Ga door naar hoofdinhoud
iFixit gebruikt cookies om de functionaliteit van de site te verbeteren, het verkeer te analyseren en advertenties te personaliseren. Door onze site te gebruiken, gaat u akkoord met ons cookiegebruik en privacybeleid.
PlayStation 4 Slim Optical Disc Drive Replacement
Hernan Rodriguez
Hernan Rodriguez en 9 andere bijdragers
Voor het laatst geüpdatet op March 1, 2025
10 - 15 minuten
Gemiddeld
Use this guide to remove or replace your Playstation 4 Slim’s disc drive.
Note: If your replacement disc drive did not come with flex cables, you will have to transfer the cables from your original drive.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
    Remove the screw directly to the left of that one in the picture as well. Should be silver.
    Elizabeth Johnson - Antwoord
    ihr seid so ein scheiß haufen das stimmt über haubt nix
    Toaster 95 - Antwoord
    einfach alles stimmt nicht
    Quitar la pegatina anula la garantía en España al menos
    Ana y Francisco - Antwoord
    So becore you start on this guide if you read the comments at the last step, this guide is geared more towards repairing of the disc drive not replacing the entire optical disc drive, i have done mine already and the guide does help get you halfway there but you are gunna need a bit more to pull the entire disc drive out, i will post another comment on the last step so you can follow these steps and then mine to further reference from that point on. See ya on the last step of the guide 🤘
    Walter Gamboa - Antwoord
  2. PlayStation 4 Slim Optical Disc Drive Replacement: stap 2, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement: stap 2, afbeelding 2 van 2
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
    Are you SURE that it’s counter-clockwise?
    The Stuff - Antwoord
    Try T9. Fits better.
    Otter - Antwoord
    T8 fits like a glove for me
    Daniel Henderson -
    Is there anything else you can use
    randomweeb - Antwoord
    A small flathead screwdriver will work
    shawng6363 -
    There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
    gavinstoutconner@icloud.com - Antwoord
    Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
    Nicholas -
    There is a metal thing inside of the screw slot any insite on this?
    Tristan York - Antwoord
  3. PlayStation 4 Slim Optical Disc Drive Replacement: stap 3, afbeelding 1 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 3, afbeelding 2 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 3, afbeelding 3 van 3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
    It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
    Vidal Santos - Antwoord
    There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
    Emil Fisk - Antwoord
    It would be easier if you just lifted the top cover of the PS4.
    Poobler - Antwoord
    The earlier comment by Emil Fisk is spot-on. I found it impossible to remove the cover without first using a spudger to release the four clips on each side.
    midahed - Antwoord
    I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
    Bahaa CHEBLI - Antwoord
  4. PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: stap 4, afbeelding 1 van 3 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: stap 4, afbeelding 2 van 3 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: stap 4, afbeelding 3 van 3
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
    Undo 4 clips on each side by using a spudger. And then lift the front corners up and pull towards you to undo them.
  5. PlayStation 4 Slim Optical Disc Drive Replacement: stap 5, afbeelding 1 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 5, afbeelding 2 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 5, afbeelding 3 van 3
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    UK model seems to be different here. There's no Philips screw where there is on your image.
    MaFt Morley - Antwoord
    This regards EU models in general, i think. My danish version is the same.
    William Villadsen -
    The screw on the left was 31mm, and the one on my right side was only 19mm.
    CUH-2215B doesn't seem to have the top antenna screw
    Kenneth Beerman - Antwoord
  6. PlayStation 4 Slim Optical Disc Drive Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 16mm Philips screws holding the power supply in place.
    Es gibt diese Schrauben bei meiner Ps4 Cuh 2116A nicht und ich bekomme das Teil so nicht raus. Kann mir jmd helfen?
    Julian S. - Antwoord
    Only 2 Phillips actress here on my UK
    Only 2 phillips screws on the US one as well.
    Sean Douglas - Antwoord
    I also only have two screws here in the US.
    Rachel Kelley - Antwoord
    CUH-2215B has two T9 Security Torx screws on metal shield and two Phillips screws
  7. PlayStation 4 Slim Optical Disc Drive Replacement: stap 7, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement: stap 7, afbeelding 2 van 2
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
    Is this metal sheet required for the unit to power on?
    AlexT - Antwoord
    I think the metal sheet protects the rest of the console or something from heating too much.
    BloodSpark22 -
    Kann man diesen Metallblech einzeln kaufen? Finde im Internet nichts
    SoN GoKu - Antwoord
    A quoi sert la tôle métallique qui recouvre le ventilateur et l’alimentation svp
    Ittady92 - Antwoord
    Que puedo hacer si uno de los tornillos que sujetan esa lamina está barrido y no los puedo quitar?
