Ga door naar hoofdinhoud
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
CMOS battery on Asus x540y
Where is the cmos battery on Asus x540y taking the laptop apart and can not find anywhere.Please show step by step on how to find and replace.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Shane Wigum it may not have one. If you removed the motherboard take a look underneath the board. IF you cannot locate it there either it is easily possible that Asus is using a capacitor instead of a CMOS battery. It would get power from the main battery. Anyhow, let us know why you need to replace it and post some good pictures of your motherboard as well as the chassis with your question so that we can give you a more precise answer.
Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 1
hi
there is no cmos battery in your laptop model just the main battery of laptop
Afbeeldingsinhoud bekijken:
Voeg je antwoord toe
Shane Wigum zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 22
Altijd: 2,942
