Ga door naar hoofdinhoud
iPhone 6s Vervanging van de oorstukspeaker
Wat je nodig hebt
  1. iPhone 6s Vervanging van de oorstukspeaker, Pentalobe schroeven: stap 1, afbeelding 1 van 1
    • Ontlaad, voordat je begint de telefoon uit elkaar te halen, je batterij tot onder de 25%. Een geladen lithium-ion batterij kan in brand vliegen en/of exploderen als deze per ongeluk wordt doorboord.
    • Schakel je iPhone uit voordat je begint deze uit elkaar te halen.
    • Verwijder de twee 3.4 mm lange Pentalobe schroeven aan beide kanten van de Lightning-poort.
    Make sure you use the correct screw driver tip to remove these screws, which for the iPhone 6s Plus is the P2, otherwise you may strip the tip of the screw making it 10 times harder to remove. If once the screw is lose, it will not come off, use a magnet to remove it.
    Miguel Perez - Antwoord
    If I do it by myself, will it damage the water resistant strip?
    I know iphone 7 have it ,but I am not sure 6s plus have it.
    Ganqian Zhu - Antwoord
    iPhone 6s has an adhesive gasket under the display, similar to the iPhone 7—however, it doesn’t add much in the way of waterproofing since the 6s has non-sealed openings in other parts of the phone. Water resistance on the 6s is primarily internal (seals around the logic board connectors, etc.). It may still be worthwhile to replace the adhesive on the 6s in order to help keep the display firmly seated so it doesn’t move/wobble at all under pressure, but the phone will continue to work fine whether you replace the adhesive or not.
    Jeff Suovanen -
    Salve nella procedura iniziale di smontaggio display con la ventosa non è menzionato il fatto di scaldare i lati del display per “ammorbidire” la striscia che incolla il display alla scocca.
    Non è necessaria la cosa o è consigliabile ?
    grazie
    Hello, in the initial disassembling procedure with the suction cup, it is not mentioned how to heat the sides of the display to "soften" the strip that glues the display to the body.
    Is not the thing necessary or is it advisable?
    thank you
    Daniele - Antwoord
    You’ve probably received your answer by now but for future enquirers, it does help the process of taking the screen off if heat is applied to the screen. If you have a hair Dryer use that on a low setting to heat the edges of the screen until it’s almost too hot to touch then slip very thin metal spudger around the edge to cut the adhesive. The carefully lift the screen with the help of the spudger and continue with your repair
    Cheers Wayne
    Wayne Lyell -
    How do I know that the Battery has ZERO Charging Cycles on it when it arrives ? Is there a (downside) to Higher Capacity batteries ? It is INCREDIBLY DIFFICULT to maintain a “Zero Chinese Products Lifestyle”, so how do I know that I’m not getting a deficient Chinese battery, potentially a refurb. battery ?
    integritybuilders - Antwoord
    When your repair is complete, you can use coconutBattery to check your new battery stats and cycle count. (A properly tested battery may already have a charge cycle or two on it.) Avoid higher capacity batteries on iPhones—they’re generally either gimmicks, unsafe, or both. As far as the quality of the part, that comes down to how much you trust your supplier and whether they guarantee the product.
    Jeff Suovanen -
    So I need to empty the battery to zero percent?
    johnpatrickanat - Antwoord
    Below 25%, exactly as stated in the instructions. There’s no benefit to draining it further than that, and in fact you’ll slightly shorten the service life of the battery by draining it all the way to zero. Follow the instructions exactly as written—if you go off-script, you’re a lot more likely to break something.
    Jeff Suovanen -
    So my screen shattered completely and the screen first had colored lines on tge while right side then it went out completely. If i get an lcd and digitizer replacement I'd that oing to fix it
    shellietheleo - Antwoord
    I would initially recommend a well-lit, comfortable area and placing the screws on a white piece of paper with the screw sizes written down (apparently there are magnetic mats, also). Also, I found placing the phone on a paper towel is good so that if a screw is dropped, it will lessen the likelihood of bouncing away.
    Lou Fazio - Antwoord
    I recommend that, before you even lift a screwdriver or plug in the hair dryer, get a piece of paper and a pencil. As you unscrew and remove the parts, write the size and/or number for that step and put them by their label. I also used a microscope to identify the screw heads (I'm 75 and my vision is not what it used to be). Laying them out in order, I just went backwards when putting them all back in. I used an anti-static cleaning cloth instead of paper, but I should think they both will work.
    N.B.: my kit had a nice pretty blue plastic sheet with a black outline on it. It was only when I put the whole phone back together and was packing up the supplies and tools that I realized it was a replacement gummi seal. A LABEL WOULD BE VERY USEFUL HERE!
    I am a retired engineer, and aside from the size of the bits and bobs, it was a piece of cake! Thanks...you saved me $75!