    Maalem - Antwoord
  8. PlayStation 4 Slim Optical Disc Drive Replacement: stap 8, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement: stap 8, afbeelding 2 van 2
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    What does this mean for part do? This part is not present in my console nor is the space where it's supposed to reside as shown in the picture above.
    The Hondo - Antwoord
    Me neither, guess they are different models.
    Daniel Henderson -
    There was a longer clip 8mm long on the left side which had to be pulled straight out. However, be careful when pulling out the antenna. My cable was soldered to the metal plate.
    It is easier to wiggle the cable out from the plastic power supply housing in step 10.
    The model shown in this tutorial is the PS4 Slim CUH-2115, because it has the WiFi Bluetooth antenna attached to the PSU.
    BRG Kasumi77 Main Channel - Antwoord
  9. PlayStation 4 Slim Optical Disc Drive Replacement: stap 9, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement: stap 9, afbeelding 2 van 2
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    Forgot to mention to remove the hard drive.
    it's usually pretty straightforward to remove the HDD first on any Playstation System
    Kenneth Beerman -
    How do you get it when the screw is stripped
    Lucas Holland - Antwoord
  10. PlayStation 4 Slim Optical Disc Drive Replacement: stap 10, afbeelding 1 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 10, afbeelding 2 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 10, afbeelding 3 van 3
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
  11. PlayStation 4 Slim Optical Disc Drive Replacement: stap 11, afbeelding 1 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 11, afbeelding 2 van 3 PlayStation 4 Slim Optical Disc Drive Replacement: stap 11, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
    Your guide is good but detail. Could be alot better for a start you forgot to mention the screw on the other side that must also be removed to let the power supply out of ps4 slim
    Chicky Boy3 - Antwoord
    Could you replace a ps4 slim model CUH-211B with a N16-160P1A power supply
    Aiden Thrash - Antwoord
    Just because I feel like this needs to be stated clearly, “Do no attempt to pull the plug out by the wires!”
    Pull from the plastic, male end of the plug or you’re going to end up have a very bad day.
    Matthew D. H. - Antwoord
    Literally no way I can do it by the plastic, the only way is wires. Gotta risk it I guess
    Misha FV -
    You are right, pulling the wires is entirely wrong. I used the small rectangular, thin blue plastic to push the cable back from the socket. It was too tight. From my experience of repairing, never pull wires. The consequences of damaging it are not worth it.
    El-Musleh -
    This cable is very hard to remove from the connector. It's much easier to unplug this cable from the motherboard side (in step 20) because you can push the connector out from behind. (This might only be true for some motherboard revisions.)
    You can leave the power supply propped up on top of the console, like shown in the first picture. After you've unplugged the two cables in step 13, you can put the power supply back where it was to make flipping the console over easier.
    Jak Atackka - Antwoord
    This is about where I'd give up
    Shane Lucey - Antwoord
  12. PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: stap 12, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: stap 12, afbeelding 2 van 2
    • Unscrew and remove the 31.0mm screw using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 10x 5.0mm screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    I have a ps4 model CUH-2215B and all the orange screws were replaced with molded plastic pins. They don’t come out. I could rip the heads off with pliers or something, but idk how it would go back together.
    Reed Deemer - Antwoord
    I have the same model as you and was stopped by this discovery, what i would try to do is remove them with pliers anyway and just use some spare small screws in the holes and see if that works, but I think no harm would happen if you just leave them out since it’s just a plate being held on and no important components are being held in place exclusively by the black pins.
    Anurag RB26 - Antwoord
    Many of the screws were replaced with plastic rivets. Just use a straight head jewelers screw driver or very small chisel to shear off the head of the rivet by hitting the screw driver or chisel with a hammer. Be sure to keep the screw driver or chisel on a steep angle so not to place force down into to console. No need to replace them when re-assembling, They are not needed.
    bsey60@yahoo.com - Antwoord
    Anyway of ur gonna clean ur ps4 , it's better to remove the bottom one , u can get the motherboard without even touching that cover , it's not so necessary
    sherlanmamaril - Antwoord
    • If there are black plastic rivets in place of some screws, pull them out using pliers. They aren't necessary.
    The PS4 Slim CUH-2215B has plastic rivets instead of screws!
  13. PlayStation 4 Slim Optical Disc Drive Replacement: stap 14, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement: stap 14, afbeelding 2 van 2
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
  14. PlayStation 4 Slim Optical Disc Drive Replacement: stap 15, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement: stap 15, afbeelding 2 van 2
    • Unscrew and remove the two 3.0mm screws using a PH000 screwdriver with a counter-clockwise motion.
