Ga door naar hoofdinhoud
Repair and device guides for the 2016 Samsung Galaxy J5 smartphone, model SM-J510FN.
20 Vragen Bekijk alle
Detection of a component on motherboard
Hello.
Can anyone help me with detection of marked component from J5 Duos motherboard?
Looks like somethink wrong has happend..
https://ibb.co/edYuWv
Thanks.
Update (09/11/2017)
Oh, thanks :-).
Phone was probably water damaged. I can see probably salt at two places on top of the borad. One image is from components around WiFi/BT and other image is different side of board - bellow front flash diode.
https://ibb.co/fL3ota
https://ibb.co/nAm8ta
So, phone is KO. Thanks.
Is dit een goede vraag?
Score 2
5 opmerkingen
I think you need to provide some background information. Is the phone water damaged? Does it turn on? Any serious drops?
door
is that not a soldered shield over the top
door
It is soldered. But what is under?
And can malfunction of this component be reason for no-functional phone?
door
I need j5 (2016) Board
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@fbituco you'll find your BT/WiFi under that EMI shield. Could be a reason for non-functional if your BT or WiFi is not working. You'll have to give us a bit more information about what is not working on your phone.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Fbi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 1,597
