Ga door naar hoofdinhoud
Google Pixel 8a 5G mmWave Antenna Replacement
Wat je nodig hebt
  1. Google Pixel 8a 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: stap 1, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: stap 1, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prepare your Pixel for disassembly: stap 1, afbeelding 3 van 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the SIM card tray: stap 2, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the SIM card tray: stap 2, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the SIM card tray: stap 2, afbeelding 3 van 3
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
  3. Google Pixel 8a 5G mmWave Antenna Replacement, Adhesive information: stap 3, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Adhesive information: stap 3, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Adhesive information: stap 3, afbeelding 3 van 3
    • The back cover is secured with adhesive around the perimeter and near the cameras. To avoid damaging your phone's internals, note the following:
    • Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
    • Don't insert your tool under the edges of the camera bump.
  4. Google Pixel 8a 5G mmWave Antenna Replacement, Insert an opening tool: stap 4, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Insert an opening tool: stap 4, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Insert an opening tool: stap 4, afbeelding 3 van 3
    • Your opening tool has a flat end and a curved end. During the opening procedure, use the flat end and angle it so the tool's sharp edge points upward.
    • Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
  5. Google Pixel 8a 5G mmWave Antenna Replacement, Separate the perimeter adhesive: stap 5, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Separate the perimeter adhesive: stap 5, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Separate the perimeter adhesive: stap 5, afbeelding 3 van 3
    • Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
  6. Google Pixel 8a 5G mmWave Antenna Replacement: stap 6, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 6, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 6, afbeelding 3 van 3
    • Slide your opening tool around the bottom right corner and up the right edge, stopping at the bottom of the camera bump.
    • Remove your opening tool from under the back cover.
  7. Google Pixel 8a 5G mmWave Antenna Replacement: stap 7, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 7, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 7, afbeelding 3 van 3
    • Insert your opening tool under the top right corner of the back cover, just above the camera bump.
    • Slide your opening tool along the top edge, stopping at the top left corner just above the camera bump.
  8. Google Pixel 8a 5G mmWave Antenna Replacement: stap 8, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 8, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 8, afbeelding 3 van 3
    • Insert your opening tool under the left edge of the back cover, just below the camera bump.
    • Slide your opening tool down the left edge to separate the adhesive.
  9. Google Pixel 8a 5G mmWave Antenna Replacement, Separate the camera bump adhesive: stap 9, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Separate the camera bump adhesive: stap 9, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Separate the camera bump adhesive: stap 9, afbeelding 3 van 3
    • A strip of adhesive above the camera bump secures the top edge of the back cover.
    • Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
    • You can insert the opening pick more than 3 mm along the top edge.
    • Slide the pick to the right, stopping when you reach the right edge of the cameras.
  10. Google Pixel 8a 5G mmWave Antenna Replacement: stap 10, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 10, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 10, afbeelding 3 van 3
    • A final strip of adhesive below the camera bump secures the back cover.
    • Insert the flat edge of an opening pick under the back cover, just below the camera bump.
    • Insert a second opening pick in the same spot on the other side.
  11. Google Pixel 8a 5G mmWave Antenna Replacement: stap 11, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 11, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 11, afbeelding 3 van 3
    • Pry up simultaneously with both picks and apply constant pressure to separate the final piece of adhesive securing the back cover.
    • Be careful not to bend the back cover. If the adhesive feels stubborn, rotate the cover side-to-side to further loosen the adhesive.
    • If the adhesive isn't separating, you can lightly heat the back cover just below the camera bump with a hair dryer or iOpener to soften the adhesive.
  12. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the back cover: stap 12, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the back cover: stap 12, afbeelding 2 van 2
    • Remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back cover.
  13. Google Pixel 8a 5G mmWave Antenna Replacement, Separate the flash unit: stap 13, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Separate the flash unit: stap 13, afbeelding 2 van 2
    • Use a hair dryer to heat the flash unit to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use an iOpener or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
  14. Google Pixel 8a 5G mmWave Antenna Replacement: stap 14, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 14, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 14, afbeelding 3 van 3
    • Slide your pick under the top edge of the flash and lift to separate the adhesive securing it to the cover.
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • During reassembly, follow this guide to replace the flash adhesives.
  15. Google Pixel 8a 5G mmWave Antenna Replacement, Unclip the logic board cover: stap 15, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Unclip the logic board cover: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    FixMat
    $36.95
    Koop
    • While the Pixel 8a uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the 15 screws securing the logic board cover:
    • Thirteen 4.3 mm‑long screws
    • Two 1.9 mm‑long screws
  16. Google Pixel 8a 5G mmWave Antenna Replacement: stap 16, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 16, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 16, afbeelding 3 van 3
    • Be very careful not to damage the spring contacts around your phone's perimeter. Only insert your tool where instructed.
    • Insert an opening pick under the bottom right corner of the logic board cover and pry up to release the clip.
    • Insert the tip of a spudger under the notch near the top right corner of the logic board cover (just below the screw hole) and pry up to release the clip.
