Ga door naar hoofdinhoud
iPhone 6s Rear Case Replacement
Wat je nodig hebt
  1. iPhone 6s Rear Case Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
    Vraag FixBot
    Voeg opmerking toe
  2. iPhone 6s Rear Case Replacement, Anti-Clamp instructions: stap 2, afbeelding 1 van 3 iPhone 6s Rear Case Replacement, Anti-Clamp instructions: stap 2, afbeelding 2 van 3 iPhone 6s Rear Case Replacement, Anti-Clamp instructions: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Vraag FixBot
    Voeg opmerking toe
  3. iPhone 6s Rear Case Replacement: stap 3, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 3, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 3, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Vraag FixBot
    Voeg opmerking toe
  4. iPhone 6s Rear Case Replacement, Opening Procedure: stap 4, afbeelding 1 van 1
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
    Vraag FixBot
    Voeg opmerking toe
  5. iPhone 6s Rear Case Replacement: stap 5, afbeelding 1 van 1
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    Vraag FixBot
    Voeg opmerking toe
  6. iPhone 6s Rear Case Replacement: stap 6, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 6, afbeelding 2 van 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
    Vraag FixBot
    Voeg opmerking toe
  7. iPhone 6s Rear Case Replacement: stap 7, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 7, afbeelding 2 van 2
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
    Vraag FixBot
    Voeg opmerking toe
  8. iPhone 6s Rear Case Replacement: stap 8, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 8, afbeelding 2 van 2
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  9. iPhone 6s Rear Case Replacement: stap 9, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 9, afbeelding 2 van 2
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
    Vraag FixBot
    Voeg opmerking toe
  10. iPhone 6s Rear Case Replacement: stap 10, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 10, afbeelding 2 van 2
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
    Vraag FixBot
    Voeg opmerking toe
  11. iPhone 6s Rear Case Replacement: stap 11, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 11, afbeelding 2 van 2
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  12. iPhone 6s Rear Case Replacement: stap 12, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 12, afbeelding 2 van 2
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
    Vraag FixBot
    Voeg opmerking toe
  13. iPhone 6s Rear Case Replacement: stap 13, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 13, afbeelding 2 van 2
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
    Vraag FixBot
    Voeg opmerking toe
  14. iPhone 6s Rear Case Replacement: stap 14, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 14, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 14, afbeelding 3 van 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • During reassembly, pause here if you wish to replace the adhesive around the edges of the display.
    • During reassembly, the camera end of the screen body needs to hook under the edge of the body. The hooks of the screen frame need to be under the rim of the main body and snugged toward the camera end to easily close the cover and have it properly clip.
    • These hooks are not really a proper hinge but clasps that need to be under the rim of the main phone frame/edge!! This way the screen easily will return to its closed state nicely gently snapping into place.
    • During reassembly, reverse order for getting the screen clipped back in means pressing along the right side top to bottom corner. Then the left.
    Vraag FixBot
    Voeg opmerking toe
  15. iPhone 6s Rear Case Replacement, Battery Connector: stap 15, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    Vraag FixBot
    Voeg opmerking toe
  16. iPhone 6s Rear Case Replacement: stap 16, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 16, afbeelding 2 van 2
    • Remove the battery connector bracket from the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  17. iPhone 6s Rear Case Replacement: stap 17, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 17, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 17, afbeelding 3 van 3
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
    Vraag FixBot
    Voeg opmerking toe
  18. iPhone 6s Rear Case Replacement: stap 18, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 18, afbeelding 2 van 2
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
    Vraag FixBot
    Voeg opmerking toe
  19. iPhone 6s Rear Case Replacement, Unfasten the display cable bracket: stap 19, afbeelding 1 van 1
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
    Vraag FixBot
    Voeg opmerking toe
  20. iPhone 6s Rear Case Replacement: stap 20, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 20, afbeelding 2 van 2
    • Remove the display cable bracket.
