Ga door naar hoofdinhoud
Google Pixel 4 XL Display Assembly Replacement
Wat je nodig hebt
  1. Google Pixel 4 XL Display Assembly Replacement, Remove the SIM card tray: stap 1, afbeelding 1 van 3 Google Pixel 4 XL Display Assembly Replacement, Remove the SIM card tray: stap 1, afbeelding 2 van 3 Google Pixel 4 XL Display Assembly Replacement, Remove the SIM card tray: stap 1, afbeelding 3 van 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 XL Display Assembly Replacement, Heat the back panel glass: stap 2, afbeelding 1 van 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 XL Display Assembly Replacement, Apply a suction cup: stap 3, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement, Apply a suction cup: stap 3, afbeelding 2 van 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 XL Display Assembly Replacement, Insert an opening pick: stap 4, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement, Insert an opening pick: stap 4, afbeelding 2 van 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 XL Display Assembly Replacement, Begin to slice the adhesive: stap 5, afbeelding 1 van 3 Google Pixel 4 XL Display Assembly Replacement, Begin to slice the adhesive: stap 5, afbeelding 2 van 3 Google Pixel 4 XL Display Assembly Replacement, Begin to slice the adhesive: stap 5, afbeelding 3 van 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 XL Display Assembly Replacement, Slice the lefthand-side adhesive: stap 6, afbeelding 1 van 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 XL Display Assembly Replacement: stap 7, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 7, afbeelding 2 van 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 XL Display Assembly Replacement: stap 8, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 8, afbeelding 2 van 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 XL Display Assembly Replacement, Slice righthand-side adhesive: stap 9, afbeelding 1 van 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 XL Display Assembly Replacement: stap 10, afbeelding 1 van 3 Google Pixel 4 XL Display Assembly Replacement: stap 10, afbeelding 2 van 3 Google Pixel 4 XL Display Assembly Replacement: stap 10, afbeelding 3 van 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 XL Display Assembly Replacement, Slice the top-side adhesive: stap 11, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement, Slice the top-side adhesive: stap 11, afbeelding 2 van 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 XL Display Assembly Replacement, Lift up the back panel: stap 12, afbeelding 1 van 3 Google Pixel 4 XL Display Assembly Replacement, Lift up the back panel: stap 12, afbeelding 2 van 3 Google Pixel 4 XL Display Assembly Replacement, Lift up the back panel: stap 12, afbeelding 3 van 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 XL Display Assembly Replacement: stap 13, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 13, afbeelding 2 van 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 XL Display Assembly Replacement, Disconnect the battery: stap 14, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Magnetic Project Mat
    $19.95
    Koop
    • Remove the four T3 Torx screws securing the battery connector shield:
    • One 1.8 mm screw
    • One 4.1 mm screw
    • One 4.4 mm shouldered screw
    • One 4.0 mm shouldered screw
  15. Google Pixel 4 XL Display Assembly Replacement: stap 15, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 15, afbeelding 2 van 2
    Koop
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 XL Display Assembly Replacement: stap 16, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 16, afbeelding 2 van 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 XL Display Assembly Replacement: stap 17, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 17, afbeelding 2 van 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 XL Display Assembly Replacement, Disconnect the back panel connector: stap 18, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
  19. Google Pixel 4 XL Display Assembly Replacement: stap 19, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 19, afbeelding 2 van 2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 XL Display Assembly Replacement: stap 20, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 20, afbeelding 2 van 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 XL Display Assembly Replacement, Remove the back panel: stap 21, afbeelding 1 van 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 XL Display Assembly Replacement, Remove the camera connector covers: stap 22, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement, Remove the camera connector covers: stap 22, afbeelding 2 van 2
    • Gently pry back the battery adhesive pull tab to allow easier access to the screws underneath it.
  23. Google Pixel 4 XL Display Assembly Replacement: stap 23, afbeelding 1 van 1
    • Remove the three T3 Torx screws securing the rear-facing camera connector cover:
    • One 2.7 mm screw
    • One 4.1 mm screw
    • One 4.2 mm screw
  24. Google Pixel 4 XL Display Assembly Replacement: stap 24, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 24, afbeelding 2 van 2
    Koop
    • Use a pair of tweezers to remove the rear-facing camera connector cover.
  25. Google Pixel 4 XL Display Assembly Replacement: stap 25, afbeelding 1 van 1
    • Remove the three T3 Torx screws securing the front-facing camera connector cover:
    • One 4.1 mm screw
    • One 4.1 mm shouldered screw
  26. Google Pixel 4 XL Display Assembly Replacement: stap 26, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 26, afbeelding 2 van 2
    • Use a pair of tweezers to remove the front-facing camera connector cover.
  27. Google Pixel 4 XL Display Assembly Replacement, Disconnect the camera and sensor connectors: stap 27, afbeelding 1 van 3 Google Pixel 4 XL Display Assembly Replacement, Disconnect the camera and sensor connectors: stap 27, afbeelding 2 van 3 Google Pixel 4 XL Display Assembly Replacement, Disconnect the camera and sensor connectors: stap 27, afbeelding 3 van 3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  28. Google Pixel 4 XL Display Assembly Replacement: stap 28, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 28, afbeelding 2 van 2
    • Disconnect the additional sensor connector.
    • This cable is secured to the phone with some light adhesive.
