Ga door naar hoofdinhoud
Asus ZenFone 2 (ZE551ML) is an Android smartphone manufactured by ASUS released March 2015.
How can I understand what's the problem?
My phone doesn't work anymore. It neither starts nor charge. The charge's led doesn't go on when i try to charge it. I changed the usb connector but nothing changed. Can someone help me to find the problem? ,
Update (08/30/2017)
No.
I tried various cable and charger.
It's happened in the night, battery was on 60% but in the day's after morning nothing work , no led's light while charging and no responding when I push the power button.
Is dit een goede vraag?
Score 2
7 opmerkingen
Did you drop the phone? Does the phone charge when you use a different cable and power brick?
door
Different battery perhaps?
door
Do I have to try with a different battery? Can it be a motherboard's problem ?
door
Yeah, it could be either the mother board or the battery.
door
Is there no tools or methods to understand before what is not working or I can only try and try again till the solution?
door
2 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Use this guide to access the battery, the required tools are listed at the beginning of the guide I think.
This one will get you to the main board.
Asus ZenFone 2 Battery Afbeelding
Handleiding
Asus ZenFone 2 Battery Replacement
Moeilijkheid:
Moeilijk
20 minutes
Asus ZenFone 2 Motherboard Afbeelding
Handleiding
Asus ZenFone 2 Motherboard Replacement
Moeilijkheid:
Gemiddeld
15 minutes
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Hello i have a problem with camera because fall down strangly and my lcd is broken and also when i want to call my screen shutdown and itis not turn on again thank u
door
Voeg je antwoord toe
Vincenzo Liguori zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 420
