Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
Change 30 pin to lightning/wireless charge
I'm looking to mod my iPod classic. I wanted to know if it'd be possible to change out the 30 pin connector for lightning and have a wireless charging coil put inside just changing the back cover to plastic/glass to have it charge?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Sorry not really possible.
Altering the connector from the 30 pin to a Lightning connectors wouldn’t really change anything. If anything you make your iPod less reliable. The physical size of the Lightning is so much smaller you would need to design a new case even then the charging or data rate wouldn’t change.
As for wireless charging I see no way to do that as you would need a completly new charging logic. Besides the work to design a workable case as it would need to be plastic or glass.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
What if I have the capability of machining a new case, specifically for the lightning port? Aside from that, are you aware of any other obstacles? Imagine this is a gift, and the effort doesn't really matter, or whether or not it makes sense. Would it work?
door
These look at this in a different way... You speak english but you don't speak Chinese so you know what is right? 你好 Thats the rub! It's more than a physical connector it's the dialog it speaks.
Just like my simple example you would need a circuit to translate the signals & dialog there's no room for it.
door
I'm currently working on a wireless charging setup on both a iPod Classic 5th and 7th Gen. I learned early on that soldering the positive and negative connections from my wireless receiver coil to the battery neg/pos terminals on the iPod mainboard immediately drained any battery I had in the iPod. It would, however, charge the battery if it were on a charging station. The only solution is to pull the mainboard of the iPod out and find the pos/neg terminals that the sync port uses via USB and make the coil solders there, where it's meant to receive power. Those terminals are so tiny, though, I'm already dreading it as I'm no soldering expert. This should work, though. You can also purchase charging base stations with a receiver coil kits for about $10 on eBay. I've found even the cheapos to be reliable.
Matt
Score 1
2 opmerkingen:
You do realize the back of the iPod is stainless steel and the charging coil needs to be mounted behind plastic or glass. in close proximity (at most 2-3mm).
You'll need mount the coil outside of the steel case and then find a way to hold it so its at least 4mm away from the steel back plate of the iPod and yet strong enough to weather the wear and tear. While this might be a fun project its not really practical.
door
Hey Matt I am planning on doing the same. I would really like to chat about it with you and learn what you already found out.
Is there any way we could get into contact?
door
My best idea? Emulate the Qi chargers for android
  1. Figure out how to connect to 30 pin connector to charge idevices (which connection)
  2. get Cheapo qi receiver and remove USB / Lightning connection
  3. Connect wires to old 30 pin connector to correct QI receiver wires to charge.
  4. Plug in and make sure it works.
  5. get soft plastic case for Idevice
  6. plug 30 pin in then while holding idevice upside down so the receiver is flat to back, slip cover over receiver.
  7. put iphone down on qi charger to test
  8. This has benefit of not damaging inside of idevice.
Hardest part is if the 30 pin doesn’t work correctly. I think you may be able to get an lightning to 30 pin adapter, open it up and using a lightening based qi receiver, wire it directly. The best part of this is it all should work and be testable before you even start the project
I have some old powermat based iphone 4 wireless charger cases that work but, I don’t want powermat and Qi charging stations all over the place. I want qi only because all my android devices use that
Score 1
2 opmerkingen:
OK I was reminded that this was here and came to update this issue.
I found Energizer (the battery company) has a 30 pin qi charger case. I have bought 4 of them from ebay / amazon / etc. I have 2 of them populated by my old iphone 4. ALSO, I got an Energizer for the Iphone 3 (???) that is a little bit shorter. It also has the 30 pin built in and it works.... on my IPOD 4 (????) but its a bit too big. I bought 2 of them for $4 each delivered and got 2 silicone case covers for the ipod4 (touch) and it exactly fills the gap around the ipod4 so it fits inside perfectly. I have 2 ipod 4's and 2 iphone 4's each in a fully form fitted rubber enclosure that works perfectly on any of the current batch of QI chargers. I now have qi dock chargers throughout my home with a working iphone or ipod on them and I use them as remote controllers for my whole house audio / controllers (smartthings, Plex, email, etc). I am happy. I just thought everyone should know these are out there and they work
door
Sorry, I was in a rush and made a couple of mistakes.
I have 4 iphone 4s's each in an energizer case that works.
I have 2 ipod 4 touchs each in a silicone case and then in an energizer case (for iphone 3s)
all 6 of them work well. I have an ipod classic that may fit in the case as well. I will try it and report.
Best of all, you don't need to do anything. Buy that case, Insert, Drop on current QI chargers and they start charging.
Case, and charger built in one
Such a deal
door
Voeg je antwoord toe
gourleygarrett zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 6,316
