Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor de derde generatie Dodge Dakota (2005-2011). De opnieuw ontworpen Dakota uit 2005 deelde zijn platform met de nieuwe Dodge Durango SUV (die nu vergelijkbaar is met het Ram-platform).
Where is the blower motor and resistor
where is the motor and resistor on a Dodge Dakota 2011-also if the motor only works on HIGH, is that going to be the resistor or the motor....... everything works good on HIGH only
Is dit een goede vraag?
Score 5
1 Opmerking
97 dodge dakota when you turn on blower motor on truck dies if blower motor is left on truck will not start turn it off truck will start and run fine until you turn blower back on
door
Voeg een opmerking toe
5 Antwoorden
Gekozen oplossing
sandra reed, just checked the service manual and the blower has only one fuse for all settings. Besides the actual switch having failed (unlikely) you are most certainly having issues with the blower resistor.
DESCRIPTION
The blower motor resistor is mounted to the HVAC air inlet housing, directly behind the glove box. The blower motor resistor consists of a molded plastic mounting plate (1) with an integral wire connector receptacle (2). Concealed behind the mounting plate are coiled resistor wires contained within a ceramic heat sink (3). The blower motor resistor is accessed for service by removing the glove box from the instrument panel.
DIAGNOSIS AND TESTING BLOWER MOTOR RESISTOR
WARNING: On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury or death.
NOTE: For circuit descriptions and diagrams, refer to the appropriate wiring information. The wiring information includes wiring diagrams, proper wire and connector repair procedures, further details on wire harness routing and retention, as well as pin-out and location views for the various wire harness connectors, splices and grounds.
1. Disconnect and isolate the negative battery cable.
2. Disconnect the wire harness connector from the blower motor resistor (Refer to 24 - HEATING & AIR CONDITIONING/CONTROLS/RESISTOR-BLOWER MOTOR - REMOVAL).
3. Using an ohmmeter, check for continuity between all of the blower motor resistor terminals. In each case there should be continuity. If OK, repair the wire harness circuits between the blower motor switch and the blower motor resistor or blower motor as required. If not OK, replace the faulty blower motor resistor.
REMOVAL
WARNING: On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury or death.
WARNING: The blower motor resistor may get very hot during normal operation. If the blower motor was turned on prior to servicing the blower motor resistor, wait five minutes to allow the resistor to cool before performing diagnosis or service. Failure to take this precaution can result in personal injury or death.
2. Remove the glove box (Refer to 23 - BODY/INSTRUMENT PANEL/GLOVE BOX - REMOVAL).
3. Disengage the wire harness connector locking tab and disconnect the wire harness connector (1) from the blower motor resistor (2).
4. Remove the two screws (3) that secure the blower motor resistor to the HVAC housing (4).
5. Remove the blower motor resistor from the HVAC housing.
Afbeelding
Was dit antwoord nuttig?
Score 4
4 opmerkingen:
How do I remove the glove box, and what is "23", and where do I find that info?
door
Hi @daveh3 ,
If you have a 2011 Dodge here's a video that shows how to remove the glove box.
23 sounds like the referral to Section 23 in the service manual which is not shown in the answer but from which the information was taken. That's how it is usually written in service manuals
door
I have a 2006 Dakota. I need to replace the resistor. I dropped the glove box & see no resistor as described & its not under the dash either next to blower motor. I'd love to see an actual video of someone removing the resistor on a 2006 Dakota. I checked YouTube & there's none there.
door
I am sure it is too late for you to benefit from this info but here goes. I just replaced both the motor and resistor. my motor was squealing and only worked on high. Unfortunately for me I replaced the motor first only to figure out that it was the resistor. I left the new motor in because it was a bit of a pain to remove . The resistor is located behind the glovebox. When you drop your glovebox look along the top of the motor housing and follow the 4 wires running to the right side they are for the resistor. mine had 2 number 15 torx holding it in. I removed it with the wires attached but installing it was easier without them attached.
I hope this helps.
door
Ok the motor is not a problem. Locate any and all fuse banks, then any and all fuses related to the low and med. setings. Replace any blowen fuses(burnt center with the metal strip broken)with like fuse(20 with 20 only)if you replace with a higher or lower fuse(20 with 30 or 10)you will damage your electric system. I have had your isue in a 99 Durango. i hope this helps.
Score 1
3 opmerkingen:
It's NOT the fuses. I've changed all of that and there is still a problem. Blower motor is pulling too many amps. I've replaced everything and still have the issue on my Dakota and Durango. Dodge knows this is an issue. It's a "grounding" issue and they have it grounded to the ignition switch. I don't want to pull the dash either. Looking for a way to wire direct to bypass all the Dodge "junk".
door
I agree, its not the fuses. I'm having the same problem. Waiting for a solution. The source of the problem that is melting the resistors and harnesses. Can you redirect a ground somewhere else?
door
I'm having the same issue tore dash out even.... I'm going to run wire from ground to toggle switch than to ground on kicker panel to turn off and on... one speed...mount under dash... problem solved
door
Here is a great video on how to do the entire procedure.
https://www.youtube.com/watch?v=-M6v2Ydf...
I have an 01 Durango and an 04 Dakota, both have the same issue. I've replaced countless resistors, wiring harnesses and blower motors. STILL have the same problem. All of this is wired into the ignition switch. I'm not wanting to replace the ignition. Dodge knows there is a major problem with this issue. It happens on all years and makes of Dodge. Most forums tell you the same thing. Change this, change that. I want to bypass all of it and wire direct. I'm sick of throwing my money out the window and Dodge doing nothing about it. And wouldn't you know, they go out at the most inopportune times. No AC in the heat, and no heat in the winter. Dodge needs to get better "engineers"!!!!
Hi @valmangal,
Not a video but here are the instructions for testing and replacing the blower resistor from the 2005 -2011 Dodge Dakota Service Repair Manual, Heating and Air Conditioning section, that may be of some help.
Afbeelding
Afbeelding
(click on images to enlarge for better viewing)
Voeg je antwoord toe
sandra reed zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 52
Altijd: 23,551