    P. Roberts - Antwoord
  2. iPhone 6s Vervanging van de oorstukspeaker, Instructies voor de anti-klem: stap 2, afbeelding 1 van 3 iPhone 6s Vervanging van de oorstukspeaker, Instructies voor de anti-klem: stap 2, afbeelding 2 van 3 iPhone 6s Vervanging van de oorstukspeaker, Instructies voor de anti-klem: stap 2, afbeelding 3 van 3
    • De volgende twee stappen introduceren de Anti-Klem, een handige tool die we aanraden aan iedereen die regelmatig reparaties uitvoert. Als je de Anti-Klem niet gebruikt, sla dan de volgende drie stappen over voor een alternatieve methode.
    • Voor uitgebreider instructies voor het gebruik van de Anti-Klem, lees je deze handleiding door.
    • Trek de blauwe hendel naar achteren zodat de anti-klem vrij kan bewegen. (Op deze manier deactiveer je de openingsstand van de anti-klem.)
    • Schuif de armen over de linker- of rechterzijde van je iPhone.
    • Plaats de zuignappen dichtbij de onderkant van de telefoon—één op de voorkant en één aan de achterkant.
    • Druk beide zuignappen aan, om zuigkracht uit te oefenen op de gewenste plek.
    • Als het oppervlak waarop de zuignappen zich moeten vastzuigen te glad is, kun je wat tape gebruiken voor meer grip.
    I found that the single suction cup from the kit worked very well. It didn’t take that much force to separate the front panel from the phone. I think any suction cup that you are able to get a firm grip on will probably work as well. There isn’t any adhesive holding the front panel in. It just snaps in and out. If you have a cracked screen and no screen protector, it may be hard to get a good suction seal. If that’s the case, someone else here suggested applying clear tape to the front glass to get a good surface for applying the suction cup. In my case, I already had a screen protector that was still intact so the suction cup sealed easily.
    fiftysomething - Antwoord
    WORKED PERFECTLY… easy, no harm at all…. thanks a lot
    carlos restrepo -
  3. iPhone 6s Vervanging van de oorstukspeaker: stap 3, afbeelding 1 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 3, afbeelding 2 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 3, afbeelding 3 van 3
    • Trek het blauwe handvat naar voren om de armen van de anti-klem te vergrendelen.
    • Draai het handvat 360 graden met de klok mee of tot de zuignappen uit beginnen te rekken.
    • Zorg dat de zuignappen op één lijn met elkaar zitten voordat je begint met het openen van het toestel. Als je ziet dat de zuignappen niet meer op één lijn zitten, maak je ze los en breng je ze weer op de juiste positie aan.
    • Zodra de anti-klem een opening heeft weten te creëren die groot genoeg is, steek je een openingsplectrum in de opening.
    • Als de anti-klem er niet in slaagt een opening te creëren die groot genoeg is voor je plectrum gebruik je meer warmte en draai je het blauwe handvat een kwartslag met de klok mee.
    • Draai het handvat nooit verder dan een kwartslag per keer en wacht een minuut voordat je de anti-klem weer besluit aan te draaien. Laat de anti-klem het werk voor je doen.
    • Sla de volgende drie stappen over.
  4. iPhone 6s Vervanging van de oorstukspeaker, Openingsprocedure: stap 4, afbeelding 1 van 1
    • Het is een optie om de onderkant van de iPhone gedurende een minuut te verwarmen met het gebruik van een iOpener of een föhn.
    • Warmte helpt de lijm die het scherm bevestigt te verzachten, waardoor het openen van de telefoon makkelijker zal zijn.
    This is important. I’ve serviced a lot of iphones/ipads for my family as a hobby in the past.
    The adhesive was so tight, I cracked the screen trying to pull it/pry it off.
    I highly suggest heating at least the bottom edge enough to soften the adhesive
    garbage911garbage - Antwoord
    I didn’t have an iOpener, nor a heat gun; however I do have a small personal size hand pillow filled with feed corn. Two minutes in the nuke machine got it plenty warm, and smelled like fresh popcorn too.
    bradiac - Antwoord
    I would suggest that you are not shy with the hairdryer. A high heat on the bottom of the phone for at least a minute, if not more, if required.
    Mark Taberham - Antwoord
  5. iPhone 6s Vervanging van de oorstukspeaker: stap 5, afbeelding 1 van 1
    • Het openen van het scherm van de 6s Plus zal ervoor zorgen dat er een strip aan lijm rondom de rand van de telefoon los zal komen. Zorg dat je, als je de lijm wilt vervangen, vervangende lijm klaar hebt liggen voordat je verdergaat. Het is mogelijk om de reparatie te voltooien zonder de lijm te vervangen en je zult hierbij geen functies inleveren.
    • Druk een zuignap op de linker onderhoek van de schermmodule.
