Inleiding
Modern smartphones use light sensors to adapt their brightness to their surroundings, but these light sensors can become too old and not work properly. This guide will show you every step to take to successfully replace your light sensor.
Wat je nodig hebt
Power off your phone and unplug any cables.
Heat an iOpener and apply it to the rear glass for two minutes.
Apply a suction handle to the center of the bottom edge of the rear glass, as close to the edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the rear glass and frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner to slice the adhesive securing the rear glass.
Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
Insert a third opening pick under the bottom left corner of the rear glass.
Slide the opening pick up the left edge to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick under the top left corner of the rear glass.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick under the top right corner of the rear glass.
Slide the opening pick down the right edge to slice the remaining adhesive.
Remove the rear glass.
Secure the rear glass with pre-cut adhesive or double-sided adhesive tape.
After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use a Phillips screwdriver to remove the eleven 3.3 mm-long screws securing the motherboard cover.
Insert the flat end of a spudger under the center of the motherboard cover's bottom edge.
Twist the spudger to release the clips.
Lever the motherboard cover up until you can grip it with your fingers.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket on the bottom left corner of the motherboard.
Disconnect the antenna cable connector on the right, using tweezers.
Disconnect the antenna cable connector on the left using tweezers.
Use an opening tool to pry up and disconnect the front camera press connector.
Remove the front camera.
Insert an opening tool into the gap between the light sensor and chassis.
Pry the light sensor up and out.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
