Ga door naar hoofdinhoud
JBL Charge 4 Speaker Replacement
Rohith Dara
Rohith Dara en 2 andere bijdragers
Voor het laatst geüpdatet op September 24, 2024
20 - 30 minuten
Moeilijk
Uitgelichte studenten-handleiding
The speaker is responsible for creating the sound coming out of the device. If the sound quality is low or your speaker is not making sound at all but powering on it may be the result of a damaged or broken speaker. This guide will show you how to replace the speaker in your JBL Charge 4. This guide requires knowledge of desoldering. Find a guide on soldering and desoldering here.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. JBL Charge 4 Speaker Replacement, Speaker Grill: stap 1, afbeelding 1 van 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    ich schaffe es nur auf der einen seite. Auf der anderen ist die abdeckung viel zu fest dran ? was kann ich machen ?
    George Ziakos - Antwoord
  2. JBL Charge 4 Speaker Replacement: stap 2, afbeelding 1 van 2 JBL Charge 4 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    You have to remove the 8 mm screws before you try and Prius the other side. They are attached, and will break
    Noah Werthaiser - Antwoord
  3. JBL Charge 4 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Speaker Replacement, Passive Bass Radiators: stap 4, afbeelding 1 van 2 JBL Charge 4 Speaker Replacement, Passive Bass Radiators: stap 4, afbeelding 2 van 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    There is absolutely no reason to remove the passive radiators if you want to replace the speaker only!
    Just cut to step 6.
    Also the difficulty level is way too high. I found it very easy to disassemble the unit.
    Paul Decaro - Antwoord
  5. JBL Charge 4 Speaker Replacement: stap 5, afbeelding 1 van 2 JBL Charge 4 Speaker Replacement: stap 5, afbeelding 2 van 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 JBL Charge 4 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Flip the device so that the speaker faces you.
    • Remove the four 8mm Phillips #1 screws.
  7. JBL Charge 4 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Gently pull out the speaker.
    Bitte mal Artikel Nr des Lautsprechers
    Meiner schrabt bei hoher Lautstärke
    Tony - Antwoord
  8. JBL Charge 4 Speaker Replacement: stap 8, afbeelding 1 van 2 JBL Charge 4 Speaker Replacement: stap 8, afbeelding 2 van 2
    • Desolder the red and black wires.
    • A guide for soldering and desoldering can be found here.
    Where can I buy the driver from ????
    Annie Angelica Chetty - Antwoord
    If you can’t find a Jbl Charge 4 driver anywhere just try to send it into Jbl maintenance they should have a bunch of them
    A Potato -
    mine is blown also unfortunately :(
    A Potato -
    Error in guide. No need to remove end caps.
    Drew Van Zandt - Antwoord
    There is a major mistake in this guide, there is absolutely no reason to remove the passive radiators! The difficulty should be lowered also.
    PROXYhx - Antwoord
Conclusie
12 andere personen hebben deze handleiding voltooid.
Rohith Dara
405 Reputatie
1 Handleiding geschreven
Cal Poly, Team S1-G1, White Winter 2019 Lid van Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Leden
27 handleidingen geschreven
11 opmerkingen
Perfect - But where to get the replacement speaker ??? I’ve searched whole web. Please give me the info about replacement speaker diaphragm. Regards, T
Tadej Tomašič - Antwoord
Jbl charge 4 Led indicator board G ribbon cable authentic
carlos maltez - Antwoord
Removing bass radiators is not necessary to replace speaker
Artur - Antwoord
Where can I order a replacement speaker for the charge for I really appreciate this article thank you
mrwilliam9486 - Antwoord
Nice tutorial but you don’t have to remove the passive radiators because its not that it gets more difficult, but it is that after the passive radiators are removed, the sealing glue will break, resulting in a non waterproof speaker. so, the only thing to do, is after you remove the grill, remove the 4 screws, take out the driver and de-solder the red and black wires and after you get the new driver, solder the red wire to positive and the black to negative. Now do these steps backward. Then you’ll be resulted with a brand-new looking JBL charge 4. Trust me, I removed passive radiators of the charge 4 and it resulted me with an air leak. So do everything except for removing passive radiators.
Jokid - Antwoord
I need JBL charge 4 speakers black colour grill
charankingraju - Antwoord
BITTE mal die Artikel Beschreibung des Lautsprechers
Meiner ist übel am schrabben wenn ich laut mache
Tony - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 175
Altijd: 24,566