    • Als je scherm gebarsten is, kun je het beplakken met een laag doorzichtige tape zodat de zuignap zich wél vast kan zuigen. Als alternatief kun je de tape ook gebruiken in plaats van de zuignap. Als het alsnog niet lukt, kun je de zuignap aan het scherm vastlijmen met behulp van secondelijm.
    take out screws first!!
    Yoav Karmon - Antwoord
    Make sure you use the right screw driver tip for i phone 6s Plus, which is the P-2. If the screw will not come off once is lose, try using a magnet.
    My cracked screen prevented the suction cup from sealing. SOLUTION: With a piece of clear packing tape across the screen, the suction cup will seal and pull.
    Jim Cowles - Antwoord
    I broke my iphone screen in the first step!
    Pierre Bertram - Antwoord
    This screen removal step got more wrestley than I anticipated. The adhesive is quite strong. I used a flat-ended razor tool that I have to begin the prying - I don’t know how I would have got it started without this.
    Ok - just got my battery replacement kit and even got the opening kit for added insurance just in case. Settled down to startwork after carefully cleaning my (immaculate) screen - no scratches or anything, with rubbing alcohol, removing screws and warming with a hair dryer, only to find the suction cup provided in the kit is worse than useless! It won’t stick to the screen well at all. When it does - it pops off at the lightest pull :-( Now what do I do to get this started?!
    CoffeeCup - Antwoord
  6. iPhone 6s Vervanging van de oorstukspeaker: stap 6, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 6, afbeelding 2 van 2
    • Trek de zuignap omhoog met een stevige, constante kracht om zo een kleine opening tussen het voorste paneel en de achterste behuizing te creëren.
    • Je loopt het risico de schermmodule te beschadigen als je te hard trekt. Oefen net genoeg druk uit om een kleine opening tussen de schermmodule en de achterste behuizing te creëren.
    I had a shattered front glass panel so I could not get the suction cup to seal properly. I tried a couple of different ways to get good suction but to no avail. I eventually used a Stanley knife to pry up the corner so I could get the spudger into the opening.
    John Architzel - Antwoord
    A really high quality packing tape over the entire screen will usually be enough to use the suction cup on a shattered screen.
    djwooten -
    I used a suction cup on each side to provide counter traction. I braced the iphone between my knees and pulled apart while my helper inserted the spudger
    jkanne - Antwoord
    This was by FAR the most difficult part of this whole thing. I confess the spudger was not cutting it so I used a butter knife to get into the small opening first, then used the spudger to go around the screen.
    Julie Sanchez - Antwoord
    Hey everyone, if you never have done this part before be aware there is an extremely strong adhesive around the lip of the screen and once again is extremely strong. I had to get a friend to insert the pry/pick into the small gap while I used one hand to brace the phone down and the other to pull the suction cup without it digging into my hand. Go slow, it took me 5 tries because I didn’t realize how strong the adhesive was.
    bartmistrot - Antwoord
    I also had a badly cracked lower screen - that glass was actually threatening to pull off the phone in chunks during this step, even with packing tape. Resorted to @j2arch’s tip and inserted a utility knife vertically into the seam between the display and phone body. Was able to lever the glass enough to get the spudger in there.
    Jason Augustyn - Antwoord
    I have replaced sevrel screens for my sister in law and my niece. The packing tape has worked every time and that’s with it Shattered and pieces already falling out. You have to make sure the packing tape goes to the edge of the screen but doesn’t touch the frame. I have the plier like screen remover and use that it is much easier to remove the screen by your self with that tool. I also have the little finger suction cup that comes with the kit here. I bought the plier suction cup tool When I had to replace the screen that had the pieces of the screen missing and I don’t regret spending the extra money for that it has made a world of difference. I do this as a hobby it’s not a job for me. The electric divide repair kit from Lowe’s is also a very good kit to help. If you’re only going to do it once the kit that comes with the package is a great deal from ifixit. Well worth the money to spend the little extra to get the kit if you all ready don’t have the tools.
    Brent - Antwoord
    If you try to use the spunger near the home button and try to pry it can crack your screen. This happened to me.
    Jeffrey - Antwoord
    Same thing happened to me. This should be a big warning in these steps. If you have a small to moderate crack in you screen, but you weren’t planning on replacing the screen at the same time as another repair inside, there’s a risk of damaging the screen further and making it inoperable.
    DW7ACCT -
    I found it easiest to use two suction cups. One on the front as directed, and a second one on the back. Give the spudger to your assistant, and have them slip it in place while you pull the display from the case.
    gordojenkins - Antwoord
    I gave up with the suction cup as it wasn't working for me with a cracked screen. Having heated the bottom of the phone with a hair dryer with a high heat for a good minute or so, I used a safety scraper (essentially a razor blade in a holder) along the bottom of the phone to separate the screen from the body of the phone. I used the scraper vertically between the bottom of the screen and the phone body and levered it sufficiently so that I could fit the spudger between the screen and the phone body. My experience when I first used the spudger around the frame was that the cracks in the screen caused the screen glass to separate from the frame, so I had to re-do it and ensure that the screen frame was separated from the phone body.
