Ga door naar hoofdinhoud
The Kodak ESP 3 is an all-in-one photo color inkjet printer.
20 Vragen Bekijk alle
What does the red flashing light mean
Why does my printer have a red flashing light as soon as I turn it on it doesnt let me push any other button or control anything only option I have is to turn it back off
Is dit een goede vraag?
1 Opmerking
sam skalij what light is flashing? Does it flash at a sequence or is it flashing continuously
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
you did not tell us which light is flashing. If it is the On/Off light then according to the manual it is a very generic error code.
"Flashing Red
The printer has detected an error condition that needs your attention.
Please check for other lights and follow the instruction for that light.Check the status monitor (Windows) on your computer for a message."
So it is important to determine id you did anything prior to this i.e. change in printer cartridge etc. I'd start by checking the cartridges by reseating those.
1) Turn on the printer; take out the old used cartridges
2) Turn off the printer for a few minutes and disconnect the power cord
3) Connect the power cord and turn the printer on, when it says "insert inks", and then insert the compatible cartridges one by one, making sure the cartridges are sitting completely in the slots.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
sam skalij zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 10,707
