Ga door naar hoofdinhoud
The Dell OptiPlex 745 small form factor is a compact desktop computer that has been a work office favorite, and still sits at desks to this day.
16 Vragen Bekijk alle
Why is my CD drive not opening?
When I press the CD drive button it does not open what to do?
Is dit een goede vraag?
1 Opmerking
@rufiniqbal what have you checked? Do you have power to the optical drive (CD drive)?
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi @rufiniqbal
Check if the cd drive tray opens if you click on the eject setting for the drive in Win Explorer.
Go to Win Explorer (press the Win key + e key - both together) > This PC > right click on the CD drive icon > eject.
It it opens OK, then the eject button on the drive may be faulty.
If it doesn't open, then there may be a problem with the tray motor or the drive electronics and further testing would be required to find the problem.
Was dit antwoord nuttig?
Score 1
You can try to force restart the computer
if that does not work, if there is a small manual opening hole in the drive door you can put a sim ejector tool into that to manually open it.
Or just stick a jimmy tool and pry until you can pull it out with your fingers
Score 1
Voeg je antwoord toe
Rufin Iqbal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 51