    Safety scraper:
    https://www.amazon.co.uk/Unger-CD170-Win...
  7. iPhone 6s Vervanging van de oorstukspeaker: stap 7, afbeelding 1 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 7, afbeelding 2 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 7, afbeelding 3 van 3
    • De beste en meest veilige plek om te wrikken is de inkeping in het voorste paneel, net boven de hoofdtelefoonjack.
    • Steek het platte einde van een spudger, terwijl je druk op de zuignap houdt, in de gecreëerde opening, direct boven de hoofdtelefoonjack.
    This was by far the hardest part of the repair for me. Getting leverage while finding a way to prod with a spudger is a challenge in coordination. I used a second spudger with point holding the phone down by the headphone jack, with the other end of the spudger anchored to my desk.
    drpotter - Antwoord
    When warmed, the suction cup was useless. Using the tip of a knife blade, was able to get it separated enough to insert spudger.
    hutland - Antwoord
    For me this was the most time consuming task. I used a hair dryer for heating. I found a very tight adhesive. For a moment I thought of abandoning my efforts and take the assembly to a professional repairman. But as they say, patience is a virtue.
    After fiddling for about 20 minutes, I achieved a barely noticable opening. So I decided to change the strategy. Instead of applying heat all over the base, I preceeded with small steps with heat concentrated near the opening. I applied intense heat only for about 15 to 20 seconds and immediately working with spudger. It took about an hour to completely open the case. It worked.
    Thanks for reading.
    - Mr Gamma
    Gamma Pailvan - Antwoord
    I also struggled with this step. Lots of heat, 3 different suction cups, I finally could see a small gap... much too thin to fit even a piece of paper into. A video on another site said it was the easy way. I used a sharp craft knife barely into the seam between metal and glass and pried slightly. And it started up. Still a pain freeing the rest of the adhesive. Perhaps the adhesive really sets up over the course of 5 years? I have it hinged open now, so onto the next steps.
    Mark Tollefson - Antwoord
  8. iPhone 6s Vervanging van de oorstukspeaker: stap 8, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 8, afbeelding 2 van 2
    • Kantel je spudger lichtjes terwijl deze in de opening zit om zo de opening tussen de schermmodule en de rest van de telefoon te vergroten.
    just changed the screen, but due to the tape along side the screen , it is best to heat a little so the glue losses and you can get the screen off better, like indicated
    Bart Blanckaert - Antwoord
  9. iPhone 6s Vervanging van de oorstukspeaker: stap 9, afbeelding 1 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 9, afbeelding 2 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 9, afbeelding 3 van 3
    • Schuif de zijkant van de spudger, terwijl je stevig aan de zuignap trekt, onder de linker onderhoek van het scherm.
  10. iPhone 6s Vervanging van de oorstukspeaker: stap 10, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 10, afbeelding 2 van 2
    • Schuif de punt van je spudger langs de linkerkant van de telefoon omhoog, tussen de schermmodule en de achterste behuizing.
  11. iPhone 6s Vervanging van de oorstukspeaker: stap 11, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 11, afbeelding 2 van 2
    • Steek het platte einde van je spudger onder de rechterkant van het scherm.
    • Schuif de spudger langs de rechterzijde omhoog.
  12. iPhone 6s Vervanging van de oorstukspeaker: stap 12, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 12, afbeelding 2 van 2
    • Gebruik een plasticen openingstool om de achterste behuizing vast te houden terwijl je de zuignap naar boven trekt om de telefoon te openen.
    • Verwijder het scherm nog niet volledig, aangezien deze aan de bovenkant van de iPhone nog vastzit door middel van datakabels die je zo kunt beschadigen.
  13. iPhone 6s Vervanging van de oorstukspeaker: stap 13, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 13, afbeelding 2 van 2
    • Trek aan het kleine lipje op de zuignap om deze van het scherm te verwijderen.
    Remember to apply the screen gasket on the re-assemble. The gasket is provided in the kit but not mentioned here on the instructions.
    Won Hong - Antwoord
    There’s a link to the entire gasket replacement procedure in Step 21.
    Jeff Suovanen -
  14. iPhone 6s Vervanging van de oorstukspeaker: stap 14, afbeelding 1 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 14, afbeelding 2 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 14, afbeelding 3 van 3
    • Pak de schermmodule voorzichtig vast en til deze op om de telefoon te openen. Gebruik de klemmen aan de bovenkant van het scherm als een scharnier om de telefoon te openen.
    • Open het scherm totdat deze ongeveer een hoek van 90º beschrijft en laat het scherm vervolgens leunen op een voorwerp, zodat je aan de telefoon kunt werken.
    • Open het scherm niet meer dan 90º—deze is namelijk nog steeds verbonden aan de bovenkant van de telefoon door middel van de scherm-, digitizer-, en voorste camerakabels, welke makkelijk kunnen scheuren.