    Vraag FixBot
    Voeg opmerking toe
  21. iPhone 6s Rear Case Replacement: stap 21, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 21, afbeelding 2 van 2
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  22. iPhone 6s Rear Case Replacement: stap 22, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 22, afbeelding 2 van 2
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    Vraag FixBot
    Voeg opmerking toe
  23. iPhone 6s Rear Case Replacement: stap 23, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 23, afbeelding 2 van 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  24. iPhone 6s Rear Case Replacement: stap 24, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  25. iPhone 6s Rear Case Replacement, Rear Camera: stap 25, afbeelding 1 van 2 iPhone 6s Rear Case Replacement, Rear Camera: stap 25, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  26. iPhone 6s Rear Case Replacement: stap 26, afbeelding 1 van 1
    • Remove the following two Phillips screws over the rear camera bracket:
    • One 1.6 mm screw
    • One 2.0 mm screw
    Vraag FixBot
    Voeg opmerking toe
  27. iPhone 6s Rear Case Replacement: stap 27, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 27, afbeelding 2 van 2
    • Remove the camera bracket.
    Vraag FixBot
    Voeg opmerking toe
  28. iPhone 6s Rear Case Replacement: stap 28, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 28, afbeelding 2 van 2
    • Insert a spudger to the side of the camera, between the rear case and the camera module.
    • Gently pry up on the camera to nudge it out from its housing.
    Vraag FixBot
    Voeg opmerking toe
  29. iPhone 6s Rear Case Replacement: stap 29, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 29, afbeelding 2 van 2
    • Remove the camera.
    Vraag FixBot
    Voeg opmerking toe
  30. iPhone 6s Rear Case Replacement, SIM Tray: stap 30, afbeelding 1 van 2 iPhone 6s Rear Case Replacement, SIM Tray: stap 30, afbeelding 2 van 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
    Vraag FixBot
    Voeg opmerking toe
  31. iPhone 6s Rear Case Replacement: stap 31, afbeelding 1 van 1
    • Remove the SIM Card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    Vraag FixBot
    Voeg opmerking toe
  32. iPhone 6s Rear Case Replacement, Logic Board: stap 32, afbeelding 1 van 1
    • Remove the two 2.3 mm Phillips screws securing the upper component cable connector bracket.
    Vraag FixBot
    Voeg opmerking toe
  33. iPhone 6s Rear Case Replacement: stap 33, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 33, afbeelding 2 van 2
    • Remove the upper component cable connector bracket.
    Vraag FixBot
    Voeg opmerking toe
  34. iPhone 6s Rear Case Replacement: stap 34, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 34, afbeelding 2 van 2
    • Remove the following five Phillips screws securing the top left Wi-Fi antenna:
    • Two 1.5mm screws
    • One 2.3 mm screw
    • One 1.9 mm screw
    • One 2.0 mm screw
    Vraag FixBot
    Voeg opmerking toe
  35. iPhone 6s Rear Case Replacement: stap 35, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 35, afbeelding 2 van 2
    • Remove the top left Wi-Fi antenna.
    Vraag FixBot
    Voeg opmerking toe
  36. iPhone 6s Rear Case Replacement: stap 36, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 36, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the audio control cable from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  37. iPhone 6s Rear Case Replacement: stap 37, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 37, afbeelding 2 van 2
    • Use the pointed tip of a spudger to disconnect the antenna cable from its socket on the upper right corner of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  38. iPhone 6s Rear Case Replacement: stap 38, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 38, afbeelding 2 van 2
    • Use the pointed tip of a spudger to disconnect the antenna cable from its socket on the lower left corner of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  39. iPhone 6s Rear Case Replacement: stap 39, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 39, afbeelding 2 van 2
    • Insert the flat end of a spudger underneath the Lightning connector ribbon cable. Lift up to disconnect it from its socket on the logic board.
    Vraag FixBot
    Voeg opmerking toe
  40. iPhone 6s Rear Case Replacement: stap 40, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 40, afbeelding 2 van 2
    • Gently pull up on the antenna cable to de-route it from the two clips on the right side of the logic board.
