Sony TCM-450 PCB/Circuit Board Replacement
Inleiding
Ga naar stap 1Do you need to remove the circuit board, motor, belts, or buttons on your TCM-450? Then you will need this guide to get to those parts. The PCB, motherboard, or circuit board for TCM-450 hides all of the important mechanical components that make TCM-450 work, and is the computer board that runs the device. This may be difficult because you desolder multiple wires to lift up the PCB.
Wat je nodig hebt
Remove the two 3.5 mm Phillips #00 screws from the bottom of the device.
Carefully desolder each connection and gently remove each connected wire.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