    • Je kunt bijvoorbeeld een elastiek gebruiken om de schermmodule te verbinden aan een voorwerp, waardoor deze rechtop blijft staan. Dit voorkomt ook dat je de kabels onbedoeld en te veel belast.
    • Je kunt creatief zijn, je kunt ook een blikje drinken gebruiken om het scherm open te houden.
    if the display cables are damaged how can you tell ?
    Smiley McSmilebot - Antwoord
    In theory, I like the idea of propping up the screen with a rubber band and box/soda can like this, but after ripping the FaceTime camera cable twice, I realize that this method puts too much stress on the cable because it places the screen so far back. Even in this photo, you can see that the cable is taut. I’d recommend just holding the screen with your free hand to put the least amount of stress on that cable as possible.
    Ben Estabrook - Antwoord
    I used my spunger to prop it open. Works great
    Redbird - Antwoord
  15. iPhone 6s Vervanging van de oorstukspeaker, Batterijaansluiting: stap 15, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Verwijder de twee Phillips schroeven die het plaatje op de batterijaansluiting aan het logic board bevestigen, met de volgende lengtes:
    • Eén 2.9 mm lange schroef
    • Eén 2.3 mm lange schroef
    • Zorg dat je, tijdens deze reparatie, bijhoudt welke schroef waarvandaan komt, zodat je deze op de juiste plek weer terug kan schroeven. Zo voorkom je schade aan je iPhone.
    FYI - I used some blue painters tape wrapped around a piece of cardboard to hold the screws and brackets in place, in order, so they did not get lost. Some of those screws are MICROSCOPIC so be careful!
    I also suggest having very good lighting, even a camping headlight for hands-free well lit work space. You will thank me later :-)
    Use the bit labeled “PH000”.
    Joe Teichert - Antwoord
    PH000 bit just wants to free-spin in the 2.3 mm screw. no bite in the head at all. had no difficulty removing the 2.9 mm screw with the same Phillips. had to abandon battery replacement effort.
    Benjamin Stalcup - Antwoord
    For this part, neither PH000 or Y000 worked. Technically, it’ll set you back 31$ because you will need the PH00 screwdriver for this part, and the part where you need to open the screen. They have ph00 screwdrivers in every hardware store and even ifixit.com. just know that they put the wrong screwheads for you
    Jack Daniel - Antwoord
    Do not lose track of which hole these screws go into. They MUST be put back into the correct hole that they came out of. If not, you will get the dreaded “long screw damage” on the mainboard, and that will be the end of the show.
    Just remember where these screws go, and it will be fine.
    Harry McDow - Antwoord
    Ended up employing a Philips #0 from a regular jeweler/precision kit on the 2.3mm screw. Bits seem a bit off for this step.
    Vance Bell - Antwoord
  16. iPhone 6s Vervanging van de oorstukspeaker: stap 16, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 16, afbeelding 2 van 2
    • Verwijder het plaatje bovenop de batterijaansluiting.
    Does it matter if the brackets arent put back in the phone? I bought a used phone and brackets are missing. Thanks!
    Coupon Crazy - Antwoord
    Auch die Abdeckung ist angeklebt. Also mit etwas Vorsicht und Geduld rangehen.
    eckhardd@icloud.com - Antwoord
    If you have forgotten your High School German -
    The cover is also glued. So take some care and patience.
    Glen Paetz -
    My bracket actually has a black wire connected on the underside that is attached to the metal bracket (with screw) below it in the picture. I decided to leave it on and just move it to the side.
    Victor Ng-Thow-Hing - Antwoord
  17. iPhone 6s Vervanging van de oorstukspeaker: stap 17, afbeelding 1 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 17, afbeelding 2 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 17, afbeelding 3 van 3
    • Gebruik de punt van een spudger om de batterijaansluiting los te koppelen door deze in een rechte beweging omhoog te duwen van het logic board.
  18. iPhone 6s Vervanging van de oorstukspeaker: stap 18, afbeelding 1 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 18, afbeelding 2 van 3 iPhone 6s Vervanging van de oorstukspeaker: stap 18, afbeelding 3 van 3
    • Duw de batterijaansluiting weg van het contact om zo te voorkomen dat deze tijdens de reparatie per ongeluk contact maakt en de telefoon mogelijk inschakelt.
    When putting the new battery in, make sure to line up the plug and not to the top of the battery… our battery was smaller so the plug would NOT have lined up if we used the top of the battery. ALSO, the plug was NOT 90 degrees so we had to finagle the plug. Also, make sure there is a clear CLICK when you plug in the connector or it may not work. Ours went in but guess didn’t go far enough so we had to take the screen off and push it harder until we heard the “click” then it worked fine.
    Won Hong - Antwoord
    There was some black goop/glue around the battery connector, and when I lifted the old connector, some of that glue fell into the receptacle. It was easy to fish out (with magnifying glass and tweezers) but if you don't catch it, you may not get a good connection.
