Switching on the bulb
My washroom's bulb always blinks several times before comes to proper working condition. So what is the reason behind this?
Is dit een goede vraag?
@muhammedsa33137 take a look at this teardown LED-lamp demontage It will show you how to get into one of those and this one LED-lamp 230V E27 defect repareren will show you how to check and possibly repair the bulb. Let us know if you need more assistance with that and you can always post images of your bulb components and circuit board with your question. Voeg afbeeldingen toe aan een bestaande vraag
Handleiding
Moeilijkheid:
Zeer eenvoudig
2 - 5 minutes
Handleiding
Moeilijkheid:
Gemiddeld
30 minutes
Handleiding
Moeilijkheid:
Gemiddeld
Was dit antwoord nuttig?
It may be that the electronic components in the LED light are beginning to fail. Usually it is the capacitors in the light as they may fail prematurely due to the heat generated by the operation of the LED light.
It could also be that the light is loose in the light fitting, making for a poor electrical connection
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 935
3 opmerkingen
Hi @muhammedsa33137,
Please verify the type of bulb e.g. Incandescent, CFL (compact fluorescent), Fluorescent tube or LED.
door jayeff
It is an LED bulb.
door Muhammed Saad Islahi
My bulb is not working what i do?
door Hassan
