Ga door naar hoofdinhoud
Demontage en reparatiehandleidingen voor een brede waaier aan fototoestellen.
Transfer pictures to phone from Covert field camera
How do I transfer pictures from my camera, which has a standard SD card to my phone which has a microSD card?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Hey Hunter,
If you want to get your photos from your camera to your phone, the easiest way would be to plug your camera/SD card into your computer, and transfer them onto your computer. Depending on what phone you have, you should be able to plug your phone into your computer via USB, and transfer the photos from your computer to your phone.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I am trying to find a way to do this in the field where I won't have my computer.
door
Hi hunter, get a micro-sd card with a full size sd card adapter. Put the sd card and the adapter into your camera, and when it comes time to transfer, pull out the adapter, take the micro-sd card from the adapter, and place it in your smartphone, and bam! That should work, do it with my nikon all the time.
Front facing camera is not working properly on my zte blade zmax phone
Voeg je antwoord toe
Hunter zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 164
