Ga door naar hoofdinhoud
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
20 Vragen Bekijk alle
How do I convert my hard drive from Raw to NTFS
Hi guys, my harddrive is now RAW, how do i convert it back to NTFS, I have been using a software called HDD Regenerator, its been a week still regenerating. Currently it has scanned 777mb out of 320gig.. Kindly assist with a software that is fast.
Is dit een goede vraag?
2 opmerkingen
do you need the data on it
door
What is the OS you are using on your system?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
DO NOT try on your own if you need the data. It's rarely partition or file system error, usually it's drive hardware issue.
Don't spin up a broken drive if the data on it is important, you'll just literally grind the data off the platter.
Was dit antwoord nuttig?
Score 4
2 opmerkingen:
No i do not want to recover any data from it
door
@therealkatt28 then just diskpart clean. If still not working, the drive is trashed.
door
Voeg je antwoord toe
Katt zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 70
