Ga door naar hoofdinhoud
iPhone X Screen Replacement
Wat je nodig hebt
Video overzicht
    1. iPhone X Screen Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
      • If the screws are stripped or damaged, replace the screws.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone X Screen Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone X Screen Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone X Screen Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone X Screen Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone X Screen Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone X Screen Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone X Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone X Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone X Screen Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone X Screen Replacement: stap 5, afbeelding 1 van 3 iPhone X Screen Replacement: stap 5, afbeelding 2 van 3 iPhone X Screen Replacement: stap 5, afbeelding 3 van 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone X Screen Replacement: stap 6, afbeelding 1 van 3 iPhone X Screen Replacement: stap 6, afbeelding 2 van 3 iPhone X Screen Replacement: stap 6, afbeelding 3 van 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick under the screen and the plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone X Screen Replacement: stap 7, afbeelding 1 van 1
      • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
      • If you use a hairdryer or heat gun, do not heat to much because that can result in damaging the screen.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone X Screen Replacement: stap 8, afbeelding 1 van 2 iPhone X Screen Replacement: stap 8, afbeelding 2 van 2
      • If using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone X Screen Replacement: stap 9, afbeelding 1 van 3 iPhone X Screen Replacement: stap 9, afbeelding 2 van 3 iPhone X Screen Replacement: stap 9, afbeelding 3 van 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • Insert an opening pick into the gap under the screen's plastic bezel, not the screen itself.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone X Screen Replacement: stap 10, afbeelding 1 van 3 iPhone X Screen Replacement: stap 10, afbeelding 2 van 3 iPhone X Screen Replacement: stap 10, afbeelding 3 van 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone X Screen Replacement, Screen information: stap 11, afbeelding 1 van 1
      • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone X Screen Replacement: stap 12, afbeelding 1 van 3 iPhone X Screen Replacement: stap 12, afbeelding 2 van 3 iPhone X Screen Replacement: stap 12, afbeelding 3 van 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Vraag FixBot
      Voeg opmerking toe
    11. iPhone X Screen Replacement: stap 13, afbeelding 1 van 3 iPhone X Screen Replacement: stap 13, afbeelding 2 van 3 iPhone X Screen Replacement: stap 13, afbeelding 3 van 3
      • The top edge of the display is secured with both glue and clips.
      • Slide the opening pick around the top corner of the display, while gently pulling or wiggling the display down in the direction of the Lightning port.
      • The clips will break if you use too much force. Work carefully and be patient.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      • Slide the pick to the opposite corner and cut any remaining adhesive securing the display.
      Vraag FixBot
      Voeg opmerking toe
    12. iPhone X Screen Replacement: stap 14, afbeelding 1 van 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Vraag FixBot
      Voeg opmerking toe
    13. iPhone X Screen Replacement: stap 15, afbeelding 1 van 3 iPhone X Screen Replacement: stap 15, afbeelding 2 van 3 iPhone X Screen Replacement: stap 15, afbeelding 3 van 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • As pictured, make sure the frame comes off with display and doesn't get stuck in the device.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone X Screen Replacement, Display Assembly: stap 16, afbeelding 1 van 1
      Magnetic Project Mat
      $19.95
      • Remove five Y000 screws securing the logic board connector bracket, of the following lengths:
      • Three 1.1 mm screws
      • One 3.1 mm screw
      • One 3.7 mm screw
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone X Screen Replacement: stap 17, afbeelding 1 van 1
      • Remove the bracket.
      • The bracket may be lightly adhered in place. Lift gently but firmly to separate it.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone X Screen Replacement: stap 18, afbeelding 1 van 2 iPhone X Screen Replacement: stap 18, afbeelding 2 van 2
      • Use the point of a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone X Screen Replacement: stap 19, afbeelding 1 van 2 iPhone X Screen Replacement: stap 19, afbeelding 2 van 2
      • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone X Screen Replacement: stap 20, afbeelding 1 van 2 iPhone X Screen Replacement: stap 20, afbeelding 2 van 2
      • Use the point of a spudger or a fingernail to disconnect the OLED panel cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone X Screen Replacement: stap 21, afbeelding 1 van 2 iPhone X Screen Replacement: stap 21, afbeelding 2 van 2
      • Use the point of a spudger to pry the digitizer cable connector up from its socket.
      • This connector's recessed location makes it tricky to reconnect. Take your time and align it carefully, then gently press it into place with your fingertip—first one side, then the other. You should feel it click into place.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone X Screen Replacement: stap 22, afbeelding 1 van 3 iPhone X Screen Replacement: stap 22, afbeelding 2 van 3 iPhone X Screen Replacement: stap 22, afbeelding 3 van 3
      • The front panel sensor assembly flex cable is lightly adhered in place.
      • Carefully lift the cable until the adhesive separates.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone X Screen Replacement: stap 23, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
    1. iPhone X Screen Replacement, Earpiece Speaker and Front Sensor Assembly: stap 24, afbeelding 1 van 1
      • Remove the 1.2 mm Y000 screw on the back of the display assembly, near the infrared camera port.
