Ga door naar hoofdinhoud
Google Pixel 5a Speaker Assembly Replacement
Wat je nodig hebt
    1. Google Pixel 5a Speaker Assembly Replacement, Eject the SIM card tray: stap 1, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement, Eject the SIM card tray: stap 1, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement, Eject the SIM card tray: stap 1, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      SIM Card Eject Tool
      $2.99
      • Insert a SIM card eject tool into the small hole on the right side edge of the frame.
      • A standard SIM card eject tool may be too wide for the job. Don't force the tool in—use a small paperclip, or a properly sized tool, like the SIM eject bit.
      • Press firmly until you feel the SIM card tray pop out.
      • Remove the SIM card tray from the phone.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel 5a Speaker Assembly Replacement, Precautionary notes: stap 2, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Precautionary notes: stap 2, afbeelding 2 van 2
      • Be sure to turn off your device before you begin the repair.
      • You'll need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
      • Take note of the two seams on the edge of the phone:
      • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
      • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel 5a Speaker Assembly Replacement, Heat the right edge of the screen: stap 3, afbeelding 1 van 1
      • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
      • Depending on the strength of your device's adhesive, you may need to reapply the iOpener multiple times in order to weaken it enough.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel 5a Speaker Assembly Replacement, Bezel removal note: stap 4, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Bezel removal note: stap 4, afbeelding 2 van 2
      • To remove the screen, you'll need to insert opening picks in between the black clips that secure the bezel to the midframe.
      • Note the optimal points of entry before proceeding.
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel 5a Speaker Assembly Replacement, Create a gap between the bezel and midframe: stap 5, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Create a gap between the bezel and midframe: stap 5, afbeelding 2 van 2
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      • Place a suction cup as close to the right edge of the screen as possible.
      • Lift the suction cup with a strong steady force until a small gap forms between the bezel and midframe.
      Vraag FixBot
      Voeg opmerking toe
    5. Google Pixel 5a Speaker Assembly Replacement, Insert an opening pick: stap 6, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Insert an opening pick: stap 6, afbeelding 2 van 2
      • The bezel is connected to the midframe by a series of plastic clips which can be detached by inserting an opening pick at points all along the seam.
      • Insert the tip of an opening pick into the bezel seam about 4-5 cm from the bottom of the phone.
      Vraag FixBot
      Voeg opmerking toe
    6. Google Pixel 5a Speaker Assembly Replacement: stap 7, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 7, afbeelding 2 van 2
      • Insert the tip of an opening pick into the bezel seam about 3-4 cm from the top of the phone.
      Vraag FixBot
      Voeg opmerking toe
    7. Google Pixel 5a Speaker Assembly Replacement: stap 8, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 8, afbeelding 2 van 2
      • Insert the tip of an opening pick into the bezel seam at the top of the phone.
      • If this step proves difficult, slide the pick along the top right corner of the phone until there is enough of a gap at the top for the opening pick.
      Vraag FixBot
      Voeg opmerking toe
    8. Google Pixel 5a Speaker Assembly Replacement: stap 9, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 9, afbeelding 2 van 2
      • Insert the tip of an opening pick into the bezel seam at the bottom of the phone.
      • If this step proves difficult, slide the pick along bottom right corner of the phone until there is enough of a gap at the bottom for the opening pick.
      Vraag FixBot
      Voeg opmerking toe
    9. Google Pixel 5a Speaker Assembly Replacement: stap 10, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 10, afbeelding 2 van 2
      • Insert the tip of an opening pick into the bezel seam on the left side of the phone, about 2 cm from the bottom of the phone.
      Vraag FixBot
      Voeg opmerking toe
    10. Google Pixel 5a Speaker Assembly Replacement: stap 11, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 11, afbeelding 2 van 2
      • Insert the tip of an opening pick into the bezel seam about 3-4 cm below the front-facing camera.
      Vraag FixBot
      Voeg opmerking toe
    11. Google Pixel 5a Speaker Assembly Replacement: stap 12, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement: stap 12, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement: stap 12, afbeelding 3 van 3
      • Be sure to detach all the clips. Slice through any remaining adhesive with an opening pick.
      • Open the device from the right side like a book.
      Vraag FixBot
      Voeg opmerking toe
    12. Google Pixel 5a Speaker Assembly Replacement: stap 13, afbeelding 1 van 1
      Magnetic Project Mat
      $19.95
      • Use a T3 Torx driver to remove the 4.6 mm-long screw securing the screen connector bracket.