    Steerpike - Antwoord
  19. iPhone 6s Vervanging van de oorstukspeaker, Schermmodule: stap 19, afbeelding 1 van 1
    • Verwijder de volgende Phillips schroeven:
    • Drie 1.3 mm lange schroeven
    • Eén 1.6 mm lange schroef
    • Eén 3.0 mm lange schroef
    • Het is tijdens het weer in elkaar zetten van je telefoon essentieel om deze 3.0 mm lange schroef in rechter bovenhoek van het plaatje te plaatsen, aangezien deze schroef op iedere andere plaats het logic board zou kunnen beschadigen.
    I really don't see value in removing screen use box and rubber band keep at 90 degrees.
    John Parker - Antwoord
    I leave screen on as well for this. - Tho I prefer a 45 degree lean.
    Thor -
    I just changed my battery and also left the screen attached. I was lucky enough to get all 3 adhesive battery strips out clean so I didn’t have a struggle with the battery coming out. If I was going to need to get rough with it I was going to take the screen off at that point.
    Michael Gross - Antwoord
    To keep track of screws, draw a quick outline of the display cable bracket/cover, with five dots where screws should be. Drop the screws on the corresponding dot. Helps if you use magnet pad.
    Christa - Antwoord
    Better yet, print out the pictures from the iFixit website, and use clear tape (“Scotch tape”) to TAPE the screws onto the place in the picture where they belong.
    Tom -
    Which screwdriver from the kit do I use for which screw?
    Shiva Sharma - Antwoord
    I made a mistake and unscrewed the screw just north north west of the one circled in yellow. Of course I lost the screw. Can anyone give me any guidance about this? what does the wire connected to it do? What is the size of the screw, in case I have to replace it?
    P.S. This is another reason to consider the possibility of NOT removing the screen just to replace the battery: removing the screen presents a additional possible headache, especially for people like me with bad eyesight who probably shouldn’t be doing this in the first place.
    Tom - Antwoord
    It is a 1.4 mm Phillips screw holding the NFC bracket in place.
    Larry Lynch -
    I didn’t think this was necessary, bit I see it relieves stress on the front-facing camera and sensor cable connector; I did not disconnect the display connector nor remove the display screen.
    I second this finding. I too did not remove the screws nor the bracket. The cables look a bit stretched, but certainly not strained.
    -Gamma
    Gamma Pailvan -
    This step of separating the two parts of the phone deserves careful consideration. In my case, I had propped up the display assembly with a box and rubber bands. However, only 2 of the battery adhesive strips came off easily. The effort to remove the battery with the display assembly attached was not a good move on my part. I jarred the ear speaker cable and after reassembly I had no camera or working ear speaker. Taking off these 5 screws and removing the three cables is not difficult. My suggestion: is you have ANY trouble removing the 3 battery adhesive strips, STOP, separate the two components, and then continue with the battery removal. Don’t struggle removing the battery with the display assembly attached. (I replaced the ear speaker cable, and all is working now)
    Richard Perl - Antwoord
    Thanks for this tip! I am having a really hard time removing this plate because one of the screw heads are stripped. So I’ll try removing the battery adhesive strips first to see if I can get the battery out without removing the screen.
    nathanfunk -
    Use dixie cups and label them for each part you take out. You can stack the dixie cups to keep them in order.
    Bradley Nolen - Antwoord
    I skipped this for the battery removal, but when I went to replace the seal, I had to remove it anyway.
    dgol69 - Antwoord
    I lost the bottom left screw of the five in this step - anyone know if it’sgoing to cause a problem? ‘m going to go ahead and put thephone back together anyway - wil report back withresult
    OMG…. SO excited! It works! Seems that missing screw wasn’t an issue. The reason I’m so excited is, I’m a senior and have bever attempted anything like this before and was worried I’d mess it up, or it just wouuldn’t work for whatever reason. I know I never would have tried if it weren’t for finding this site, the great service, parts to do it and the videos/guides. Thank you so much ifixit. :-)
    I changed the battery, without removing the screen, when I closed the phone the front camera and speaker no longer work.
    Mr T - Antwoord
  20. iPhone 6s Vervanging van de oorstukspeaker: stap 20, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 20, afbeelding 2 van 2
    • Verwijder het plaatje bovenop de schermkabel.
    Be careful on this step: with my iPhone, one of the connectors (the home button/fingerprint sensor) was stuck to the underside of the bracket and I almost strained its cable.
    kevin - Antwoord
  21. iPhone 6s Vervanging van de oorstukspeaker: stap 21, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 21, afbeelding 2 van 2
    • Zorg ervoor dat je enkel de aansluiting zelf en niet het contact op het logic board omhoog duwt.
    • Gebruik een plasticen openingstool om de naar voren gerichte camera en de sensorkabelaansluiting los te koppelen.