      Vraag FixBot
      Voeg opmerking toe
    2. iPhone X Screen Replacement: stap 25, afbeelding 1 van 3 iPhone X Screen Replacement: stap 25, afbeelding 2 van 3 iPhone X Screen Replacement: stap 25, afbeelding 3 van 3
      • Beneath the screw you just removed lies a small metal grounding clip. If it didn't already come out along with the screw, remove it now.
      • During reassembly, orient the clip as shown. Hold the clip in position while you install and tighten the screw.
      Vraag FixBot
      Voeg opmerking toe
    3. iPhone X Screen Replacement: stap 26, afbeelding 1 van 1
      • Remove two more Y000 screws securing the speaker/sensor assembly:
      • One 1.6 mm screw
      • One 1.3 mm screw
      Vraag FixBot
      Voeg opmerking toe
    4. iPhone X Screen Replacement: stap 27, afbeelding 1 van 2 iPhone X Screen Replacement: stap 27, afbeelding 2 van 2
      • The earpiece speaker is lightly adhered in place.
      • Using a spudger, gently pry under the top edge of the speaker assembly, and flip it over—down and away from the top edge of the display.
      • The speaker remains attached via a very thin flex cable. Be careful not to strain or damage the cable.
      Vraag FixBot
      Voeg opmerking toe
    5. iPhone X Screen Replacement: stap 28, afbeelding 1 van 1
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
      Vraag FixBot
      Voeg opmerking toe
    6. iPhone X Screen Replacement: stap 29, afbeelding 1 van 3 iPhone X Screen Replacement: stap 29, afbeelding 2 van 3 iPhone X Screen Replacement: stap 29, afbeelding 3 van 3
      • Carefully slide the flat edge of your spudger underneath the flex cable below the microphone.
      • Twist gently to separate the microphone, while being careful not to strain or damage the flex cable.
      • If needed, use the point of the spudger to finish separating the microphone from its notch in the front panel.
      Vraag FixBot
      Voeg opmerking toe
    7. iPhone X Screen Replacement: stap 30, afbeelding 1 van 3 iPhone X Screen Replacement: stap 30, afbeelding 2 van 3 iPhone X Screen Replacement: stap 30, afbeelding 3 van 3
      • Working left to right, slide an opening pick beneath the flex cable and underneath the proximity sensor + flood illuminator module.
      • Gently wiggle and lift to separate the module from its notch in the front panel.
      • It's helpful to lift and hold the speaker out of the way for access. Just be careful not to pull on the thin flex cable while you work.
      Vraag FixBot
      Voeg opmerking toe
    8. iPhone X Screen Replacement: stap 31, afbeelding 1 van 2 iPhone X Screen Replacement: stap 31, afbeelding 2 van 2
      • Use tweezers to wiggle the ambient light sensor and lift it from its notch in the display.
      • The sensor remains attached to the rest of the sensor assembly via a very thin flex cable. Be careful not to strain or damage the cable.
      Vraag FixBot
      Voeg opmerking toe
    9. iPhone X Screen Replacement: stap 32, afbeelding 1 van 3 iPhone X Screen Replacement: stap 32, afbeelding 2 van 3 iPhone X Screen Replacement: stap 32, afbeelding 3 van 3
      • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
      • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
      • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
      • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
      Vraag FixBot
      Voeg opmerking toe
    10. iPhone X Screen Replacement: stap 33, afbeelding 1 van 3 iPhone X Screen Replacement: stap 33, afbeelding 2 van 3 iPhone X Screen Replacement: stap 33, afbeelding 3 van 3
      • Remove the earpiece speaker and front sensor assembly.
      • During reassembly, check the position of the black plastic module containing these components:
      • Proximity sensor
      • Flood illuminator
      • The module must be positioned so that these components are not obstructed by any adhesive.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
711 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
454.165 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
78.338 handleidingen geschreven
100Gids Commentaar
Great Guide, professional and honest to proper procedures, good work Jeff Suovanen.
Alec - Antwoord Deel
does a new display not come with faceid sensor? so you have to remove this and instal it again with the new glass?
Scott Miller - Antwoord Deel
yeah, also face id will not work if you don’t replace the flex. Just be careful
jump1n - Antwoord Deel
FaceID is diabled if the hardware detects a new FaceID module. Using the original parts avoids this issue so that the FaceID feature is’t disabled. This could prevent a FaceID module from being replaced with a doctored or unlicensed part which may fail to provide the same level of security than the Apple supplied part.
Sandman619 - Antwoord Deel
Sorry, if I replace my iPhone X Lcd, will the Face ID stop working?
Valentine Ebuka - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 79
Afgelopen 7 dagen: 604
Afgelopen 30 dagen: 2,530
Altijd: 1,425,941
