Inleiding
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to remove or replace the battery in your Google Pixel 8a.
Lithium-ion batteries have a limited lifespan. If your phone doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
You'll need replacement battery, back cover, and flash unit adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive.
Wat je nodig hebt
Unplug all cables from your phone.
Completely power off your phone.
Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
Don't insert your tool under the edges of the camera bump.
Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
Slide the pick to the right, stopping when you reach the right edge of the cameras.
Remove the back cover.
Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
Follow this guide to apply new adhesive and install your back cover.
Use a hair dryer to heat the flash unit to soften the adhesive securing it to the logic board cover.
Use a Torx Plus 3IP screwdriver to remove the 15 screws securing the logic board cover:
Thirteen 4.3 mm‑long screws
Two 1.9 mm‑long screws
Remove the logic board cover (which has the wireless charging coil connected to it).
Use a pair of tweezers or your fingers to remove the metal cover on the right edge of your phone.
Insert the flat end of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
Insert the point of a spudger under the bottom edge of the 5G mmWave antenna press connector and pry straight up to disconnect it.
Move the battery and 5G mmWave cables out of the way of the battery.
Flip your phone over and use a hair dryer, heat gun, or hot plate to evenly heat the screen until the entire frame is warm to the touch.
Insert the flat end of an opening pick between the left edge of the battery and the frame.
Use your opening pick to lift the battery, separating any remaining adhesive.
Remove the battery.
Use the flat end of your spudger to scrape an edge of the old adhesive into a ball large enough to grip with a pair of tweezers.
Use tweezers or your fingers to peel and remove the old adhesive from the frame.
Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any adhesive residue and wipe it with a lint-free or microfiber cloth.
Peel the large, clear liner from the two battery adhesive strips.
Apply the strips to the battery recess, so the longer strip is on the left side.
Firmly press down along the length of both strips to secure the adhesive to the frame.
Remove the remaining blue liner from the strips.
To reassemble your device, follow these instructions in reverse order, starting from this step.
Calibrate your newly installed battery after completing this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
