Ga door naar hoofdinhoud
No power light and not turning on
After I opened my pc to check the monitor cable, turns out it's not getting any power anymore. The power light is not on anymore, i double checked every connection, and is all well connected. What could be the issue ? The power suplly is good, i didn't touched it.
Update (08/24/23)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@renatocoel46366 let us know what the issue was that prompted you to check your display cable. first try to reset your RAM. Remove it from the slots and then reseat the module(s) again.
Next try this
Turn off the computer. If you are unsure whether the computer is off or on, turn the computer on, and then shut it down. Yours does not come on so this should not be an issue but we just have to stay consistent.
Disconnect the power from the computer by unplugging the power cord from your computer.
Disconnect all external devices from the computer.
Remove the battery
Now hold the power button depressed for about 30sec-1min.
REapply the AC power adapter and see if your computer does now show any sign of life.
Since this happened after you (sort off) took it apart, double check all the connectors. Make sure that everything is seated properly. I know you said your power supply is good, but you want to check your power supply anyway. Make sure it has the proper voltages. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. After that you need to check and see if your motherboard even gets power. For that of course, you need to open it up.
Fir any further and deeper help, we would need to know your exact motherboard number. It should be printred on the motehrboard. To work on your compurter use the Maintenance adn Service guide from here
If you are stuck or see anything that requires some sort of explanation, post some pictures of that with ypour Question Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Hello, thanks for the answer.
The motherboard number is: DAG3DBMB8D0 REV:D
I've tried those methods and nothing seems to work.
I removed the battery, plug it again, disconnect the power, connect again, all those methods I saw on the internet I've tried but nothing works.
I also remove the ram, disconnect all the things that I can one by one and nothing happens.
I checked the motherboard and all the components and no signs of debries or burned components.
The only thing that shows some sort of life is when I unplug the power, remove the battery, hold on the power button for 30 seconds and then connect the battery again sometimes the power button goes live and turns on his red light. But nothings happens appart from that, only the led light goes on and nothing else more.
Do you have any clue what's going on ? Could be the motherboard that died while I was trying to fix the monitor cabble ?
door
@renatocoel34522 it could be. give us more detail on the repair.
door
Voeg je antwoord toe
Renato Coelho zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 135
Altijd: 2,592