    Vraag FixBot
    Voeg opmerking toe
  41. iPhone 6s Rear Case Replacement: stap 41, afbeelding 1 van 1
    • Remove the 1.3 mm Phillips screw securing the NFC bracket to the logic board.
    Vraag FixBot
    Voeg opmerking toe
  42. iPhone 6s Rear Case Replacement: stap 42, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 42, afbeelding 2 van 2
    • Remove the NFC bracket.
    Vraag FixBot
    Voeg opmerking toe
  43. iPhone 6s Rear Case Replacement: stap 43, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 43, afbeelding 2 van 2
    • Remove the following two Phillips screws:
    • One 2.5 mm screw at the top of the logic board
    • One 1.4 mm screw set into the upper edge of the rear case
    Vraag FixBot
    Voeg opmerking toe
  44. iPhone 6s Rear Case Replacement: stap 44, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 44, afbeelding 2 van 2
    • Remove the plastic clip.
    Vraag FixBot
    Voeg opmerking toe
  45. iPhone 6s Rear Case Replacement: stap 45, afbeelding 1 van 1
    • Remove the final three screws securing the logic board to the rear case:
    • One 1.9 mm Phillips screw
    • One 2.5 mm hex nut
    • One 1.8 mm Phillips screw
    Vraag FixBot
    Voeg opmerking toe
  46. iPhone 6s Rear Case Replacement: stap 46, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 46, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 46, afbeelding 3 van 3
    • Insert an opening pick below the lower edge of the logic board, between the board and the loudspeaker.
    • Use the opening pick to gently lift the logic board out of its housing.
    • Remove the logic board.
    Vraag FixBot
    Voeg opmerking toe
  47. iPhone 6s Rear Case Replacement, Upper Component Cable: stap 47, afbeelding 1 van 2 iPhone 6s Rear Case Replacement, Upper Component Cable: stap 47, afbeelding 2 van 2
    • Remove the two 1.5 mm Phillips screws holding the Taptic Engine in place.
    • Remove the Taptic Engine.
    Vraag FixBot
    Voeg opmerking toe
  48. iPhone 6s Rear Case Replacement: stap 48, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 48, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 48, afbeelding 3 van 3
    • Use tweezers to peel up the tips of the battery adhesive strips at the lower edge of the battery.
    Vraag FixBot
    Voeg opmerking toe
  49. iPhone 6s Rear Case Replacement: stap 49, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 49, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 49, afbeelding 3 van 3
    • Try not to wrinkle the strips during this procedure—they will become very difficult to deal with and will not straighten out again.
    • Pull one of the adhesive strips straight out, towards the bottom of the iPhone.
    • For best results, pull the strip at a 60º angle or less.
    • The strip will stretch to many times its original length. Continue to pull steadily, re-grabbing the strip closer to the iPhone if necessary.
    • Continue pulling until the strip is fully removed.
    • If the battery adhesive tabs break off at any point during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
    • If one of the adhesive strips breaks under the battery during this procedure, and cannot be retrieved, remove the remaining strip, and then skip to Step 48.
    Vraag FixBot
    Voeg opmerking toe
  50. iPhone 6s Rear Case Replacement: stap 50, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 50, afbeelding 2 van 2
    • Repeat the previous step for the second adhesive strip.
    • Use one hand to hold down the battery as you remove the second strip, or the strip may fling the battery from the phone once it separates from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  51. iPhone 6s Rear Case Replacement: stap 51, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 51, afbeelding 2 van 2
    Plastic Cards
    $2.99
    • If you successfully removed all three adhesive strips, move on to the next step. Otherwise, you will need to pry the battery from the rear case.
    • Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
    • After about a minute, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
    Vraag FixBot
    Voeg opmerking toe
  52. iPhone 6s Rear Case Replacement: stap 52, afbeelding 1 van 1
    • Remove the battery.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
    Vraag FixBot
    Voeg opmerking toe
  53. iPhone 6s Rear Case Replacement: stap 53, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 53, afbeelding 2 van 2
    • Remove the single 1.3 mm Phillips screw securing the flash bracket.
    • Remove the flash bracket.