    FYI, in the video she uses the spudger for this but I think either one will work.
    I found prying from the right to be better
    Is there any need for this step if only the Battery is replaced
    mrrreid - Antwoord
    I don’t recommend using the spudger for this as you can do more damage that way. I scratched the black square thing underneath.
    Laura Houghton - Antwoord
    I managed to remove the battery without disconnecting and removing the display first. This avoids possible difficulties in these steps (see below).
    One has to be careful that, while fighting with the battery strips, the display remains in its 90º position
    alfasw33 - Antwoord
  22. iPhone 6s Vervanging van de oorstukspeaker: stap 22, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 22, afbeelding 2 van 2
    • Gebruik een plasticen openingstool om de digitizerkabel los te koppelen door ook deze in een rechte beweging uit het contact op het logic board omhoog te duwen.
    • Druk, bij het weer aansluiten van de digitizerkabel, niet op het middel van de aansluiting. Druk de aansluiting aan een kant aan en druk dan de andere kant aan. Als je de aansluiting in het midden vastdrukt, loop je het risico een pin in de aansluiting te buigen en de digitizer permanent te beschadigen.
    Thanks you i fix it
    God Hand - Antwoord
    “When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage. “
    The following note above was so helpful. I was speeding through the process of getting things back together, since it seemed easy to connect the digitizer cable, but I kept pushing it in the middle and I wouldn’t connect. Until I read through this step and realized it was easier if I would’ve connected one side and then the opposite side right after.
    Jeffrey Robinos - Antwoord
    Don’t be too shy when pushing the ends of the digitizer connector back to place. If it does not connect properly, you might face the “half backlight” problem, even if you did not kill any LCD filter. Also check carefully, that you don’t clamp parts of the sticky sealing material placed around the connector inside the connection area.
    Norbert Andreas Richartz - Antwoord
    This part was a very frustrating experience for me.  I thought that my replacement screen was just poor quality, as it worked when it wanted to work.  Pressing home/power repeatedly sometimes brought it back, charging to 100% also brought it back.    The actual problem was that it is very easy to get some of the gasket material caught in the connector, which I couldn’t see until I used my jeweler's loupe.  I used 91% alcohol to carefully clean all of this off until all pins were shiny, and it took about 6 tries to get it right.  However, the screen’s been running well for 2 days now.  I already bought another screen replacement which I have for a spare as it was 100% not the problem.
    chumblyf - Antwoord
    I followed all the steps, so the sound is missed. What could be happened? thanks a lot. Fabio Balbino
    Fabio Balbino - Antwoord
  23. iPhone 6s Vervanging van de oorstukspeaker: stap 23, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 23, afbeelding 2 van 2
    • Zorg dat de batterij is losgekoppeld voordat je de kabel in deze stap loskoppelt of weer aansluit.
    • Koppel de thuisknop/vingerafdruksensorkabel los door deze in een rechte beweging uit het contact op het logic board omhoog te duwen.
    How much is this to replace?
    Alistair knight - Antwoord
    And where could I buy from?
    You can buy these at iFixit: [gekoppeld product ontbreekt of is uitgeschakeld: IF314-000-3]
    drgon - Antwoord
    After finishing the assembly I got the message “Touch ID cannot be enabled on this phone”. I found this connector was loose. Plugged it back in and that fixed it.
    Bryan Province - Antwoord
    Thanks for the tip. Same thing happened to me, some leftover adhesive was in the way!
    Sean - Lua Tech -
    Always make sure to disconnect the battery before you do any work on the phone replacing any parts the digitizer or anything. And before you start make sure the phone is turned off you don’t want any power surges. If you also have a static electricity bracelet that also is a plus to use but isn’t a necessity just a nice piece of mind. Some cases you do need to use one so you don’t discharge static electricity to an electrical component and mess it up.
    Brent - Antwoord
    Be very careful in this step. I noticed it’s very easy to tear the flex when trying to lift it out of its socket from the right side.
    shoeib - Antwoord
    What is the cable and how is it connected/fixed to the motherboard between the bottom socket and the screw hole.
    Mine came loose somehow?
    Jason Engelsman - Antwoord
    I figured out my own question its the Wi-Fi diversity antenna cable. But how is it connected/secured to the motherboard?
    i pressed on the center of the digitizer connection. and the bottom half of my screen didnt work. i then took that same front panel assembly and tried to install it on another old iphone 6s+ and i had the same issue.
    can i still fix it?
    what exactly is broken now?
    alejandro rueda - Antwoord
    @mynameisoli Honestly this just sounds like a defective screen to me, but it’s hard to say for sure. Look closely at the connector at the end of the ribbon cable and check it for damage. If it’s slightly bent/curved, all the pins won’t make good contact in the socket. You can try bending it back so it lays flat, but you have to be very careful not to damage the connector or contaminate the pins with skin oils, so it’s tricky—and it may be harder to return as “defective” if you mess up the connector. So try this at your own risk. Apart from that, I would just return it and try a different display. Good luck!
