Ga door naar hoofdinhoud
The second generation Pathfinder was introduced in late 1995 with more rounded styling. It was completely redesigned from the first generation, switching from body on frame construction to unibody construction.
13 Vragen Bekijk alle
My pathfinder turns over but wont start
It will turn over but won't start. It is getting fuel and sparking. I just had the exhaust repaired. It ran for a few minutes but when I started it up again it shut off and won't start back.
Is dit een goede vraag?
2 opmerkingen:
What was the exhaust repair?
door
Not a gear-head here, but a quick search for common culprits gave me this rather detailed troubleshooting overview:
https://shop.advanceautoparts.com/r/car-...
Some further digging suggests that, if it isn't the common reasons then it could be a failed camshaft or crankshaft position sensor
door
Voeg een opmerking toe
2 Antwoorden
My suggestion would be to replace the fuel filter. Maybe some sediment in the gas tank got sucked into the filter when you ran the vehicle on low fuel. This sounds like a textbook issue of a clogged fuel filter.
Was dit antwoord nuttig?
1 Opmerking:
Jessica the OP stated that " It is getting fuel and sparking." How would that correspond with a clogged fuel filter?
door
When you work on your car and it does not work after you are finished, you broke something in the area where you was working, the crank position sensor CKP is probably near the back side of the engine, I would guess that a wire is broken in the exhaust area where you was working, do a very good inspection.
Voeg je antwoord toe
heathernkelly0126 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 1,784
