Ga door naar hoofdinhoud
Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement
Carsten Frauenheim
Carsten Frauenheim en een andere bijdrager
Voor het laatst geüpdatet op July 24, 2024
45 minuten - 2 uren
Gemiddeld
Use this guide to remove or replace the heatsink or to service a faulty cooling fan on a Microsoft Surface Laptop 3 (15").
Wat je nodig hebt
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Prepare your device: stap 1, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Prepare your device: stap 1, afbeelding 2 van 2
    • Turn on your laptop and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power down your laptop and unplug any cables.
    • Close the laptop.
  2. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Flip the laptop over: stap 2, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Flip the laptop over: stap 2, afbeelding 2 van 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  3. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Removal tip: stap 3, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Removal tip: stap 3, afbeelding 2 van 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  4. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the rear feet: stap 4, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the rear feet: stap 4, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the rear feet: stap 4, afbeelding 3 van 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  5. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the front feet: stap 5, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the front feet: stap 5, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the front feet: stap 5, afbeelding 3 van 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  6. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reassembly tip: stap 6, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reassembly tip: stap 6, afbeelding 2 van 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  7. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reassembly tip: stap 7, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reassembly tip: stap 7, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reassembly tip: stap 7, afbeelding 3 van 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  8. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the upper case screws: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  9. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Open the display: stap 9, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Open the display: stap 9, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Open the display: stap 9, afbeelding 3 van 3
    • Flip the device over.
    • Open the display as far as it will go.
  10. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Lift up the upper case: stap 10, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Lift up the upper case: stap 10, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Lift up the upper case: stap 10, afbeelding 3 van 3
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  11. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Disconnect the ribbon cable: stap 11, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Disconnect the ribbon cable: stap 11, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Disconnect the ribbon cable: stap 11, afbeelding 3 van 3
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  12. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the upper case: stap 12, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the upper case: stap 12, afbeelding 2 van 2
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  13. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the SSD screw: stap 13, afbeelding 1 van 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  14. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the SSD: stap 14, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the SSD: stap 14, afbeelding 2 van 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  15. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the tape: stap 15, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the tape: stap 15, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the tape: stap 15, afbeelding 3 van 3
    • Use a pair of tweezers to remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
    • During reassembly, if the tape is sticky enough to be reused, reapply it.
  16. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the heatsink shield: stap 16, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the heatsink shield: stap 16, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the heatsink shield: stap 16, afbeelding 3 van 3
    • Use an opening tool to pry up the front edge of the metal shield covering the heatsink.
    • Try not to deform the shield too much—you'll need to reinstall it during reassembly.
  17. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement: stap 17, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement: stap 17, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement: stap 17, afbeelding 3 van 3
    • Work your way around the perimeter of the shield, prying up intermittently, until you can remove it completely.
  18. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement: stap 18, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement: stap 18, afbeelding 2 van 2
    • Remove the heatsink shield.
  19. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Disconnect the cooling fan: stap 19, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Disconnect the cooling fan: stap 19, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Disconnect the cooling fan: stap 19, afbeelding 3 van 3
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable's ZIF connector.
    • Use a pair of tweezers to pull the fan cable straight out of the connector.
  20. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the heatsink screws: stap 20, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the ten screws securing the heatsink:
    • Two 2.5 mm screws
    • Three 2.0 mm screws
    • One 3.0 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
  21. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reassembly tip: stap 21, afbeelding 1 van 1
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern.
  22. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Clear the alignment peg: stap 22, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Clear the alignment peg: stap 22, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Clear the alignment peg: stap 22, afbeelding 3 van 3
    • Use the tip of your finger to lift the far right edge of the heatsink up and off of the small alignment peg near the right side of the fan on the lower case.
    • Once the heatsink has cleared the peg, lightly pull the right edge towards the front of the device.
  23. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the heatsink: stap 23, afbeelding 1 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the heatsink: stap 23, afbeelding 2 van 3 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Remove the heatsink: stap 23, afbeelding 3 van 3
    • Remove the heatsink.
    • If the heatsink feels stuck to the CPU, gently wiggle it side-to-side to separate it from the thermal paste holding it down.
    • Don't pull on the heatsink too hard; the heat pipes are susceptible to creasing.
  24. Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reapply thermal paste: stap 24, afbeelding 1 van 2 Microsoft Surface Laptop 3 15" Heatsink and Fan Replacement, Reapply thermal paste: stap 24, afbeelding 2 van 2
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Carsten Frauenheim
135.539 Reputatie
371 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.418 handleidingen geschreven
Één opmerking
Bonjour, merci pour ce tutoriel.
par contre à l'étape 10, lorsque je voulais retirer le connecteur aimenté , c'est l'embout connecteur qui est relié directement au boitier du clavier qui s est enlevé. que faire et comment le replacer ? ça ne tient plus et ne fonctionne plus ...
Serkan Akcin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 74
Altijd: 6,012
