Ga door naar hoofdinhoud
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
20 Vragen Bekijk alle
a part came lose looking for origin
https://d3nevzfk7ii3be.cloudfront.net/ig...
phone and a black part fell out I can't seem to find its origin
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
photos would help as nobody can tell what you mean by just saying a black part fell out
Was dit antwoord nuttig?
Score 1
Update (10/28/2019)
Michelle
This piece comes from where the two screws hold the back plate to the screen assembly. If you look at the right hand bottom of the back plate when it is on the table inside facing up, you will see a small casting on the bottom right hand corner. This piece straddles that casting with its hole in the direction from where the attaching screw is inserted. Hope this helps.
Voeg je antwoord toe
Michelle Van Der Merwe zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 73
