Ga door naar hoofdinhoud
Meta Quest 2 Front Cover Replacement
Arthur Shi
Arthur Shi
Voor het laatst geüpdatet op July 21, 2024
20 - 45 minuten
Gemiddeld
This guide shows how to remove and replace the front cover (aka front shell or faceplate) for your Meta Quest 2.
The front cover is the white plastic piece that covers the front of the headset. Removing the cover gives access to the motherboard.
Note: You'll need a long PH00 bit or a dedicated PH00 screwdriver to remove some recessed screws.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Meta Quest 2 Front Cover Replacement, Power off your Meta Quest 2: stap 1, afbeelding 1 van 1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Front Cover Replacement, Remove the facial interface: stap 2, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement, Remove the facial interface: stap 2, afbeelding 2 van 2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Front Cover Replacement: stap 3, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement: stap 3, afbeelding 2 van 2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Front Cover Replacement: stap 4, afbeelding 1 van 1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Front Cover Replacement, Unclip the side straps: stap 5, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement, Unclip the side straps: stap 5, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement, Unclip the side straps: stap 5, afbeelding 3 van 3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Front Cover Replacement: stap 6, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement: stap 6, afbeelding 2 van 2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Front Cover Replacement, Remove the top strap: stap 7, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement, Remove the top strap: stap 7, afbeelding 2 van 2
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Front Cover Replacement, Remove the head strap: stap 8, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement, Remove the head strap: stap 8, afbeelding 2 van 2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Front Cover Replacement, Remove the eyepiece trim screws: stap 9, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement, Remove the eyepiece trim screws: stap 9, afbeelding 2 van 2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Front Cover Replacement, Release the eyepiece trim clips: stap 10, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement, Release the eyepiece trim clips: stap 10, afbeelding 2 van 2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Front Cover Replacement: stap 11, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement: stap 11, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement: stap 11, afbeelding 3 van 3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Front Cover Replacement: stap 12, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement: stap 12, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement: stap 12, afbeelding 3 van 3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Front Cover Replacement, Reposition the eyepiece trim: stap 13, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement, Reposition the eyepiece trim: stap 13, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement, Reposition the eyepiece trim: stap 13, afbeelding 3 van 3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Front Cover Replacement, Disconnect the face sensor: stap 14, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement, Disconnect the face sensor: stap 14, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement, Disconnect the face sensor: stap 14, afbeelding 3 van 3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Front Cover Replacement: stap 15, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Front Cover Replacement, Remove the eyepiece trim: stap 16, afbeelding 1 van 1
    • Remove the eyepiece trim.
  17. Meta Quest 2 Front Cover Replacement, Reassembly note: stap 17, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement, Reassembly note: stap 17, afbeelding 2 van 2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Front Cover Replacement, Reassembly note: stap 18, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement, Reassembly note: stap 18, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement, Reassembly note: stap 18, afbeelding 3 van 3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Front Cover Replacement, Remove the front cover screws: stap 19, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement, Remove the front cover screws: stap 19, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement, Remove the front cover screws: stap 19, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Front Cover Replacement, Release the front cover clips: stap 20, afbeelding 1 van 2 Meta Quest 2 Front Cover Replacement, Release the front cover clips: stap 20, afbeelding 2 van 2
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Front Cover Replacement: stap 21, afbeelding 1 van 3 Meta Quest 2 Front Cover Replacement: stap 21, afbeelding 2 van 3 Meta Quest 2 Front Cover Replacement: stap 21, afbeelding 3 van 3
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Front Cover Replacement, Remove the front cover: stap 22, afbeelding 1 van 1
    • Remove the front cover.
Conclusie
Arthur Shi
282.898 Reputatie
587 handleidingen geschreven
iFixit Lid van iFixit
Staff
119 Leden
19.501 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 164
Altijd: 1,976