      Vraag FixBot
      Voeg opmerking toe
    13. Google Pixel 5a Speaker Assembly Replacement, Remove the connector bracket: stap 14, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Remove the connector bracket: stap 14, afbeelding 2 van 2
      • Use a pair of tweezers to remove the screen connector bracket.
      Vraag FixBot
      Voeg opmerking toe
    14. Google Pixel 5a Speaker Assembly Replacement, Remove the screen: stap 15, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Remove the screen: stap 15, afbeelding 2 van 2
      • Use the tip of a spudger to pry up and disconnect the screen flex cable.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Vraag FixBot
      Voeg opmerking toe
    15. Google Pixel 5a Speaker Assembly Replacement, Screen information: stap 16, afbeelding 1 van 1
      • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
      • To prevent damaging your screen or replacement screen:
      • When handling your screen, grip it by its edges.
      • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
      Vraag FixBot
      Voeg opmerking toe
    16. Google Pixel 5a Speaker Assembly Replacement: stap 17, afbeelding 1 van 1
      • Remove the screen from the phone.
      • During reassembly:
      • If you replaced the screen, check the screen's front-facing camera hole and remove any protective liners covering it.
      • Remember to reinstall the screen connector bracket.
      • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
      • If you are using Tesa tape to reattach the screen, follow this guide.
      • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel 5a Speaker Assembly Replacement, Remove the screws: stap 18, afbeelding 1 van 1
      • Use a T3 Torx driver to remove six of the screws securing the midframe to the motherboard:
      • Four 4.6 mm screws
      • One 4.0 mm screw
      • One 2.0 mm screw
      • Since a few of these screws have different lengths, keep track of each screw and be sure to reinstall them in their proper places.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel 5a Speaker Assembly Replacement, Remove the black plastic cover: stap 19, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Remove the black plastic cover: stap 19, afbeelding 2 van 2
      • Use the pointed end of a spudger to pry up on the black plastic cover at the bottom left of the phone.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel 5a Speaker Assembly Replacement: stap 20, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 20, afbeelding 2 van 2
      • Slide the pointed end of the spudger left until the plastic cover is completely separated from the midframe.
      • Remove the plastic cover from the midframe.
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel 5a Speaker Assembly Replacement: stap 21, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement: stap 21, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement: stap 21, afbeelding 3 van 3
      • Use a pair of tweezers to slightly peel back the tape concealing the two screws securing the charging port bracket.
      Vraag FixBot
      Voeg opmerking toe
    5. Google Pixel 5a Speaker Assembly Replacement, Remove the remaining screws: stap 22, afbeelding 1 van 1
      • Use a T3 Torx driver to remove the remaining four screws securing the midframe to the motherboard:
      • Three 4.6 mm screws
      • One 4.0 mm screw
      Vraag FixBot
      Voeg opmerking toe
    6. Google Pixel 5a Speaker Assembly Replacement: stap 23, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 23, afbeelding 2 van 2
      • Use a spudger or a pair of tweezers to peel back the tape securing the charging port bracket to the speaker assembly.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      Vraag FixBot
      Voeg opmerking toe
    7. Google Pixel 5a Speaker Assembly Replacement: stap 24, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement: stap 24, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement: stap 24, afbeelding 3 van 3
      • Use a blunt pair of tweezers, or your fingers, to carefully peel back the graphite sheet covering the battery.
      • Be careful not to accidentally puncture or otherwise damage the battery when gripping the graphite sheet.
      Vraag FixBot
      Voeg opmerking toe
    8. Google Pixel 5a Speaker Assembly Replacement, Detach the midframe: stap 25, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Detach the midframe: stap 25, afbeelding 2 van 2
      • Insert the pointed end of a spudger under the top right corner of the midframe.
      • There is a black plastic clip at the top of the midframe that secures it to the top of the frame. To detach it, use the spudger to pull the midframe down and then pry up.
      Vraag FixBot
      Voeg opmerking toe
    9. Google Pixel 5a Speaker Assembly Replacement, Remove the midframe: stap 26, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Remove the midframe: stap 26, afbeelding 2 van 2
      • Remove the midframe.
      Vraag FixBot
      Voeg opmerking toe
    10. Google Pixel 5a Speaker Assembly Replacement, Replace the plastic bits: stap 27, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement, Replace the plastic bits: stap 27, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement, Replace the plastic bits: stap 27, afbeelding 3 van 3
      • There are two small plastic bits that help hold the midframe in place. Take care not to misplace them, as without the midframe to hold them in place, they are very easy to lose.
      • Be sure to place these back into their respective corners before replacing the midframe when reassembling your device.