    Jeff Suovanen -
    The 6s plus screen repair kit i bought has the wrong size cable here on the replacement part. SOL.
    Alex Richardson - Antwoord
    Once I accidentally disconnected the display assembly cables before disconnecting the battery. Now the home button and fingerprint sensor doesn’t work. Any solution to this?? I have tried a different home button, even that doesn’t work.
    a3roar - Antwoord
    I changed the battery on my iPhone and put all together again and charged it. When I pressed the home button the lock screen with my picture appeared and when I pressed it again the screen with the digits from 0 to 9 appeared. I was asked to enter my passcode, but when I did that nothing happened, the phone did not open.
    What could be wrong? Is the home screen cable not fully connected or what could be the reason for this?
    THORDUR JOHANNESSON - Antwoord
  24. iPhone 6s Vervanging van de oorstukspeaker: stap 24, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 24, afbeelding 2 van 2
    For instructions on home button swap out to the new screen you just installed, go here
    iPhone 6s Plus Vervanging van de thuisknopmodule
    Superior Office Systems - Antwoord
    Do you know whether the adhesive contributes to waterproofing, or just for stability/adhesion?
    Christa - Antwoord
    @kitabel The iPhone 6s case isn’t waterproof, so I don’t think adhesive around the display is contributing anything other than stability. The 6s series does have some water resistance, but it’s mostly internal and not something Apple advertises.
    Jeff Suovanen -
    If you have a replacement adhesive for the display, you may need to install it before reconnecting cables to the components. If the adhesive wraps all the way around the display, it will be impossible to install it once the display is reconnected.
    Matthew Olwell - Antwoord
    These instructions worked great for me. Thank you!
    Chris Enloe - Antwoord
  25. iPhone 6s Vervanging van de oorstukspeaker, Oorstukspeaker: stap 25, afbeelding 1 van 1
    • Verwijder de volgende drie Phillips schroeven:
    • Twee 2.7 mm lange schroeven
    • Eén 1.4 mm lange schroef
  26. iPhone 6s Vervanging van de oorstukspeaker: stap 26, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 26, afbeelding 2 van 2
    • Verwijder het plaatje op de oorstukspeaker.
  27. iPhone 6s Vervanging van de oorstukspeaker: stap 27, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 27, afbeelding 2 van 2
    • Gebruik het platte einde van een spudger om de FaceTime-camera uit de behuizing te tillen.
  28. iPhone 6s Vervanging van de oorstukspeaker: stap 28, afbeelding 1 van 2 iPhone 6s Vervanging van de oorstukspeaker: stap 28, afbeelding 2 van 2
    • Trek de FaceTime-camera naar achteren en verwijder de oorstukspeaker.
Conclusie
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
91 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
en nl
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Evan Noronha
226.093 Reputatie
168 handleidingen geschreven
12 opmerkingen
Is there really a difference between 6s and 6s plus ear speaker?
AWT - Antwoord
For future reference, I found only a slight physical difference between the two. Tested both out on a 6s Plus and they both seem to work exactly the same.
Corey Hawkins -
Guide worked well. Fixed my 6s Plus with no issues.
Thanks.
jim crusan - Antwoord
Is the earpiece bracket the same as the one in the iphone 6s?
adam Meaney - Antwoord
I recently followed this but sadly my replacement sounds the same (too low). Any suggestions
Mark Sexton - Antwoord
replaced the ear speaker with out a hitch in less than 20 minutes but speaker still does not work so what can I do?
soesterlarry - Antwoord
The speaker still does not work. Might be software related. For reference, the “PHONE GASKET” that came for theiPhone 6s Plus Earphone Speaker is for the IPHONE 6/6S, NOT, THE PLUS. TOO SMALL.
terrylg50 - Antwoord
tried it and now my camera, flash light and speaker doesn’t work.  I'm worse than when I started
Carlitos Ramos - Antwoord
Swedish: Ganska lätt att genomföra om man har rätt vilja och fokusering. Bra guide! Jag bytte på min iPhone 6s Plus men tyvärr blev det ingen förbättring. Samma fel kvarstår. Alltså: svagt ljud i hörselhögtalaren som man har mot örat. Felet måste vara något annat? Humm…?
Mvh: Thord:)
Thord Lundin - Antwoord
Speaker still does not work after repair. Volume still too low for use the Iphone out of room without rumors...
Where could the problem be?
Thanks for any other informations .
Gary
Andrea - Antwoord
In my experience, almost all low volume complaints are actually not damaged components but rather clogged membranes. The screen-like membrane on the front cover that keeps contaminants out of the phone gets clogged with oils, dirt and such and simply blocks the sound waves. A thorough cleaning with alcohol has worked many times for me.
djwooten -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 75
Altijd: 49,470
