keeping the pick no more than 5/16" (8 mm) in.
    Vraag FixBot
    Voeg opmerking toe
  9. Google Pixel 3a Battery Replacement: stap 9, afbeelding 1 van 2 Google Pixel 3a Battery Replacement: stap 9, afbeelding 2 van 2
    • With all of the edges cut, carefully hinge open the right edge of the screen.
    • Do not remove the screen. It is still attached to the phone by a flex cable near the left edge.
    • Use an opening pick to carefully cut through any remaining adhesive.
    Vraag FixBot
    Voeg opmerking toe
  10. Google Pixel 3a Battery Replacement: stap 10, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 10, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 10, afbeelding 3 van 3
    • With all of the adhesives cut, flip the attached screen glass side down and rest it on top of the phone. The screen flex cable should be loosely arched.
    Vraag FixBot
    Voeg opmerking toe
  11. Google Pixel 3a Battery Replacement: stap 11, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 11, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 11, afbeelding 3 van 3
    • Carefully peel the black tape covering the screen connector bracket.
    • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of electrical tape.
    • Remove the two 4.4 mm long T3 screws securing the screen connector bracket.
    • Remove the screen connector bracket.
    Vraag FixBot
    Voeg opmerking toe
  12. Google Pixel 3a Battery Replacement: stap 12, afbeelding 1 van 2 Google Pixel 3a Battery Replacement: stap 12, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the screen flex cable.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Vraag FixBot
    Voeg opmerking toe
  13. Google Pixel 3a Battery Replacement: stap 13, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 13, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 13, afbeelding 3 van 3
    • Remove the screen.
    • Carefully compare your replacement screen with your original part. You may need to transfer additional components (such as the speaker mesh) to the new part.
    • To reinstall the screen:
    • Follow this guide if you are using custom-cut adhesives.
    • If you are using double-sided tape such as Tesa tape, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    Vraag FixBot
    Voeg opmerking toe
  14. Google Pixel 3a Battery Replacement, Plastic Midframe: stap 14, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Remove the fourteen T3 screws of the following lengths securing the plastic midframe:
    • Twelve 4.3 mm silver T3 screws
    • Two 4.3 mm black T3 screws
    Vraag FixBot
    Voeg opmerking toe
  15. Google Pixel 3a Battery Replacement: stap 15, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 15, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 15, afbeelding 3 van 3
    • The midframe is still held in place by plastic clips.
    • Insert an opening pick into frame seam at the bottom of the phone. This seam sits between the plastic midframe and the back cover.
    • Slide the pick along the seam to release the clips holding the plastic midframe.
    Vraag FixBot
    Voeg opmerking toe
  16. Google Pixel 3a Battery Replacement: stap 16, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 16, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 16, afbeelding 3 van 3
    • Slide the opening pick along the left and right edges of the phone to release the midframe clips.
    • Lift the bottom edge of the plastic midframe up but do not remove the midframe. The midframe is still tethered to the phone by the fragile proximity sensor cable at the top edge.
    • To reinstall the plastic midframe, align the midframe to the back cover, and squeeze the perimeter of the phone with your fingers to snap the clips back into position.
    Vraag FixBot
    Voeg opmerking toe
  17. Google Pixel 3a Battery Replacement: stap 17, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 17, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 17, afbeelding 3 van 3
    • Use the point of a spudger to carefully pry up and disconnect the proximity sensor connector from the motherboard.
    • Your proximity sensor connector may have automatically disconnected itself when you lifted the midframe.
    • Remove the plastic midframe.
    Vraag FixBot
    Voeg opmerking toe
  18. Google Pixel 3a Battery Replacement: stap 18, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 18, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 18, afbeelding 3 van 3
    • This step shows how to reconnect the proximity sensor during re-assembly.
    • Align the top edge of the plastic midframe with the phone.
    • Use the point of a spudger to carefully align and push the proximity sensor connector onto the motherboard socket.
    • This takes a bit of patience and finesse. Once you have the connector in place, you can also use a finger to gently press the connector onto the socket.
    • Alternatively, you can remove the proximity sensor from the midframe to reattach it to the motherboard first.
    • Use the point of a spudger to carefully pry the proximity sensor out of its recess on the midframe. The sensor is lightly adhered to the midframe.
    • Remove the sensor from the midframe. Attach the sensor connector onto its motherboard socket.
    • Thread the sensor cable through the midframe and reposition the sensor in the recess. Press down with your finger to adhere the sensor back onto the midframe.
    Vraag FixBot
    Voeg opmerking toe
  19. Google Pixel 3a Battery Replacement, Google Pixel 3a Battery Disconnect: stap 19, afbeelding 1 van 3 Google Pixel 3a Battery Replacement, Google Pixel 3a Battery Disconnect: stap 19, afbeelding 2 van 3 Google Pixel 3a Battery Replacement, Google Pixel 3a Battery Disconnect: stap 19, afbeelding 3 van 3
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
    • Bend the battery flex cable slightly so that it will not accidentally make contact with the socket.
