Ga door naar hoofdinhoud
The tenth generation Corolla (E140/E150) was released in Japan in October 2006. A narrow variant was available in Japan while wider versions were sold internationally.
20 Vragen Bekijk alle
W what causes crank but no start
What causes cranking but no start
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Dit antwoord was oorspronkelijk aan een andere vraag gericht.
@debfinnegan you mentioned that you have "checked Sparks battery ignition coils" but did not tell us if you do have a spark when the engine cranks over. You need air, fuel and spark to fire the engine. You most likely have air and if you do have sparks then the issue would be fuel or it does not spark at the right time.
Let us know what exact year and engine size your Corolla is. From what you are describing I would take a closer look at the crankshaft and the camshaft position sensor.
Was dit antwoord nuttig?
"Intermittent cranking" and "will crank" are mutually exclusive.
If it cranks normally, the battery is OK. If it is intermittent you could have a number of problems.
If it won't start and you have spark while cranking, and it never makes any sign of starting, then turn your attention to fuel injectors, fuel pump, or empty tank.
Voeg je antwoord toe
Deb Finnegan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 132