    Vraag FixBot
    Voeg opmerking toe
  54. iPhone 6s Rear Case Replacement: stap 54, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 54, afbeelding 2 van 2
    • Use the flat end of a spudger to lift the flash out of its housing in the rear case.
    Vraag FixBot
    Voeg opmerking toe
  55. iPhone 6s Rear Case Replacement: stap 55, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 55, afbeelding 2 van 2
    • Remove the following five Phillips screws:
    • Two 2.5 mm screws set into the left edge of the rear case
    • One 2.1 mm Phillips #000 screw set into the left edge of the rear case
    • Two 2.1 mm screws set into the right edge of the rear case
    • If you overtighten these screws during reassembly, your power and volume buttons may not click properly. Check the clicking action on each button before you continue with reassembly.
    Vraag FixBot
    Voeg opmerking toe
  56. iPhone 6s Rear Case Replacement: stap 56, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 56, afbeelding 2 van 2
    • Use the pointed tip of a spudger to gently separate the microphone from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  57. iPhone 6s Rear Case Replacement: stap 57, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 57, afbeelding 2 van 2
    • Slide an opening pick between the upper component cable and the rear case.
    • Gently separate the cable from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  58. iPhone 6s Rear Case Replacement: stap 58, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 58, afbeelding 2 van 2
    • Continue pushing the opening pick under the cable until it fully separates from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  59. iPhone 6s Rear Case Replacement: stap 59, afbeelding 1 van 1
    • Remove the upper component cable assembly.
    Vraag FixBot
    Voeg opmerking toe
  60. iPhone 6s Rear Case Replacement: stap 60, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 60, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 60, afbeelding 3 van 3
    • If your replacement part did not come with the mute switch cover, you will need to remove the switch cover and transfer It.
    • Use the flat end of the spudger to press down and hold the old bracket firmly in place.
    • Use tweezers or your fingers to carefully rock the switch cover such that the switch cover pins swing out of their clips.
    • Lift the switch cover straight up.
    • To install the mute switch cover onto the new upper cable assembly, reverse the steps.
    • The pins are supposed to rest near the clip opening. Do no attempt to force the pins far into the clips. The switch cover will be held securely in place once you screw the bracket back onto the case.
    • The switch cover goes on in only one orientation. If you are having a hard time getting the switch cover onto the new part, try toggling the switch so that the black protruding lever is in a different position.
    • Before reassembling the phone, check all switches and buttons to see if they physically work.
    Vraag FixBot
    Voeg opmerking toe
  61. iPhone 6s Rear Case Replacement, Volume Control Button Covers: stap 61, afbeelding 1 van 3 iPhone 6s Rear Case Replacement, Volume Control Button Covers: stap 61, afbeelding 2 van 3 iPhone 6s Rear Case Replacement, Volume Control Button Covers: stap 61, afbeelding 3 van 3
    • Grasp the metal bar behind either of the two volume control button covers, and pull the button cover out of its housing in the rear case.
    • Repeat for the second volume control button cover.
    • Check for proper orientation when reinstalling the button covers. The metal bar should swing downward, towards the rear case of the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  62. iPhone 6s Rear Case Replacement, Power Button Cover: stap 62, afbeelding 1 van 2 iPhone 6s Rear Case Replacement, Power Button Cover: stap 62, afbeelding 2 van 2
    • Grasp the metal bar on the back of the power button cover.
    • Remove the power button cover.
    • Check for proper orientation when reinstalling the button cover. The metal bar should swing downward, towards the rear case of the iPhone.
    Vraag FixBot
    Voeg opmerking toe
  63. iPhone 6s Rear Case Replacement, Rear Case: stap 63, afbeelding 1 van 3 iPhone 6s Rear Case Replacement, Rear Case: stap 63, afbeelding 2 van 3 iPhone 6s Rear Case Replacement, Rear Case: stap 63, afbeelding 3 van 3
    • Deroute the antenna cable from its rubber sleeve on the right edge of the rear case.