    Vraag FixBot
    Voeg opmerking toe
  20. Google Pixel 3a Battery Replacement, Battery: stap 20, afbeelding 1 van 2 Google Pixel 3a Battery Replacement, Battery: stap 20, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket above the battery.
    Vraag FixBot
    Voeg opmerking toe
  21. Google Pixel 3a Battery Replacement: stap 21, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 21, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 21, afbeelding 3 van 3
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its daughterboard socket below the battery.
    • Remove the interconnect cable.
    • During reassembly, be sure to attach the cable in the orientation as shown. The cable won't work if it's reversed.
    Vraag FixBot
    Voeg opmerking toe
  22. Google Pixel 3a Battery Replacement: stap 22, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 22, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 22, afbeelding 3 van 3
    • Use the point of a spudger to pry up and disconnect the left squeeze sensor connector from its socket on the motherboard above the battery.
    • Repeat the procedure for the right squeeze sensor connector near the power button.
    Vraag FixBot
    Voeg opmerking toe
  23. Google Pixel 3a Battery Replacement: stap 23, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 23, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 23, afbeelding 3 van 3
    • The battery is held in place by two stretch-release adhesive strips.
    • Carefully pull the right stretch-release adhesive's pull-tab from the bottom right corner of the battery.
    • Be very careful not to puncture the battery pack with the tweezers.
    Vraag FixBot
    Voeg opmerking toe
  24. Google Pixel 3a Battery Replacement: stap 24, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 24, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 24, afbeelding 3 van 3
    • Pull the tab at a shallow angle (close to parallel to the phone) with steady force. As the strip comes out, you can roll it around your tweezers.
    • Keep pulling until the entire strip comes free.
    Vraag FixBot
    Voeg opmerking toe
  25. Google Pixel 3a Battery Replacement: stap 25, afbeelding 1 van 3 Google Pixel 3a Battery Replacement: stap 25, afbeelding 2 van 3 Google Pixel 3a Battery Replacement: stap 25, afbeelding 3 van 3
    • Find the second stretch-release adhesive's pull-tab at the upper left corner of the battery.
    • Be careful not to puncture the battery with the tweezers.
    • Grasp the tab carefully with your tweezers.
    • Pull the tab at a shallow angle with steady force, rolling it as it gets longer, until the entire strip comes free.
    • If your adhesive strips did not pull out intact, insert an opening pick under the bottom edge of the battery and pry upwards to loosen the battery.
    • If needed, apply a heated iOpener to the back of the phone for a minute to loosen the battery adhesive.
    Vraag FixBot
    Voeg opmerking toe
  26. Google Pixel 3a Battery Replacement: stap 26, afbeelding 1 van 1
    • Remove the battery.
    • To install a replacement battery:
    • Remove any battery adhesive remaining on the phone.
    • Install replacement pull-stretch adhesives, or double-sided tape such as Tesa tape, in the phone's battery well where the original adhesive used to stick.
    • Gently set the battery in place. Temporarily connect the battery's connector to the motherboard to ensure that the battery is properly positioned.
    • Press the battery firmly in place with your fingers.
    • Disconnect the battery from the motherboard and resume re-assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
For optimal performance, calibrate your newly-installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our Google Pixel 3a Answers community for troubleshooting help.
66 andere personen hebben deze handleiding voltooid.
Arthur Shi
344.106 Reputatie
915 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
31.535 handleidingen geschreven
7Gids Commentaar
There is no link to a battery part to purchase, where can those be found?
Nir Hadjes - Antwoord Deel
Hi Nir,
We are in the process of getting replacement batteries. Because the phone is so new, supply chains have not gotten to offering replacements yet.
Arthur Shi - Antwoord Deel
Just completed this took, probably took me an hour and half from start to plugging the phone back in after I was done. Seems to have worked very well! Do be careful pulling the adhesive out from behind the battery. If it breaks, it can be a little trickier to get it out. I had to heat up the adhesive through the back of the phone, but once I did that I was able to very carefully pry the battery out, using a pick as a load distributor on the battery.
Zachary Tolar - Antwoord Deel
Same with me....one strip came out nicely, the other one just broke midway.
Andrea Airoldi - Antwoord Deel
If you are reusing the screen, this guide is too dangerous
1. You should heat the disaply evenly, not only at the right edge:
Using simple physics heating the display from all sideas will reduce the adhesive force of the glue overall, heating only one side will reduce the adhesive force on one side, thus you will need to use more force on the suction cup making things worse.
2. Start from bottom edge:
Most glue is present on bottom and top edges, also there is more space to insert the pick too cut the glue. It will give you more room to work on left and right edges where the gap is very less.
3. Don't use iopener
It's very hard to evenly heat the display with iopener. You basically heat one edge, run to the microwave to heat the iopener then place on the next edge, until then the first edge cools. Use hair dryer, or heat gun they heat the display evenly
Abhijeet Narvekar - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 122
Afgelopen 30 dagen: 612
Altijd: 116,592
