Inleiding
Follow this guide to replace a cracked or damaged plastic screen lens on your Nintendo Game Boy Advance.
The screen lens is the piece of plastic attached to the front shell—not the screen itself. If you're replacing the screen, follow this guide.
The Game Boy Advance uses JIS screws. If you use a non-iFixit Phillips driver in JIS screws, you'll risk stripping them. iFixit's Phillips bits are designed to be compatible with JIS screws.
Wat je nodig hebt
Before working on your Game Boy, turn the power switch to the OFF position and unplug any cables.
If you have a game cartridge installed, remove it.
Release the battery cover tab with your finger and swing the cover away from your Game Boy to remove it.
Remove the seven screws securing the back shell:
Six 9.4 mm‑long tri‑point Y0 screws
One 8.5 mm‑long JIS 1 screw
Lift the shoulder buttons (aka L and R buttons) straight up to remove them.
Slide the buttons into place, making sure the peg on the button goes into its circular cutout and the button itself is over the actual button mechanism.
Gently test the buttons to make sure they feel correct. If they don't, reposition them and make sure the metal arms aren't stuck in a weird position under the board.
Use the point of a spudger to fully push up both locking tabs on either side of the screen cable connector.
Use a JIS 1 screwdriver to remove the three 7 mm‑long screws securing the motherboard.
Use your fingers to grip the cartridge reader and lift the motherboard straight up to remove it.
Use tweezers or your fingers to remove the three silicone pads covering the buttons (A and B, the D‑pad, and Start/Select ).
Use tweezers or your fingers to remove the buttons (A and B as well as the D‑pad).
There's a seam between the screen and its gasket. Insert your tool here (under the screen) to give yourself the best chance of preserving the gasket.
There's a seam between the gasket and the shell. Don't insert your tool here, or you may damage the gasket.
Insert the flat end of a spudger under the screen and pry the screen up. Apply constant, steady pressure to allow the adhesive to separate.
Gereedschap gebruikt in deze stap:Tesa 61395 Tape$2.95
Remove the screen.
Compare your replacement screen to the original part—you may need to remove adhesive backings or protective liners from the new part before you install it.
If you damaged the gasket, remove all of it from the shell and use high‑concentration (>90%) isopropyl alcohol and coffee filters or a lint‑free cloth to remove any remaining residue. Then, replace the gasket with a new one, or apply strips of double‑sided tape where the old one was.
Lay a heated iOpener on the screen lens for two minutes to soften its adhesive.
Use your finger to push the screen lens up from the bottom. Apply steady, constant pressure to allow the adhesive to separate.
Remove the screen lens.
If any adhesive stayed on the shell, remove it with tweezers and a spudger and clean the residue with a high‑concentration (>90%) isopropyl alcohol and a coffee filter or lint‑free cloth.
Remove the adhesive backing from your replacement lens and firmly press it into place on the shell.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
Één andere persoon heeft deze handleiding voltooid.
