Ga door naar hoofdinhoud
iPhone 11 Rear-Facing Cameras Replacement
Wat je nodig hebt
  1. iPhone 11 Rear-Facing Cameras Replacement, Remove the pentalobe screws: stap 1, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Remove the pentalobe screws: stap 1, afbeelding 2 van 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 11 Rear-Facing Cameras Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 11 Rear-Facing Cameras Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 11 Rear-Facing Cameras Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the top, and one on the bottom.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 11 Rear-Facing Cameras Replacement: stap 5, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 5, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 11 Rear-Facing Cameras Replacement: stap 6, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 6, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 6, afbeelding 3 van 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 11 Rear-Facing Cameras Replacement, Heat the lower edge of the phone: stap 7, afbeelding 1 van 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute.
  8. iPhone 11 Rear-Facing Cameras Replacement: stap 8, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement: stap 8, afbeelding 2 van 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
  9. iPhone 11 Rear-Facing Cameras Replacement, Lift the display slightly: stap 9, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Lift the display slightly: stap 9, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Lift the display slightly: stap 9, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  10. iPhone 11 Rear-Facing Cameras Replacement, Separate the screen adhesive: stap 10, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Separate the screen adhesive: stap 10, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Separate the screen adhesive: stap 10, afbeelding 3 van 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
  11. iPhone 11 Rear-Facing Cameras Replacement, Screen information: stap 11, afbeelding 1 van 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  12. iPhone 11 Rear-Facing Cameras Replacement: stap 12, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 12, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 12, afbeelding 3 van 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  13. iPhone 11 Rear-Facing Cameras Replacement: stap 13, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 13, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement: stap 13, afbeelding 3 van 3
    • The top edge of the display is secured with both glue and clips.
    • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
    • Insert your pick into the top-right corner of the phone.
  14. iPhone 11 Rear-Facing Cameras Replacement: stap 14, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement: stap 14, afbeelding 2 van 2
    • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
    • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
    • Don't insert your pick more than 3 mm, as you may damage the Face ID sensor array.
  15. iPhone 11 Rear-Facing Cameras Replacement, Remove the suction cup: stap 15, afbeelding 1 van 1
    • Pull the small nub on the suction cup to detach it from the front panel.
  16. iPhone 11 Rear-Facing Cameras Replacement, Open the iPhone: stap 16, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Open the iPhone: stap 16, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Open the iPhone: stap 16, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Prop the display up against something sturdy.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 11 Rear-Facing Cameras Replacement, Display Assembly: stap 17, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Display Assembly: stap 17, afbeelding 2 van 2
    • To access the screws in the following step, tilt the display by slightly lifting its lower edge.
    • Be careful not to strain or tear the display cables.
  18. iPhone 11 Rear-Facing Cameras Replacement, Unscrew the battery connector cover: stap 18, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Unscrew the battery connector cover: stap 18, afbeelding 2 van 2
    Magnetic Project Mat
    $19.95
    • Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  19. iPhone 11 Rear-Facing Cameras Replacement, Remove the battery connector cover: stap 19, afbeelding 1 van 1
    • Remove the bracket.
  20. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the battery: stap 20, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the battery: stap 20, afbeelding 2 van 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
  21. iPhone 11 Rear-Facing Cameras Replacement, Unscrew the logic board cover screws: stap 21, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Unscrew the logic board cover screws: stap 21, afbeelding 2 van 2
    • Use a Y000 driver to remove the five 1.1 mm screws securing the logic board cover bracket.
  22. iPhone 11 Rear-Facing Cameras Replacement, Remove the logic board cover bracket: stap 22, afbeelding 1 van 1
  23. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the display: stap 23, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the display: stap 23, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the display: stap 23, afbeelding 3 van 3
    • Use a spudger or a fingernail to disconnect the LCD panel cable connector.
    • Disconnect the digitizer connector next to it.
  24. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the front sensors: stap 24, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the front sensors: stap 24, afbeelding 2 van 2
    • Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
  25. iPhone 11 Rear-Facing Cameras Replacement, Remove the display assembly: stap 25, afbeelding 1 van 1
  26. iPhone 11 Rear-Facing Cameras Replacement, Unscrew the rear camera cover: stap 26, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Unscrew the rear camera cover: stap 26, afbeelding 2 van 2
    • Remove the two Phillips screws securing the rear camera cover:
    • One 1.4 mm screw
    • One 1.3 mm screw
  27. iPhone 11 Rear-Facing Cameras Replacement, Remove the camera cover: stap 27, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Remove the camera cover: stap 27, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Remove the camera cover: stap 27, afbeelding 3 van 3
    • Lift the camera cover from the edge closest to the battery, and remove it.
    • To reinstall the camera cover, follow the images exactly in reverse: first, lower the outside edge until the two protruding tabs on the cover are slotted securely into the bracket on the outer edge of the camera module. Then, hinge the cover closed.
    • The cover only lays flat after the two tabs are seated correctly.
  28. iPhone 11 Rear-Facing Cameras Replacement, Disconnect the cameras: stap 28, afbeelding 1 van 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the cameras: stap 28, afbeelding 2 van 3 iPhone 11 Rear-Facing Cameras Replacement, Disconnect the cameras: stap 28, afbeelding 3 van 3
    • Use a spudger or a fingernail to disconnect the two camera cable connectors by prying them straight up from their sockets.
  29. iPhone 11 Rear-Facing Cameras Replacement, Loosen the camera assembly: stap 29, afbeelding 1 van 2 iPhone 11 Rear-Facing Cameras Replacement, Loosen the camera assembly: stap 29, afbeelding 2 van 2
    • Insert the point of a spudger at the bottom right corner of the camera, between the camera assembly and the iPhone's frame.
    • Gently pry up to lever the camera out of the iPhone.
  30. iPhone 11 Rear-Facing Cameras Replacement: stap 30, afbeelding 1 van 1
    • Remove the rear-facing camera assembly.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 11 Answers community for help.
42 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
439.289 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.418 handleidingen geschreven
5 opmerkingen
hey there
that was very useful guide. Thank you so much
https://paytakhtfanavari.com/home-applia...
fatemeh hosseini - Antwoord
i cannot use dark mode on the replacement camera now. it should work shouldn't it?
norman wheatley - Antwoord
بسیار عالی بود.
من برای تعمیرات لوازم مرتبط با موبایل به این سایت مراجعه می کنم و برای تعمیرات لباسشویی در مشهد به سایت مشهدتعمیر
هر دو عالی هستند
Saeed Dopamine - Antwoord
When I try to use my rear camera now, its black, and I cannot use 0.5x. What could be the problem?
Martin Skugor - Antwoord
Hi. hope I'm not left out. You need to change your rear camera. Happened to me once. Rear camera just black . After replace it, its fine now
Nard In -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 20
Afgelopen 7 dagen: 187
Afgelopen 30 dagen: 800
Altijd: 88,067
