Ga door naar hoofdinhoud
The Nokia E63 is a quad-band GSM that includes UMTS support. Is is released in 2008.
14 Vragen Bekijk alle
How do I install software to my nokia e63
my e63 was dropped into water. i dried it but when i turn on power it shows only nokia logo and then switched off. i think it need new software. so i connect with pc using usb cable for reinstalling software. the main problem is i can't connect my phone with pc. (even pc didn't show my ph) so in can't connect. how should i do?
Is dit een goede vraag?
Score 11
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Go through this guide to see if you can repair your water damaged machine: Electronics Water Damage
Was dit antwoord nuttig?
Score 4
min thet, after you follow the guide that mayer refers to, troubleshoot your phone and see what needs to be repaired, if anything. When you ask for the software, all you really need is the Nokia OVI suite and to update your phone’s software using Nokia Ovi Suite on your PC:
On your PC, open Nokia Ovi Suite and connect your phone
In Nokia Ovi Suite, select Tools > Software updates.
From the list of available updates, choose what you’d like to install. Nokia OVi suite does not work on a Mac, sorry :-) there is more info at Nokia about your phone. Good Luck and let us know how it is going.
Score 2
2 opmerkingen:
thz alot for ur advice. Is nokia ovi suite same as pc suite? I already have pc suite n i tried. but i can't connect with my ph
door
you may have to check on the Nokia site for that. I know it as OVi Suite for the Nokia phones I have had repaired in the past. The reason why your PC suite might not see your phone is because you still have to evaluate the water damage. Like I mentioned before, just follow the link mayer gave you. It is a great starting point.
door
I M DOWNLOAD A SOFTWARE OF NOKIA E63 FROM NOKIA PC SUIT "UPDATE PHONE SOFTWARE" ITS ABOUT 47MB SOFTWARE. BUT I DON'T KNOW HOW TO INSTALL IT IN THE PHONE.... WHEN I M DOBULE CLICK ON THIS SO ITS INSTALL IN MY PC PLEASE KINDLY SUGGEST ME WHAT CAN I DO ?
hrhimanshu1@gmail.com
Voeg je antwoord toe
min thet zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 28,123