  17. Google Pixel 8a 5G mmWave Antenna Replacement: stap 17, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 17, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 17, afbeelding 3 van 3
    • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board cover into place.
  18. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the wireless charging assembly: stap 18, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the wireless charging assembly: stap 18, afbeelding 2 van 2
    • Remove the logic board cover (which has the wireless charging coil connected to it).
  19. Google Pixel 8a 5G mmWave Antenna Replacement, Disconnect the battery: stap 19, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Disconnect the battery: stap 19, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Disconnect the battery: stap 19, afbeelding 3 van 3
    • Use a pair of tweezers or your fingers to remove the metal cover on the right edge of your phone.
    • During reassembly, place the upper left corner of the cover under the hook on the logic board before laying it into place.
  20. Google Pixel 8a 5G mmWave Antenna Replacement: stap 20, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 20, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 20, afbeelding 3 van 3
    • To prevent damaging the surface mounted components around the battery and 5G mmWave connectors, only pry where instructed.
    • Insert the flat end of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  21. Google Pixel 8a 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: stap 21, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: stap 21, afbeelding 2 van 2
    • Insert the point of a spudger under the bottom edge of the 5G mmWave antenna press connector and pry straight up to disconnect it.
  22. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the earpiece speaker: stap 22, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the earpiece speaker: stap 22, afbeelding 2 van 2
    • Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the earpiece speaker to the frame.
  23. Google Pixel 8a 5G mmWave Antenna Replacement: stap 23, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 23, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 23, afbeelding 3 van 3
    • Lift the bottom edge of the earpiece speaker and remove it.
    • When reinserting the speaker during reassembly, make sure the graphite film is out of the way. Then, insert the speaker at a downward angle and push it towards the front of the phone so the gasket goes into its cutout in the frame.
  24. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the antenna housing: stap 24, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the antenna housing: stap 24, afbeelding 2 van 2
    • Use a Torx Plus 3IP screwdriver to remove the two 4.3 mm‑long screws securing the antenna housing.
  25. Google Pixel 8a 5G mmWave Antenna Replacement: stap 25, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 25, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 25, afbeelding 3 van 3
    • Insert an opening pick under the left edge of the antenna housing and pry up to release the clips securing the housing.
    • Repeat the process on the top edge to release the remaining clips.
    • During reassembly, press firmly around the perimeter of the housing to engage its clips.
  26. Google Pixel 8a 5G mmWave Antenna Replacement: stap 26, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 26, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 26, afbeelding 3 van 3
    • Lift the antenna housing and remove it.
  27. Google Pixel 8a 5G mmWave Antenna Replacement, Disconnect the logic board: stap 27, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Disconnect the logic board: stap 27, afbeelding 2 van 2
    • Be careful not to touch the rear camera lenses during the next two steps.
    • Use the point of a spudger or your fingernail to pry up and disconnect the press connector just above the battery.
  28. Google Pixel 8a 5G mmWave Antenna Replacement: stap 28, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 28, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 28, afbeelding 3 van 3
    • Slide the tip of your opening pick under the right edge of the front-facing camera cable and lift to detach it.
    • If the pick can't slide under the cable, lightly heat the cable with a hair dryer or heat gun to soften the adhesive underneath.
  29. Google Pixel 8a 5G mmWave Antenna Replacement: stap 29, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 29, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 29, afbeelding 3 van 3
    • Move the battery and 5G mmWave cables out of the way of the battery.
  30. Google Pixel 8a 5G mmWave Antenna Replacement: stap 30, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 30, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 30, afbeelding 3 van 3
  31. Google Pixel 8a 5G mmWave Antenna Replacement: stap 31, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 31, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 31, afbeelding 3 van 3
    • The logic board is delicate. Be careful not to bend it as you free the lower edge from the frame.
    • Before trying to remove the board, make sure you removed the SIM tray.
    • Lift the top edge of the logic board from the frame.
    • Pull the top edge of the logic board to the right of the frame so the cutouts of the board lift over the vibration motor and protrusions in the frame.
    • As you pull, guide the charging port out of its recess in the frame.
    • Don't fully remove the logic board yet, as it's still connected to the frame by the screen cable.
    • During reassembly, push the logic board toward the bottom of the frame and press the charging port down until the bottom edge sits flush with its protrusion in the frame.
    • Make sure the flash, front-facing camera, and press connector don't become trapped under the frame.
  32. Google Pixel 8a 5G mmWave Antenna Replacement, Prop up your phone: stap 32, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prop up your phone: stap 32, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prop up your phone: stap 32, afbeelding 3 van 3
    • The logic board might fall out of place during this step. Hold it steady, but avoid gripping it by any of the camera lenses or connectors.
    • Apply a suction handle to the left side of the screen with the handle facing down.
    • Prop up the left side of your phone so it stands upright.
    • If you don't have a suction handle, prop up the phone against a sturdy object, such as a heavy box or thick book.
    • Tilt the logic board down and lay it flat, gently guiding the delicate graphite sheet around the cables.
    • Be careful not to touch the thermal pads on the underside of the logic board.
