Ga door naar hoofdinhoud
iPhone 7 Plus Speaker Replacement
Wat je nodig hebt
  1. iPhone 7 Plus Speaker Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Vraag FixBot
    Voeg opmerking toe
  2. iPhone 7 Plus Speaker Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Vraag FixBot
    Voeg opmerking toe
  3. iPhone 7 Plus Speaker Replacement, Anti-Clamp instructions: stap 3, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement, Anti-Clamp instructions: stap 3, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement, Anti-Clamp instructions: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Vraag FixBot
    Voeg opmerking toe
  4. iPhone 7 Plus Speaker Replacement: stap 4, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 4, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 4, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Vraag FixBot
    Voeg opmerking toe
  5. iPhone 7 Plus Speaker Replacement: stap 5, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement: stap 5, afbeelding 2 van 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Vraag FixBot
    Voeg opmerking toe
  6. iPhone 7 Plus Speaker Replacement, Heat the display: stap 6, afbeelding 1 van 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
    Vraag FixBot
    Voeg opmerking toe
  7. iPhone 7 Plus Speaker Replacement, Separate the display: stap 7, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement, Separate the display: stap 7, afbeelding 2 van 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Vraag FixBot
    Voeg opmerking toe
  8. iPhone 7 Plus Speaker Replacement: stap 8, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 8, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 8, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Vraag FixBot
    Voeg opmerking toe
  9. iPhone 7 Plus Speaker Replacement: stap 9, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 9, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 9, afbeelding 3 van 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    Vraag FixBot
    Voeg opmerking toe
  10. iPhone 7 Plus Speaker Replacement, Screen information: stap 10, afbeelding 1 van 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
    Vraag FixBot
    Voeg opmerking toe
  11. iPhone 7 Plus Speaker Replacement: stap 11, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 11, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 11, afbeelding 3 van 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Vraag FixBot
    Voeg opmerking toe
  12. iPhone 7 Plus Speaker Replacement: stap 12, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement: stap 12, afbeelding 2 van 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Vraag FixBot
    Voeg opmerking toe
  13. iPhone 7 Plus Speaker Replacement: stap 13, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 13, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 13, afbeelding 3 van 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  14. iPhone 7 Plus Speaker Replacement: stap 14, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement: stap 14, afbeelding 2 van 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Vraag FixBot
    Voeg opmerking toe
  15. iPhone 7 Plus Speaker Replacement: stap 15, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 15, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 15, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Vraag FixBot
    Voeg opmerking toe
  16. iPhone 7 Plus Speaker Replacement, Battery Disconnection: stap 16, afbeelding 1 van 1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
    Vraag FixBot
    Voeg opmerking toe
  17. iPhone 7 Plus Speaker Replacement: stap 17, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement: stap 17, afbeelding 2 van 2
    • Remove the lower display cable bracket.
    Vraag FixBot
    Voeg opmerking toe
  18. iPhone 7 Plus Speaker Replacement: stap 18, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 18, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 18, afbeelding 3 van 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
    Vraag FixBot
    Voeg opmerking toe
  19. iPhone 7 Plus Speaker Replacement, Display Assembly: stap 19, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement, Display Assembly: stap 19, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement, Display Assembly: stap 19, afbeelding 3 van 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    Vraag FixBot
    Voeg opmerking toe
  20. iPhone 7 Plus Speaker Replacement: stap 20, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 20, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 20, afbeelding 3 van 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
    Vraag FixBot
    Voeg opmerking toe
  21. iPhone 7 Plus Speaker Replacement: stap 21, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement: stap 21, afbeelding 2 van 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Vraag FixBot
    Voeg opmerking toe
  22. iPhone 7 Plus Speaker Replacement: stap 22, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  23. iPhone 7 Plus Speaker Replacement, Speaker: stap 23, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement, Speaker: stap 23, afbeelding 2 van 2
    • Use a thin pry tool or tweezers to carefully pry up and disconnect the upper coaxial cable connector from the logic board.
    • There are two coaxial connectors in close proximity. Disconnect the one nearest the battery connector.
    • During reassembly, this can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
    Vraag FixBot
    Voeg opmerking toe
  24. iPhone 7 Plus Speaker Replacement: stap 24, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement: stap 24, afbeelding 2 van 2
    • Carefully de-route the coaxial cable you just disconnected from the small metal clip holding it to the logic board.
    Vraag FixBot
    Voeg opmerking toe
  25. iPhone 7 Plus Speaker Replacement: stap 25, afbeelding 1 van 2 iPhone 7 Plus Speaker Replacement: stap 25, afbeelding 2 van 2
    • Use tweezers or the point of your spudger to pry both coaxial cables out of the metal clip holding them on the side of the speaker.
    Vraag FixBot
    Voeg opmerking toe
  26. iPhone 7 Plus Speaker Replacement: stap 26, afbeelding 1 van 1
    • Remove the five Phillips screws securing the speaker:
    • Three 1.3 mm screws
    • One 2.3 mm screw
    • One 3.3 mm screw
    Vraag FixBot
    Voeg opmerking toe
  27. iPhone 7 Plus Speaker Replacement: stap 27, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  28. iPhone 7 Plus Speaker Replacement, Wi-Fi Diversity Antenna: stap 28, afbeelding 1 van 1
    • Warm the lower speaker area where the antenna is adhered with an iOpener, hair dryer, or heat gun, until it's slightly too hot to touch.
    • Heat helps soften the adhesive securing the antenna.
    Vraag FixBot
    Voeg opmerking toe
  29. iPhone 7 Plus Speaker Replacement: stap 29, afbeelding 1 van 3 iPhone 7 Plus Speaker Replacement: stap 29, afbeelding 2 van 3 iPhone 7 Plus Speaker Replacement: stap 29, afbeelding 3 van 3
    • Slide an opening pick between the antenna and the speaker on the right side, and carefully separate the adhesive underneath.
    Vraag FixBot
    Voeg opmerking toe
  30. iPhone 7 Plus Speaker Replacement: stap 30, afbeelding 1 van 1
    • Rotate the speaker and re-insert your opening pick on the opposite side.
    • Separate any remaining adhesive securing the antenna.
    • If necessary, re-heat the adhesive until it separates easily.
    Vraag FixBot
    Voeg opmerking toe
  31. iPhone 7 Plus Speaker Replacement: stap 31, afbeelding 1 van 1
    • Remove the Wi-Fi diversity antenna from the speaker.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
58 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
453.473 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
28.236 handleidingen geschreven
6Gids Commentaar
Thanks Jeff, this guide helped me complete the repair, even the fiddly bits with the diversity antennae. Oh the joy of hearing the “by the seaside “ ringtone from a previously mute iPhone. :D
Kola - Antwoord Deel
Hi, I have completed this but the speaker option is still not available and am not able to record videos, and basically not able to hear anything when placing a call. should i replace the earpiece speaker as well?
bhargava perni - Antwoord Deel
Thank you Jeff! I followed this guide and everything went smoothly. Used this to fix my friend’s iPhone when her phone went silent. She says everything is working as it should be. Thanks again from her and I.
Maganafixes - Antwoord Deel
Hallo zusammen, ich habe den Umbau wie oben vorgenommen, jedoch kommt unten kein Ton wenn mich jemand anruft. Woran kann das liegen?
Kann es noch eine andere Ursache geben außer den Lautsprecher zu tauschen?
Freue mich über eine Rückmeldung.
iannarrig - Antwoord Deel
People still can’t hear me when I call. However, if I switch to loudspeaker they can. Did I miss a connection or do I need another part?
mtderosier - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 218
Altijd: 83,157