  15. PlayStation 4 Slim Optical Disc Drive Replacement: stap 16, afbeelding 1 van 2 PlayStation 4 Slim Optical Disc Drive Replacement: stap 16, afbeelding 2 van 2
    • Remove the disk drive out by pinching on either side of the two black plastic "claws" and lifting up with your hand.
    Naja, etwas unvollständig, das Laufwerk ist ja noch drin.
    Alex - Antwoord
    Where is the part number so I can order the exact fit? I have a older ps4 not the pro
    Neto Rosas - Antwoord
    This guy is incorrect unless you plan on breaking off all of the rivets, and replacing only half of the disk drive. Proper replacement requires full disassembly
    Ender - Antwoord
    How do I identify the part no’ for replacement please?
    Pete B - Antwoord
    This guide is only for replacing the disk loading system not the entire drive.
    Drew B - Antwoord
    Die Anleitung ist unvollständig und hört auf wenn es erst richtig los geht. Das Laufwerk ist noch drin und die Konsole muss restlos entkernt werden. Wärmeleitpaste sollte zur Hand sein. Bitte bitte ergänzt das noch. Es suggeriert das es deutlich einfacher ist, als es ist.
    jan hofmann - Antwoord
    شكراً!!!!!!!!!!
    GABBAR GAMR - Antwoord
    SO basically I just wasted my time reading this whole guide only to find out it's not to replace the whole drive?
    Nice.
    Bullet Baxter - Antwoord
    Ich musste letzt endlich die komplette PS4 zerlegen, um das komplette Laufwerk zu wechseln. Bitte hier nachbessern.
    Walter Söffky - Antwoord
    This yet another not fully completed guide. This is NOT a full disc drive replacement.
    William Loggarakis - Antwoord
Conclusie
99 andere personen hebben deze handleiding voltooid.
Hernan Rodriguez
4.082 Reputatie
3 handleidingen geschreven
Cal Poly, Team S19-G4, Livingston Winter 2018 Lid van Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 Leden
35 handleidingen geschreven
24 opmerkingen
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
Yegor Ilchuk - Antwoord
Yeah, where's the ending to this?
Ben Baptist - Antwoord
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
Freddie Parsons - Antwoord
when replacing do you have to swap a board like the PS4’s of the past?
Frank Ferrante - Antwoord
Nope, on the ps4 slim the optical drive is not married to the motherboard so any drive as long is the same model will work with any motherboard
Joshua Sites -
What drive is used for replacement? Anyone have a link?
Matthew Silliman - Antwoord
Newer ps4 slim has some black buttons on the drives instead of the 10 screws I’m stuck on getting the plate to the disc drive any suggestions????
Haktendo - Antwoord
I had to shave off the tops of those black buttons with a pocket knife to get the plate to come off.
Elizabeth Soltwedel -
The screw behind the warranty is not a T8 , it’s a TR8 (Tamper Resistant) screw. Just so you know which screwdriver to ACTUALLY buy/use.
Manuel Guzman - Antwoord
T8 works fine
Dakota Ryder -
hi guys, is it possible to replace a ps4 slim disc drive with a standard ps4 disc Drive?
thank you
Gaby Cove - Antwoord
Nope i’m afraid you’ll have to buy the same model of ps4 slim disc drive with same one.
David Peck -
Hi.
I have the ps4 slim, the optical drive stopped working. I been through the process here and replaced the drive with a new one but the new one won't work either. Any suggestions?
Andrew Turner - Antwoord
this will help me get my PS4 repaired
Jonathan Davis - Antwoord
i just need to get a new disc drive online
I have installed a new drive and it is not taking in disc, any suggestions ?
Fabio - Antwoord
Thanks for putting this up. I was wondering how different it was going to be, compared to tearing down the Pro.
This guide is incomplete.If you want to actually replace the disc drive,then refer to the fan guide. The entire system let's be taken apart to get to the disk drive and or the fan. I also Ordered a replacement drive and installed it properly and it does not work
Quintin Harbin - Antwoord
I replaced the optical drive but it only accepts the disc part of the way in. It's like something is blocking it because I can hear and fell the pull of the feed on the disc. I've taken it apart several times to check. What am I missing?
Elizabeth Soltwedel - Antwoord
I'm having the same problem
Antonio Rivera -
So I replaced it but it want take any discs at all? Im not sure what to do
Antonio Rivera - Antwoord
Joshua Sites - Aug 13, 2018
THIS
erexx - Antwoord
Not even a full guide💀💀
Roope Yrjölä - Antwoord
Le lecteur éjecte pas le cd de jeux. Comment faire ?
Emo - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 80
Afgelopen 7 dagen: 595
Afgelopen 30 dagen: 2,352
Altijd: 195,869
