Ga door naar hoofdinhoud
Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
20 Vragen Bekijk alle
Why is my watch getting hot charging after screen replacement?
So I recently changed my wife’s screen last night and stuck it on the charger. I got the green snake and left it overnight. The next morning I checked on it and it wasn’t charged. I tried to reset the watch but it stays at the green and red snake. Now when I put it back on the charger it gets very very hot. Did I damage the battery or something else?
Is dit een goede vraag?
Score 4
1 Opmerking
I am having the same problem. I am trying to check the battery now with a multimeter but I can't locate positive/negative sides of battery to test???
door
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Hi Aaron !
It is possible your battery is damage.
I advise you to follow the repair tutorial for the screen to check the connections and the battery replacement tutorial.
Apple Watch Series 3 Batterij Afbeelding
Handleiding
Apple Watch Series 3 Vervanging van de batterij
Moeilijkheid:
Moeilijk
1 - 3 hours
Apple Watch Series 3 Scherm Afbeelding
Handleiding
Apple Watch Series 3 Vervanging van het scherm
Moeilijkheid:
Moeilijk
2 - 3 hours
Was dit antwoord nuttig?
Score 2
Make sure you have a good battery!!!
https://youtu.be/jX1dve5DC-0
Voeg je antwoord toe
Aaron zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 1,059
