Ga door naar hoofdinhoud
Model numbers JSN-L21 and JSN-L42.
20 Vragen Bekijk alle
Lag issues and storage being filled out of nowhere
Lag issues my ping in games rondomly jumps and increases
Storage fulling up out of nowhere like the other day I had 18 gbs used and now I have 25 used nothing downloaded in between them days
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @meanpg3d
Download, install and run an anti malware program to ensure that there's no malware in the phone.
Once done, start the phone in safe mode and check if it now works OK.
If it does then a downloaded app¹ may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app one by one and start the phone in normal mode between each uninstall to see if it works OK or not. When it does, the last downloaded app that was uninstalled was the culprit.
¹ A downloaded app is one that you downloaded and installed on the phone and wasn't pre-installed on the phone when you first got it.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
MEAN PG3D zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 54
