Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
20 Vragen Bekijk alle
Vraag afgerond
battery does not work! it wont charge!
3gs battery replacement
i bought a new battery and when i plugged it in the charge, the new battery will not charge. i changed it back and my old battery works fine.
do i have to set up the battery in a certain way, or what?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
What exactly is the kind of your old and new batteries? and if your old batterie works fine, why get a new one? Look first if both are compatible. Watch also how you deposit your new batterie inside to see if it is well connected, as a batterie always have a positive and negative, phone batterie always at the same place.
Was dit antwoord nuttig?
1 Opmerking:
the kind? it was a 3gs battery, like the old one..
my old battery did not work fine, it would last for a half hour, and then die at 90%. but the fact that the old battery recharges is a sign that tells that i have not done anything wrong when i was installing the new battery! it means that can reassemble my iphone perfectly without damage.
i do not understand ? compatible? i bought a 3gs battery for my 3gs iphone; so how could it not be compatible?
the new battery works, even though it does not recharge. it just goes down from 20% i think it was about 10% when i gave up. but it worked perfectly fine.
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 288
