Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De Samsung Galaxy Watch Active is een smartwatch ontworpen, ontwikkeld en geproduceerd door Samsung Electronics, een Zuid-Koreaans elektronicabedrijf. Het apparaat is te identificeren aan het modelnummer SM-R500. Het werd uitgebracht in maart 2019.
Watch randomly stopped responding
My watch randomly died while I was at work. The screen went from working normally, to only showing yellow-ish lines and kind of fading in and out, to not displaying picture at all now.... It's still functional, still charges (vibrates) and before I reset it through the app, my notifications would still make it vibrate. I'm just wondering if I should replace the screen or another component. I bought it back in 2020 used and already beaten up pretty good, as a work watch. It's had a rough life, from sand/steel dust to machining coolant/oil in the past 2 years. I've taken it apart after it died, and it doesn't appear any liquid got inside, though the screws did appear to have some corrosion on them. (Could have also been spottily applied loctite)
Am I looking at a screen or main board replacement? Obviously since I've opened it I'll replace the battery as well. I bought a galaxy watch active 2 in the meantime, but I'd like to fix this one for my S/O. Thanks!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
The screen needs to be replaced. Link: Samsung Wacht Active Vervanging van de schermmodule
This is very difficult to do.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Clayton Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 40
Altijd: 702