  33. Google Pixel 8a 5G mmWave Antenna Replacement: stap 33, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 33, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 33, afbeelding 3 van 3
    • Be very careful not to puncture the battery during this step.
    • Hold one hand above the display bracket when prying it up, as the bracket can easily eject.
    • Use the tip of one arm of your angled tweezers to pry up the top edge of the display cable bracket from the center of the logic board.
    • Be very careful not to damage the board under the bracket's socket. Only insert your tweezers just enough to pry up the bracket.
    • Remove the bracket.
    • During reassembly, hook the bottom edge of the bracket into its slot on the logic board and press down firmly on the top to snap the bracket back into place.
    • If your display cable bracket is bent and doesn't fit, replace it with a new one.
  34. Google Pixel 8a 5G mmWave Antenna Replacement: stap 34, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement: stap 34, afbeelding 2 van 2
    • Insert the flat end of a spudger or a clean fingernail under the top edge of the display cable press connector and pry straight up to disconnect it.
    • The tension in this cable makes it tricky to reconnect. If necessary, hold the neck of the cable in place with tweezers and align it over the socket before pressing down to secure it.
  35. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the logic board: stap 35, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the logic board: stap 35, afbeelding 2 van 2
    • Remove the logic board from the frame.
  36. Google Pixel 8a 5G mmWave Antenna Replacement, Check the front sensor gasket: stap 36, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Check the front sensor gasket: stap 36, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Check the front sensor gasket: stap 36, afbeelding 3 van 3
    • If the front sensor rubber gasket stayed on the frame or became misaligned, remove it and set it aside.
    • During reassembly, place the gasket over the front sensor on the logic board, with the smaller cutout toward the top.
    • Avoid touching the sensor with your fingers or tool.
  37. Google Pixel 8a 5G mmWave Antenna Replacement, Check the thermal pads: stap 37, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Check the thermal pads: stap 37, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Check the thermal pads: stap 37, afbeelding 3 van 3
    • Check the condition of the thermal pads—they'll be on the bottom of the logic board or the corresponding spot on the right side of the frame.
    • If you're reusing your logic board and either of the thermal pads are damaged, remove the old pad, clean the surface with highly-concentrated isopropyl alcohol (over 90%), and apply a new pad.
    • If you have a new logic board and it doesn't come with thermal pads pre-installed, apply the new pads now.
  38. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the mmWave antenna: stap 38, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the mmWave antenna: stap 38, afbeelding 2 van 2
    • The 5G mmWave antenna is lightly adhered to the frame.
    • Insert the point of your spudger under the lower left corner of the 5G mmWave antenna and pry up to separate its adhesive.
  39. Google Pixel 8a 5G mmWave Antenna Replacement: stap 39, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement: stap 39, afbeelding 2 van 2
    • Remove the 5G mmWave antenna and cable from the frame.
  40. Google Pixel 8a 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna cable: stap 40, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna cable: stap 40, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Remove the 5G mmWave antenna cable: stap 40, afbeelding 3 van 3
    • Conductive tape secures the 5G mmWave antenna to its cable. In this step, you'll disconnect the cable before peeling off the tape.
    • Grab the cable as close to the head of the connector as possible and pry the connector away from the antenna to disconnect it.
    • Lift the 5G mmWave antenna cable upward and peel it from the antenna.
    • If the conductive tape rips, peel the remaining pieces off with tweezers or your fingers.
  41. Google Pixel 8a 5G mmWave Antenna Replacement, Prepare the cable for reassembly: stap 41, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prepare the cable for reassembly: stap 41, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prepare the cable for reassembly: stap 41, afbeelding 3 van 3
    • The 5G mmWave antenna is all that remains.
    • Peel and remove the conductive tape from the head of the cable.
  42. Google Pixel 8a 5G mmWave Antenna Replacement, Prepare your 5G mmWave antenna for reassembly: stap 42, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prepare your 5G mmWave antenna for reassembly: stap 42, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement, Prepare your 5G mmWave antenna for reassembly: stap 42, afbeelding 3 van 3
    • The next three steps show how to reconnect the 5G mmWave antenna cable and apply new adhesive. If you don't have replacement adhesive, skip the remaining steps.
    • Peel your replacement adhesive off of the large liner.
    • Remove the two red liners to expose the sticky side of the adhesive.
  43. Google Pixel 8a 5G mmWave Antenna Replacement: stap 43, afbeelding 1 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 43, afbeelding 2 van 3 Google Pixel 8a 5G mmWave Antenna Replacement: stap 43, afbeelding 3 van 3
    • Reconnect the 5G mmWave antenna cable.
    • Apply the square tab of the adhesive strip onto the head of the connector and the long edge onto the thin, upright side of the antenna.
  44. Google Pixel 8a 5G mmWave Antenna Replacement: stap 44, afbeelding 1 van 2 Google Pixel 8a 5G mmWave Antenna Replacement: stap 44, afbeelding 2 van 2
    • Peel and remove the two blue liners from the adhesive.
Conclusie
To reassemble your device, follow these instructions in reverse order, starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
59.654 Reputatie
430 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.895 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 111
Altijd: 135