    Vraag FixBot
    Voeg opmerking toe
  64. iPhone 6s Rear Case Replacement: stap 64, afbeelding 1 van 1
    • Remove the antenna cable from the metal clip on the right edge of the rear case.
    Vraag FixBot
    Voeg opmerking toe
  65. iPhone 6s Rear Case Replacement: stap 65, afbeelding 1 van 1
    • Remove the following five Phillips screws securing the speaker to the rear case:
    • Two 2.6 mm screws
    • Two 2.3 mm screws
    • One 3.0 mm screw
    Vraag FixBot
    Voeg opmerking toe
  66. iPhone 6s Rear Case Replacement: stap 66, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 66, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 66, afbeelding 3 van 3
    • Use your fingers to lift the speaker out of its housing in the rear case.
    • Remove the speaker assembly.
    Vraag FixBot
    Voeg opmerking toe
  67. iPhone 6s Rear Case Replacement: stap 67, afbeelding 1 van 1
    • Remove the following eight Phillips screws:
    • Two 2.9 mm screws securing the headphone jack
    • One 3.7 mm screw securing the microphone bracket
    • Two 1.3 mm screws on the lower edge of the iPhone
    • Two 1.9 mm screws on either side of the Lighting connector
    • One 3.0 mm screw to the left of the connector
    Vraag FixBot
    Voeg opmerking toe
  68. iPhone 6s Rear Case Replacement: stap 68, afbeelding 1 van 1
    • Remove the plastic microphone bracket.
    Vraag FixBot
    Voeg opmerking toe
  69. iPhone 6s Rear Case Replacement: stap 69, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 69, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 69, afbeelding 3 van 3
    • Insert an opening pick between the Lightning connector assembly and the rear case to begin breaking up the adhesive holding the flex cable in place.
    Vraag FixBot
    Voeg opmerking toe
  70. iPhone 6s Rear Case Replacement: stap 70, afbeelding 1 van 3 iPhone 6s Rear Case Replacement: stap 70, afbeelding 2 van 3 iPhone 6s Rear Case Replacement: stap 70, afbeelding 3 van 3
    • Use the flat end of a spudger to continue separating the Lightning connector assembly from the rear case.
    Vraag FixBot
    Voeg opmerking toe
  71. iPhone 6s Rear Case Replacement: stap 71, afbeelding 1 van 2 iPhone 6s Rear Case Replacement: stap 71, afbeelding 2 van 2
    • Use the tip of a spudger to separate the two microphones from the lower edge of the rear case.
    Vraag FixBot
    Voeg opmerking toe
  72. iPhone 6s Rear Case Replacement: stap 72, afbeelding 1 van 1
    • Remove the Lightning connector and headphone jack assembly.
    Vraag FixBot
    Voeg opmerking toe
  73. iPhone 6s Rear Case Replacement: stap 73, afbeelding 1 van 1
    • Only the rear case remains.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
92 andere personen hebben deze handleiding voltooid.
Evan Noronha
229.466 Reputatie
168 handleidingen geschreven
9Gids Commentaar
I can't get the phillips 000 screw out on step 52, now it's become too hollow within to open. What do I do?
Anun Azganun - Antwoord Deel
Stripped screws are the worst! We have a guide on how to remove stripped screws that you may find helpful. Remember to maintain lots of pressure on the screw and stop applying force and try a different method if the bit is still slipping.
Evan Noronha - Antwoord Deel
Every thing works fine except I have no sound, either on speakerphone or normally. Did I break the upper component cable? I've checked all the plug connections and they seem ok.
John Lesnik - Antwoord Deel
I have no sound at all from the normal speaker or in speakerphone mode. I have good cellular and Wi-Fi connections and the phone sees to work perfectly otherwise. The battery charges fine through the Lightning connector. Can't use it as a phone though! Did I break the upper component cable in the disassembly? Any other ideas?
Before I start.. many steps involve pulling flex cables away from adhesive films lining the case. If my replacement back has no such adhesive films, or they are no longer sticky, what's the impact? Will I have a phone that buzzes and resonates when on speakerphone?
Handy - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 145
Altijd: 103,319
