Ga door naar hoofdinhoud
Handle Replacement on Patagonia Freewheeler/Freightliner Luggage
Brittany McCrigler
Brittany McCrigler en 8 andere bijdragers
Voor het laatst geüpdatet op March 20, 2025
5 - 10 minuten
Eenvoudig
Uitgelichte handleiding
Patagonië
The telescoping handle is a crucial component of any wheeled luggage. When it gets bent or worn out, it can stop moving smoothly or get stuck altogether, which can be quite frustrating.
This guide will demonstrate how to replace the handle of the Patagonia Freewheeler and Freightliner Roller Luggage. In some cases, however, a simple lubrication might do the trick. If that's the case, check out this guide to fixing a stuck luggage handle: Stuck Luggage Handle Lubrication.
Replacement parts are currently unavailable. To get your luggage fixed, take it in to a local Patagonia retail store for repair evaluation or send it in to Patagonia through their mail-in repair service.
Related Tutorials
Wat je nodig hebt
Gereedschap
  1. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: stap 1, afbeelding 1 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: stap 1, afbeelding 2 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Assess the damage: stap 1, afbeelding 3 van 3
    • Open the zipper at the base of the bag, then open the zipper in the compartment liner to expose the handle mechanisms.
    • All metal bars should be straight and plastic housings should be intact. Replacing the handle won't work if the metal bars or handle housings are damaged or bent.
    • If there is a possibility that the handle is sticking but not damaged, try lubricating it first.
  2. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the screws and clips: stap 2, afbeelding 1 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the screws and clips: stap 2, afbeelding 2 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the screws and clips: stap 2, afbeelding 3 van 3
    • Use a Phillips PH1 screwdriver to remove the four screws at the top handle bracket.
    • Then remove the two black plastic retaining clips that were kept in place by the red screws.
    • Be careful not to lose these pieces! Put them somewhere safe and accessible, they'll be reused later on.
  3. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the damaged handle: stap 3, afbeelding 1 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the damaged handle: stap 3, afbeelding 2 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Remove the damaged handle: stap 3, afbeelding 3 van 3
    • Press the handle release button to retract the toggle buttons on the handle.
    • If the toggle buttons won't retract, use a pointed object (like a screwdriver) to depress the buttons into the handle housing manually.
    • Pull the handle up and out of the handle housing. Use a repeated side-to-side movement to free the black plastic sleeves on the bottom portion of the handle.
    • Discard the damaged handle responsibly.
  4. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Insert the new handle: stap 4, afbeelding 1 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Insert the new handle: stap 4, afbeelding 2 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Insert the new handle: stap 4, afbeelding 3 van 3
    • While holding the release button on the top, use a repeated up-and-down movement to insert the new handle into the handle housing.
    • Replace the retaining brackets and screws to the original positions.
  5. Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Test the handle functionality: stap 5, afbeelding 1 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Test the handle functionality: stap 5, afbeelding 2 van 3 Handle Replacement on Patagonia Freewheeler/Freightliner Luggage, Test the handle functionality: stap 5, afbeelding 3 van 3
    • Test that the handle works properly. Move the handle into all positions and ensure it locks securely at each position:
    • Fully extended
    • Middle position (medium and small bags only)
    • Fully collapsed into the handle housing
    • The toggle buttons should move freely when the handle release button is pressed.
    • If the toggles function but need some TLC, see Stuck Luggage Handle Lubrication.
    • Close the interior liner zipper and main zipper compartments.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.745 Reputatie
142 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.465 handleidingen geschreven
2 opmerkingen
I depressed the pins. It worked once or twice. But now, I have to depress the pins every time to get the handle to work OR even with the pins depressed it will still not retract or if retracted it will still not open.
What is the solution?
I love this suitcase otherwise, but the handle has always been tricky needing just the right angle on the way in and having to jiggle it to get it out.
Help Patagonia!
Sharon - Antwoord
Hi Sharon,
The solution to depress the pins was meant to be a temporary solution when your handle is stuck in the extended position. Unfortunately, it means that your handle needs to be replaced as the handle trigger mechanism and pins are not functioning properly. Contact Patagonia for a new handle. You can either call us and we will can ship you a new one and you can replace yourself, or you can go to a Patagonia Retail Store and get a new handle there, afterwhich you can use the handing guidelines for replacement. Please visit our website for phone number and to locate a store near you. Copy and paste this URL in your search engine bar or click on the link.
http://www.patagonia.com/us/patagonia.go...
Marty Chapman -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 84
Afgelopen 30 dagen: 175
Altijd: 32,943