      Vraag FixBot
      Voeg opmerking toe
    11. Google Pixel 5a Speaker Assembly Replacement, Disconnect the battery: stap 28, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Disconnect the battery: stap 28, afbeelding 2 van 2
      • Use the flat end of a spudger to pry up on the battery connector to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel 5a Speaker Assembly Replacement, Remove the 16 MP Ultrawide camera: stap 29, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement, Remove the 16 MP Ultrawide camera: stap 29, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement, Remove the 16 MP Ultrawide camera: stap 29, afbeelding 3 van 3
      • Use the flat end of a spudger to pry up on the 16 MP Ultrawide camera's connector to disconnect it.
      • Remove the 16 MP Ultrawide camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel 5a Speaker Assembly Replacement, Remove the 12.2 MP Wide-Angle camera: stap 30, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement, Remove the 12.2 MP Wide-Angle camera: stap 30, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement, Remove the 12.2 MP Wide-Angle camera: stap 30, afbeelding 3 van 3
      • Use the flat end of a spudger to pry up on the 12.2 MP Wide-Angle camera's connector to disconnect it.
      • Remove the 12.2 MP Wide-Angle camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel 5a Speaker Assembly Replacement, Disconnect the headphone jack: stap 31, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Disconnect the headphone jack: stap 31, afbeelding 2 van 2
      • Use the pointed end of a spudger to pry up on the headphone jack connector to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel 5a Speaker Assembly Replacement, Remove the headphone jack: stap 32, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement, Remove the headphone jack: stap 32, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement, Remove the headphone jack: stap 32, afbeelding 3 van 3
      • Use the flat end of a spudger to pry up on the headphone to pop it out of its socket.
      • Remove the headphone jack.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel 5a Speaker Assembly Replacement, Disconnect the fingerprint sensor cable: stap 33, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Disconnect the fingerprint sensor cable: stap 33, afbeelding 2 van 2
      • Use the flat end of a spudger to pry up on the fingerprint sensor connector to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    2. Google Pixel 5a Speaker Assembly Replacement, Disconnect the camera flash cable: stap 34, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement, Disconnect the camera flash cable: stap 34, afbeelding 2 van 2
      • Use the flat end of a spudger to pry up on the camera flash connector to disconnect it.
      Vraag FixBot
      Voeg opmerking toe
    3. Google Pixel 5a Speaker Assembly Replacement, Remove the motherboard screws: stap 35, afbeelding 1 van 1
      • Use a T3 Torx driver to remove the three 2.9 mm screws securing the motherboard to the frame.
      Vraag FixBot
      Voeg opmerking toe
    4. Google Pixel 5a Speaker Assembly Replacement: stap 36, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 36, afbeelding 2 van 2
      • Insert the flat end of a spudger under the top right corner of the motherboard to lift it from the frame.
      • The SIM card tray also secures the motherboard to the frame, so double-check that it has been removed before this step.
      Vraag FixBot
      Voeg opmerking toe
    5. Google Pixel 5a Speaker Assembly Replacement: stap 37, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 37, afbeelding 2 van 2
      • Insert the flat end of a spudger under the top left corner of the motherboard to lift it from the frame.
      Vraag FixBot
      Voeg opmerking toe
    6. Google Pixel 5a Speaker Assembly Replacement: stap 38, afbeelding 1 van 2 Google Pixel 5a Speaker Assembly Replacement: stap 38, afbeelding 2 van 2
      • Insert the pointed end of a spudger under the the screw slot to the top right of the speaker assembly to dislodge it from the frame.
      • Be careful not to deform the battery when prying at the speaker assembly.
      Vraag FixBot
      Voeg opmerking toe
    7. Google Pixel 5a Speaker Assembly Replacement, Remove the motherboard: stap 39, afbeelding 1 van 1
      • Remove the motherboard and speaker assembly.
      Vraag FixBot
      Voeg opmerking toe
    1. Google Pixel 5a Speaker Assembly Replacement, Disconnect the speaker assembly: stap 40, afbeelding 1 van 3 Google Pixel 5a Speaker Assembly Replacement, Disconnect the speaker assembly: stap 40, afbeelding 2 van 3 Google Pixel 5a Speaker Assembly Replacement, Disconnect the speaker assembly: stap 40, afbeelding 3 van 3
      • Follow this guide for in-depth instructions on how to disconnect a coaxial connector.
      • Slide one of the tweezer's tips under the white wire until it's snug against the connector, and pry straight up from the board.
      • To reinstall, hold the connector in place and gently press it straight down. The connector “snaps” into its sockets much like the metal snaps on a jacket.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 5a Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Clay Kim
13.329 Reputatie
21 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 79
Altijd: 2,230