  29. Google Pixel 4 XL Display Assembly Replacement, Remove the front camera and sensor assembly: stap 29, afbeelding 1 van 1
    • Remove the three T3 Torx screws securing the front camera and sensor assembly:
    • Two 2.7 mm screws
    • One 3.1 mm screw
  30. Google Pixel 4 XL Display Assembly Replacement: stap 30, afbeelding 1 van 3 Google Pixel 4 XL Display Assembly Replacement: stap 30, afbeelding 2 van 3 Google Pixel 4 XL Display Assembly Replacement: stap 30, afbeelding 3 van 3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
  31. Google Pixel 4 XL Display Assembly Replacement, Disconnect the display assembly: stap 31, afbeelding 1 van 1
    • Use a T3 Torx driver to remove the four 3.5 mm screws securing the display connector cover.
  32. Google Pixel 4 XL Display Assembly Replacement: stap 32, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 32, afbeelding 2 van 2
    Koop
    • Use a pair of tweezers to remove the display connector cover.
  33. Google Pixel 4 XL Display Assembly Replacement: stap 33, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 33, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the display connector from the motherboard.
  34. Google Pixel 4 XL Display Assembly Replacement, Slice the display adhesive: stap 34, afbeelding 1 van 1
    • Prepare an iOpener and apply it to the right edge of the display near the power button for one minute.
  35. Google Pixel 4 XL Display Assembly Replacement: stap 35, afbeelding 1 van 3 Google Pixel 4 XL Display Assembly Replacement: stap 35, afbeelding 2 van 3 Google Pixel 4 XL Display Assembly Replacement: stap 35, afbeelding 3 van 3
    • This process will almost always destroy the OLED display panel. Only proceed if you are replacing an already-broken display assembly.
    • Apply a suction cup to the heated edge of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display assembly.
    • Pull up on the suction cup with strong, steady force to create a gap between the display assembly and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Depending on the age of your phone, this may take significant force. If you are having trouble, apply more heat and try again.
  36. Google Pixel 4 XL Display Assembly Replacement: stap 36, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 36, afbeelding 2 van 2
    • Slide the opening pick down the right bezel of the phone, between the display and the frame, to slice the adhesive.
    • Leave the pick inserted in the bottom right corner.
  37. Google Pixel 4 XL Display Assembly Replacement: stap 37, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 37, afbeelding 2 van 2
    • Insert a second opening pick underneath the display assembly in the top left corner of the phone, near the front-facing camera cutout.
    • If this is difficult, you may need to reapply an iOpener to the upper edge of the display assembly.
    • Slide the opening pick around the corner and down the left side of the phone, stopping about halfway down, and leave the pick inserted.
  38. Google Pixel 4 XL Display Assembly Replacement: stap 38, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement: stap 38, afbeelding 2 van 2
    • Insert a third opening pick under the display assembly in the middle of the right edge of the phone and twist to separate the assembly.
  39. Google Pixel 4 XL Display Assembly Replacement, Tilt the display up: stap 39, afbeelding 1 van 2 Google Pixel 4 XL Display Assembly Replacement, Tilt the display up: stap 39, afbeelding 2 van 2
    • Tilt the display assembly up along the left edge of the phone.
    • Don't fully remove the assembly yet, as the display cable is still routed through the phone's frame.
  40. Google Pixel 4 XL Display Assembly Replacement, Thread the display connector through the frame: stap 40, afbeelding 1 van 1
    • Slide the display connector out of the hole near the motherboard to separate the display assembly from the rest of the phone.
    • You may need to tilt the assembly side to side to allow the connector to slide through the hole on the phone's frame.
    • The connector will slide out without any force.
  41. Google Pixel 4 XL Display Assembly Replacement, Remove the display assembly: stap 41, afbeelding 1 van 1
    • Remove the display assembly.
    • You will have to carefully thread the replacement assembly's display cable through the motherboard cutout. If you are having trouble, you can always loosen and partially remove the motherboard.
    • Follow this guide for instructions on how to apply adhesive to the replacement display assembly.
    • Be sure to test your repairs before you affix the display assembly with adhesives.
    • If you are using Tesa tape to reattach the assembly, follow this guide.
    • During the boot-up process after reassembly, the display assembly will go through a calibration sequence. Do not touch the display assembly during this process, as it could result in improper touch calibration and create touch issues.
Conclusie
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
21 andere personen hebben deze handleiding voltooid.
Carsten Frauenheim
118.976 Reputatie
341 handleidingen geschreven
iFixit Lid van iFixit
Staff
140 Leden
18.074 handleidingen geschreven
10 opmerkingen
If you’re only replacing the screen, can you just skip to Step 34?
Gerson - Antwoord
Because the front-facing camera module is partially embedded in the screen, it’s recommended that you remove it before attempting a screen repair. You won’t have to worry about damaging or realigning the module during reassembly!
Carsten Frauenheim -
Hi, I bought an OEM screen to replace my broken one: how can I make sure the OEM replacement is an original one and not simply a comaptible screen of lower quality?
Giovanni Stoto - Antwoord
If I'm only replacing the front screen which steps do I need to do and which can I skip?
Marlena Cremeens - Antwoord
The Pixel 4 XL’s layout requires the rear panel to be removed in order to disconnect the display connector, which is necessary to do prior to removing & replacing the display. This guide is that entire process, so no steps should be skipped. Happy fixing!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 110
Altijd: 22,072
