Ga door naar hoofdinhoud
the Dell Dimension 3000 was a mid-range desktop from 2004. it shipped with 2 GBs of ram and your choice of a Pentium 4, 4 HT, or Celeron.
5 Vragen Bekijk alle
replacing the CPU holder
The square frame that is used to help hold done the CPU. Two corners have broken off and the clips will not connect so the processor is not held in place. Where can I find the part?
Update (05/07/2017)
Here are the pictures - at least they show up in the preview!
Is dit een goede vraag?
Score 2
4 opmerkingen
Could you attach a picture? I think I know what you are talking about but I am not sure.
door
[image|1111596][image|1111597] Here are pictures of the broken CPU holder. I cannot click it into place because the clips are broken. Where can I get a new one?
door
Hi @Iwrayscott,
Your images are not showing.
You cannot add images to a 'comment' only to a question or an answer
You have to edit your question to add them, here's how Voeg afbeeldingen toe aan een bestaande vraag
door
Thanks jayeff. I just answered my question with the pictures.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @Iwrayscott,
Here is a link to the service manual for your desktop, (not that you need it but it may still be handy to have).
Scroll to the section that deals with removing the processor, (p.23 I think). It shows the heat sink retention base, which I think is the part that you want.
Here is a link to just one supplier of the part. It is not a recommendation to use them, it is shown to give an idea of the price. There may be others online that suit you better. Just search for Dell Dimension 3000 heat sink retention base for results.
Hopefully this is of some help.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks, jayeff! You have been extremely helpful!!
door
Voeg je antwoord toe
lwrayscott zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 26
Altijd: 753
